4 Pages V  1 2 3 > »
> GB from 914Rubber.com A- Arm bushings CLOSING 12/23, $29/59 a set add tools for $30 adtnl. Reg price $48/80
Mikey914
post Nov 30 2017, 11:50 AM
The rubber man
As many of you may be aware there has been a "Cheap" option, that lets say brand "E" has done a video on notating that they are smaller than factory and change the pre-load on the arm.
Brand "U" lets call them has an install video saying that they have recreated the factory part with the same "type and amount of rubber being used"
Technically not true because as shown in the video by brand E the durometer is definitely not the same from the deflection noted.
With all the BS aside we have made a part like the factory bushing and a special tool to help install these. One of the problems with installation of this part is the end that brand E glosses over. When you get to the part where the tube holds that end from sliding down the shaft you have a "sharp edge" from the metal the rubber can catch on. If it catches you will scar the inside rubber. This will make a second attempt more difficult.
We have made the delrin "tools" to allow you to use a 1/2" stainless rod with some nuts and large washers to install. There is a taper to allow the rubber to clear the edge of the A arm without catching it.
I had Cary do up one for me and fully document this so that you will have some instruction as how to do this. We are currently compiling and putting this together now.
Mikey914
post Nov 30 2017, 11:54 AM
The rubber man
To be clear the delrin parts are the only "tools" we are providing. We figured that most of you have an Ace Hardware or Home Depot nearby and can acquire these for less than we can ship them for.
BeatNavy
post Nov 30 2017, 12:00 PM
Yup, I'll need one set of these with the tool.
It would have been two but I already bought a set of "brand E" about 8 weeks ago. From the looks of it, this is a great value, and I could have saved a decent chunk of money. Oh well.
Mikey914
post Nov 30 2017, 12:04 PM
The rubber man
QUOTE(BeatNavy @ Nov 30 2017, 10:00 AM) *
What is their return policy? I'd pay you postage (IMG:style_emoticons/default/biggrin.gif)
GregAmy
post Nov 30 2017, 12:10 PM
Perfect timing. I'm in.
Also will go along with other winter projects, including the door/seal rebuilds kits (with all options), and how are you coming on the targa/top seals?
BeatNavy
post Nov 30 2017, 12:12 PM
QUOTE(Mikey914 @ Nov 30 2017, 01:04 PM) *
They probably wouldn't be thrilled that I've done a "partial install" (bushings are in the collars, but not on the arms). Otherwise I'd take you up on it (IMG:style_emoticons/default/biggrin.gif)
Mikey914
post Nov 30 2017, 12:16 PM
The rubber man
QUOTE(GregAmy @ Nov 30 2017, 10:10 AM) *
we are finishing up the tools on the lathe now. Will be able to start shipping in a few days (tools)
Also doing a set of GBs aimed at suspension so we will be able to combine to the extent possible. There is one more I need to list but need to run a few errands 1st.
MikeM
Fantastic price!!
Sadly, I also installed brand"E" last spring.
post Nov 30 2017, 12:33 PM
914-6 GT in waiting
I’ve been waiting on these. Thank you.
post Nov 30 2017, 12:38 PM
914-6 GT in waiting
QUOTE(Mikey914 @ Nov 30 2017, 12:54 PM) *
(IMG:style_emoticons/default/agree.gif) I just recently bought some threaded rod, nuts and washers to install some motorcycle headset cups and it was less than $10.
mb911
post Nov 30 2017, 01:16 PM
I am in but you knew that.
bbrock
post Nov 30 2017, 01:19 PM
I've also been waiting, so I'm in.
Mikey914
post Nov 30 2017, 02:28 PM
The rubber man
We've also marked our product so you will not get imposters
Chris914n6
post Nov 30 2017, 03:06 PM
Jackstands are my life.
These also fit the 911 arms right?
Are rear trailing arm bushings in the works?
CMONNETT
post Nov 30 2017, 03:51 PM
I'd be interested in one maybe two sets.
Thanks,
amfab
post Nov 30 2017, 03:57 PM
K i'm in
rmdinmd
post Nov 30 2017, 04:29 PM
in for a set. thx
JamesM
post Nov 30 2017, 04:59 PM
Id love to see a video to see how much of a PITA this is, but im in, with tools. two of my cars are on 45 year old rubber and the 3rd is on $500 worth of RSR parts so this seems like its worth a shot.
dlee6204
post Nov 30 2017, 06:34 PM
Howdy
I'm in
bigkensteele
post Nov 30 2017, 07:59 PM
Major Member
An early set of the bushings somehow landed in my mailbox, and the quality is first-rate. Compared to the poly bushings I was about to use, they are a no-brainer.
I still need to get my A-arms powder coated, but as soon as that is done, these are going on!
4 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 16th April 2024 - 05:46 AM
