Removing CV Roll Pins |
Olympic 914 |
Jan 12 2018, 01:22 PM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
When I pulled the axles the roll pins stayed in the stub axles. they are blind holes so I can't push them out from the back and grabbing them with vice grips and prying has not budged them.
I am sure this has happened to others, What did you do? I guess drilling them would be an option, but wondered if there was another way. |
Jan 12 2018, 01:31 PM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Heat
iankarr |
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I used a drill chuck. needs to be one with a key though. Just put the pin in the chuck and turn the key to tighten. it should compress the roll pin enough to remove it. Installation is the reverse...
Mueller |
Jan 12 2018, 02:28 PM
I used a drill chuck. needs to be one with a key though. Just put the pin in the chuck and turn the key to tighten. it should compress the roll pin enough to remove it. Installation is the reverse... Ditto on the drill chuck, can also use this method to remove dowel pins sometimes. |
GeorgeRud |
Jan 12 2018, 02:30 PM
Can you just leave them for when you’re reassembling the axles?
johnhora |
Jan 12 2018, 02:56 PM
Senior Member Group: Members Posts: 866 Joined: 7-January 03 From: Derby City KY Member No.: 107 Region Association: None |
Can you just leave them for when you’re reassembling the axles? (IMG:style_emoticons/default/agree.gif) Why do you want to remove them? |
Bartlett 914 |
Jan 12 2018, 03:10 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
Can you just leave them for when you’re reassembling the axles? (IMG:style_emoticons/default/agree.gif) Why do you want to remove them? His look to be in pretty good condition. If a cv has ever come loose, it is a good idea to make a cleanup cut in a lathe. When a CV comes loose, this surface will no longer be perfectly flat. You will find the surface near the holes to be a tad high. If this is the case, the CV will not stay tight! |
rgalla9146 |
Jan 12 2018, 04:51 PM
Can you just leave them for when you’re reassembling the axles? (IMG:style_emoticons/default/agree.gif) Why do you want to remove them? His look to be in pretty good condition. If a cv has ever come loose, it is a good idea to make a cleanup cut in a lathe. When a CV comes loose, this surface will no longer be perfectly flat. You will find the surface near the holes to be a tad high. If this is the case, the CV will not stay tight! Excellent tip. |
mgphoto |
Jan 12 2018, 06:08 PM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
If you need to remove them, squeeze with vice grips, try not to deform them for reuse, tap against the vice grips to pull out the roll pins.
914Sixer |
Jan 12 2018, 06:37 PM
914 Guru Group: Members Posts: 8,869 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Squeeze them in a vice and pull up. Quick and easy.
Olympic 914 |
Jan 12 2018, 06:56 PM
Can you just leave them for when you’re reassembling the axles? (IMG:style_emoticons/default/agree.gif) Why do you want to remove them? I am installing new factory axle sets and they already have the roll pins installed. ( cuddyk did a nice unboxing video of these ) Have tried clamping vice grips and using a small pry bar. will try tapping on the vice grips with a hammer. Also the drill chuck thing might be a good idea. I could use the drill press to pull them out. |
Olympic 914 |
Jan 13 2018, 05:36 PM
Drill chuck method did not work for me, Applied some heat and tried clamping with vice grips and tapping with hammer. after no progress I decided to try drilling them.
Major Fail.... these pins are hard.. Even with cutting foam I still had sparks flying , until I had a busted of piece of drill bit inside the hardened spring steel roll pins. Applied some more heat and went back to the vice grip method. I had measured the height to tell if it was moving, and once I got it to move a little it came out fine. did the same with the other side, minus the busted drill bit part. |
Jan 13 2018, 06:28 PM
I should have said Lots of heat. Glad it worked.
Can’t tell you how much we use the map gas wrench around the shop. |
Lo-Fi Version | Time is now: 24th April 2024 - 12:54 PM |
