Sputter/cut out at high RPM, is it the distributor? |
Groosh |
Nov 23 2017, 12:03 PM
Member Group: Members Posts: 50 Joined: 21-October 11 From: Dexter, MI Member No.: 13,702 Region Association: Upper MidWest |
Happy Thanksgiving!
I'm getting a cut out at higher RPMs but it pulls well. I currently run Hot Spark on the original dizzy and the fuel pressure is solid. I have oiled the distributor with some results but before I go buy a new one, I wondered if there is something else I might try. |
rhodyguy |
Nov 23 2017, 12:06 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Is there a rev-limiting rotor in the distributor?
Groosh |
Nov 23 2017, 12:08 PM
mgphoto |
Nov 23 2017, 01:40 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Oil could be a problem.
Best to use Bosch high temp dizzy grease. FI points are low voltage, they don't burn impurities off, causes the engine to stutter. The Bosch stuff stays put when hot. |
Groosh |
Nov 23 2017, 01:44 PM
Oil could be a problem. Best to use Bosch high temp dizzy grease. FI points are low voltage, they don't burn impurities off, causes the engine to stutter. The Bosch stuff stays put when hot. I'll clean it up but would this still be a problem with the Hot Spark electronic ignition? |
timothy_nd28 |
Nov 23 2017, 03:41 PM
Clark had a similar issue. I texted him instructions that's not in this thread but look at post 6 for his conclusion
http://www.914world.com/bbs2/index.php?sho...=317471&hl= |
oakdalecurtis |
Nov 23 2017, 06:45 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
If it’s fuel injected, check the trigger points in the dizzy.
Groosh |
Nov 23 2017, 07:13 PM
Clark had a similar issue. I texted him instructions that's not in this thread but look at post 6 for his conclusion http://www.914world.com/bbs2/index.php?sho...=317471&hl= Thanks Tim! It looks like heat may be my problem. I did feel like the car didn't skip as much early on in this colder weather. I'll try the arctic silver between the plates. There are probably no more than 50 miles on the Hot Spark. Do you think the coil and ballast resistor are also needed? |
timothy_nd28 |
Nov 23 2017, 09:19 PM
He has a pointless module installed inside the distributor, also this injection system doesn't use trigger points. (IMG:style_emoticons/default/beerchug.gif)
Clark had a similar issue where his hot spark would start whacking out above 3000 rpm. I had him use a timing light attached to a random plug wire, and had him stare at this timing light as he manipulated the throttle cable. I had him repeat this test for every plug wire. I do believe his hotspark did fail due to a heak soak issues, either way it failed. If you repeat the test and see the same thing, your hotspark module has failed too. I've become a believer with this group buy 123 distributor. It is a investment, but I think it is money well spent vs buying another hotspark module. |
malcolm2 |
Nov 23 2017, 09:29 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Yes Tim_ND helped me. The timing light showed the cut out. I put it on each spark plug wire and all 4 cut out.
Go to the hot spark web site. They have documents and tests. It seems to be voltage that got me. Guess it is heat from voltage. I bought their coil and their ballast resistor. I still got over 14 volts. They want under 13.7. I got a 5 ohm br at napa. Slightly better voltage readings at high rpm, but not idle. Still 14. Put their br and the napa in series and still have too high voltage at 950 rpm. I have just left it with the new coil, new hot spark and the napa BR. And a spare hot spark in my trunk. The 1st hs module made it 38000 miles. during that time i did replace the voltage regulator. Did not know i should check the HS voltage. The HS comes with a pack of the cool goo stuff. Did you install it under the HS? Iam not much help. Good luck. Clark |
timothy_nd28 |
Nov 23 2017, 09:47 PM
Your input does help, it opened my eyes to a shitty design flaw with the hotspark module. I know it's a cheap knock off to the better pertronix module, but why would they design it for max voltage of 13.7v? (IMG:style_emoticons/default/screwy.gif)
I've been having a intermittent issue with my own 914, I haven't had much time in diagnosing it yet but I think it is ignition related. It's acting very similar to what you and Clark experienced. This is why I think it may be time to jump ship and abort the Chinese hotspark module and switch to the 123 dizzy. There are some very good reviews, and I like the option of tweaking the timing curve through my phone. This could be useful for different octane fuels or modern fuels riddled with ethanol. |
Groosh |
Nov 24 2017, 08:16 AM
Thanks everyone!
malcolm2 |
Nov 25 2017, 06:36 AM
Since i have a fresh module installed and a spare in the trunk, i'll put the new disty on the wish list and see how long i can make it in this set up. If 30000 + per module is my number, I'd say I might have 5 years to save up for one. And i can test the voltage often to see if it increases.
I like the idea of a new disty too. I just replaced the coil packs on my boar. It runs and starts like a dream. |
Lo-Fi Version | Time is now: 23rd April 2024 - 07:02 PM |
