Delete please, Thanks |
jt914 |
Dec 1 2017, 09:02 PM
I love my914 Group: Members Posts: 26 Joined: 20-March 14 From: Pinon Hills, CA Member No.: 17,141 Region Association: Southern California |
Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks
jason Here is some of it: Front Brake calipers $40 Brake Pistons $5each Brake Hardware $1 and up Master Cylinders $25 Proportioning Valve $25 Hard Brake Lines $5ea Brake Dust Shields$5ea Rear Valance$100 Rear Bumper Core$50 Dog Bones$1ea Fiberglass Rocker panel pair$50 Hella Tail Light Lens pair$100 Hella Side Marker assembly and lens$25ea Tail Light Plastic Nuts$FREE Headlights$10 Headlight Motors$20 Turn Signal Buckets$20 Fuel Injection ECU $50 FI Harnesses$50 1.7 205F Distributors$50 Trigger Points$50 Relay Boards, Covers, Hold-Down Bolts$5-20 Relays $3ea Fuel Pressure Regulators$30 Deceleration Valves$20 Fuel Rails$2ea Voltage Regulators$10ea 1.7 Djet Injection Parts from 1973 Fuel Pressure Sender Connectors and harness parts Coils$10ea 2.0 Manifold$25 Distributor Drive Gears$25 Rear Trunk Lock$25 Rear Trunk Latch and Plunger$25 Inner Door Lock Mechanism $20 Striker Plates$10pr New Front Trunk Weatherstrip Seal $40 Engine Lid Welting Front Targa Latches $25 Window Roller Assembly $25 Front Cowl Seals $5 Dash Skeleton$50 Steering Column$25 Heater Parts Dash Fresh Air Controls$25 Glove Boxes, Doors$10ea Glove box Lock$15 Window Crank Handles$3 Vents$10 Triangle side window glass$10 Rear window$25 Coat Hooks$10 Front Trunk Release Handle and Lock$15 Pedal Clusters$50 Pedal Cluster Parts Pedal Boards$10 1.7 shortblock has not been split open w crank, cam, rods$200 Cranks 1.7 $50 Connecting Rods 1.7 $50set Rocker Arm Assembly 2.0 $100 Oil Coolers$10 Pushrods and Tubes$2 1.7 Heat Exchangers blasted and painted$100 1.7 Heads $100 2.0 Head 75-76 needs repair $40 Valve Covers and Bales $30 Driver seat$60 Seat Tracks$25ea Center pad and plastic tray $15 Fuel Combo Gauge Silver Dot$30 Gauge Bezels Metal $20 or Plastic$10 914 A-arms$80 Front Struts and Spindles$50 . And so I don't break any more rules, I wish to be paid in cash. Or paypal if parts need shipped. plus actual shipping and packaging if needed. |
burton73 |
Dec 2 2017, 12:03 AM
burton73 Group: Members Posts: 3,457 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Seems like the High Desert of So. CA has a number of guys with 914 stashes! While it never rains in Southern CA it snows in the High Desert. I lived there between 88-96 in the Victor Valley
What do you have and how much do you want. That is in our seller rules. Saves time for byers. It will help you too. I want a good battery tray bracket like new one I just missed out today. You got one? Early Chrome bumper? H piece for passenger floor in 70-71 cars Bob B (IMG:style_emoticons/default/welcome.png) |
jt914 |
Dec 2 2017, 02:04 AM
Seems like the High Desert of So. CA has a number of guys with 914 stashes! While it never rains in Southern CA it snows in the High Desert. I lived there between 88-96 in the Victor Valley What do you have and how much do you want. That is in our seller rules. Saves time for byers. It will help you too. I want a good battery tray bracket like new one I just missed out today. You got one? Early Chrome bumper? H piece for passenger floor in 70-71 cars Bob B (IMG:style_emoticons/default/welcome.png) I have hundreds of parts and I want very little. None of what you are looking for unfortunately. |
tsvo |
Dec 2 2017, 08:08 AM
Member Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest |
Pm sent
jt914 |
Dec 2 2017, 10:08 AM
Thanks everyone. I've responded to all PMs.
Morph914 |
Dec 3 2017, 06:56 PM
Member Group: Members Posts: 435 Joined: 22-August 16 From: St Augustine, FL Member No.: 20,326 Region Association: South East States |
Pm sent
H2OSB |
Dec 3 2017, 07:34 PM
I'm new here ... Group: Members Posts: 0 Joined: 5-February 16 From: Modesto, CA Member No.: 19,639 Region Association: None |
PM sent
type47fan |
Dec 4 2017, 12:46 AM
It Looks Better In Person. . . Group: Members Posts: 860 Joined: 17-September 03 From: Carlsbad, CA Member No.: 1,170 Region Association: Southern California |
PM sent |
TonyA |
Dec 5 2017, 11:20 AM
Nachmal Group: Members Posts: 454 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States |
Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks jason Here is some of it: Front Brake calipers $40 Brake Pistons $5each Brake Hardware $1 and up Master Cylinders $25 Proportioning Valve $25 Hard Brake Lines $5ea Lug Nuts$2ea Brake Dust Shields$5ea Rear Valance$100 Rear Bumper Core$50 Dog Bones$1ea Green Dot Jack$75 Fiberglass Rocker panel pair$50 Hella Tail Light Lens pair$100 Hella Side Marker assembly and lens$25ea Tail Light Plastic Nuts$1 License Plate Lights$20 Fog Lights and lenses$50 Headlights$10 Headlight Motors$20 Turn Signal Buckets$20 Fuel Injection MPS$50 Fuel Injection ECU$50 FI Harnesses$50 1.7 205F Distributors$50 Trigger Points$50 Relay Boards, Covers, Hold-Down Bolts$5-20 Relays $1ea Fuel Pressure Regulators$30 Deceleration Valves$20 Aux Air Regulators Fuel Rails$2ea Voltage Regulators$10ea 1.7 Complete Djet Injection System from 1973$150 Fuel Pressure Sender Connectors and harness parts Coils$10ea 2.0 Manifold$25 Distributor Drive Gears$25 Exterior Door Handle Pair Driver Quality$75 Rear Trunk Lock$25 Rear Trunk Latch and Plunger$25 Inner Door Lock Mechanism $20 Striker Plates$10pr New Front Trunk Weatherstrip Seal $40 Engine Lid Welting Front Targa Latches $25 Window Roller Assembly $25 Front Cowl Seals $5 Dash Skeleton$50 Steering Column$25 Heater Parts Dash Fresh Air Controls$25 Glove Boxes, Doors$10ea Glove box Lock$15 Window Crank Handles$3 Vents$10 Triangle side window glass$10 Rear window$25 Coat Hooks$10 Front Trunk Release Handle and Lock$15 Pedal Clusters$50 Pedal Cluster Parts Pedal Boards$10 1.7 shortblock has not been split open w crank, cam, rods$200 Cranks 1.7 $50 Connecting Rods 1.7 $50set Rocker Arm Assembly 2.0 $100 Oil Coolers$10 Pushrods and Tubes$2 1.7 Heat Exchangers blasted and painted$100 Heat Valve Flappers $20 1.7 Heads $100 2.0 Head 75-76 needs repair $40 Valve Covers and Bales $30 Shifter Sideshift$50 Shifter Tailshift$50 2.0 Bursch Exhaust$75 Driver seat$60 Seat Tracks$25ea Center pad and plastic tray $15 Tachometer Silver Dot$50 Fuel Combo Gauge Silver Dot$30 Gauge Bezels Metal $20 or Plastic$10 911 Front Underbody sway bar and A-arms$150 914 A-arms$80 Front Struts and Spindles$50 . And so I don't break any more rules, I wish to be paid in cash. Or paypal if parts need shipped. plus actual shipping and packaging if needed. |
rgolia |
Dec 5 2017, 04:55 PM
GeoJoe Group: Members Posts: 702 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
PM sent
HIPPIEKILLER |
Dec 6 2017, 02:13 AM
Member Group: Members Posts: 84 Joined: 25-July 17 From: Huntington Beach, CA Member No.: 21,286 Region Association: Southern California |
I'll take this.
Please let me know the year of such parts and payment details. Thanks! 911 Front Underbody sway bar and A-arms$150 Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks jason [...] |
jt914 |
Dec 6 2017, 07:32 PM
I'll take this. Please let me know the year of such parts and payment details. Thanks! 911 Front Underbody sway bar and A-arms$150 Hi guys, I have a lot of 914 parts that need to go. i have all sorts of stuff from all over the cars. If there is anything you need let me know and i'll let you know if i have. prices can't be beat and the more you buy the better the deals. thanks jason [...] Hi there, PM sent to you and I think everyone else who messaged me. thanks guys. |
FL000 |
Dec 9 2017, 07:53 PM
Member Group: Members Posts: 386 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
PM sent
jesse7flying |
Dec 10 2017, 10:52 AM
Member Group: Members Posts: 133 Joined: 9-August 16 From: Burleson,TX Member No.: 20,281 Region Association: None |
PM sent.
Kurbis |
Dec 15 2017, 12:57 PM
Newbie Group: Members Posts: 5 Joined: 6-October 17 From: Pittsfield NH Member No.: 21,490 Region Association: North East States |
If the brake dust shields are from early model and they are rears and if you have two I'll take 'em.
jt914 |
Dec 15 2017, 01:24 PM
Retroracer |
Dec 15 2017, 02:40 PM
Senior Member Group: Members Posts: 606 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Do you have any interior mirrors? My car needs one but I baulk at coughing up $200 for a used on e-bay... marked / scuffing OK but not cracked....
- Tony |
jt914 |
Dec 15 2017, 08:26 PM
Ed_Turbo |
Dec 17 2017, 03:12 PM
Member Group: Members Posts: 440 Joined: 5-June 17 From: Hacienda Heights, Ca. Member No.: 21,151 Region Association: Southern California |
I am looking for these:
- H-frame for license plate - Glove box door - Lugs For late model 914-4. |
jt914 |
Dec 17 2017, 11:31 PM
Lo-Fi Version | Time is now: 28th March 2024 - 07:45 AM |
