Best Suspension Setup, For a good handling street car |
Justinp71 |
Feb 8 2018, 10:33 AM
Senior Member Group: Members Posts: 1,582 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
So since a lot of us on here are trying to achieve a well handling street car, that still absorbs bumps. I figure it would be good to share suspension setup's. I will go first-
Front- 18mm torsion bars (stock 914) 19mm sway bar, set to second hole out Bilsteins (sport) Stock Bushings 205/50/15 tires Rear- 200 lb springs w/coil-overs (3.2l motor) no sway bar Bilsteins (sport) 225/45/15 tires I do have a six, so my spring rates in the rear need to be a little higher. This combo for me seems to work really well for a street car with occasional track use. It could benefit from maybe 19 or 20mm front torsion bars. Btw this combo feels "softer" than my GTi, yet it still handles well on the track (for occasional HPDE use). Interesting I have heard if you order Koni's you can get them made for a 914 (since it is different weight than a 911). What works for you guys? |
defianty |
Feb 8 2018, 11:48 AM
Senior Member Group: Members Posts: 659 Joined: 9-August 06 From: Essex, UK Member No.: 6,621 Region Association: None |
I can't comment on the ride yet as the car isn't built yet, but this is what I have already purchased for the car. My decisions were based on research and advice from a friend who raced a 914.
Front- 21mm Torsion bars 19mm Sway bar Bilstein Sport Shocks Stock Bushings Rear- 200 lb Springs adjustable coil-overs (3.0l motor) 16mm Sway bar - (Will decide whether to keep after testing) Bilstein Sport Shocks |
914_teener |
Feb 8 2018, 11:58 AM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
So since a lot of us on here are trying to achieve a well handling street car, that still absorbs bumps. I figure it would be good to share suspension setup's. I will go first- Front- 18mm torsion bars (stock 914) 19mm sway bar, set to second hole out Bilsteins (sport) Stock Bushings 205/50/15 tires Rear- 200 lb springs w/coil-overs (3.2l motor) no sway bar Bilsteins (sport) 225/45/15 tires I do have a six, so my spring rates in the rear need to be a little higher. This combo for me seems to work really well for a street car with occasional track use. It could benefit from maybe 19 or 20mm front torsion bars. Btw this combo feels "softer" than my GTi, yet it still handles well on the track (for occasional HPDE use). Interesting I have heard if you order Koni's you can get them made for a 914 (since it is different weight than a 911). What works for you guys? I have nearly the same as you except I run 140 spring rate in the rear and a stock sway bar in the front with adjustable droplinks.....only a 4 banger. Car drives like it is on rails. Alignment is just as important as the setup BTW. Looks like you run a staggered setup which I don't. For the 3.2 probably need more meat in the back for sure for track. I would call my ride feel "firm" but responsive but not "twitchy". |
shoguneagle |
Feb 10 2018, 09:44 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
Front: 19mm Torsion Bars 911 stock
21mm Sway Bar aftermarket Koni Red Adjustable Shocks Elephant Racing Bronze/Brass suspension bushings with zeros 205/50-17 7 inch rims with BF Goodrich tires Rear: 16mm Stock Sway Bar Koni Red Adjustable Shocks with adjustable perches 150# springs Elephant Racing Suspension Bushings and pivot bolts with zeros 245/45-17 9 inch rims with BF Goodrich tires Engine: 1987 911 Carrera 3.2 with front oil cooler and origin heat exch- angers and heat system. Trans: Rebuilt 901 with shifting assembly for headers |
Larmo63 |
Feb 11 2018, 12:00 AM
Front:
'83 911SC Bilstein struts Bilstein heavy duty shocks turbo tie rods 22mm Sway Away torsion bars New Lemforder ball joints stock sway bar - new bushings Elephant rubber A arm bushings late 911 style aluminum cross bar Rear: Bilstein heavy duty shocks 2 1/4" 200# Eibach springs Rebel Racing height adjust collars stock 914 sway bar - new bushings Top of shock tie bar - custom piece(?) Delrin swing arm bushings 6 x 15 Fuchs deep six wheels all around Yokohama 205/60 x 15 My car handles firm, a bit harsh, but precise. Slot car handling. |
phillstek |
Feb 11 2018, 12:34 AM
Member Group: Members Posts: 350 Joined: 19-May 10 From: Byron Bay, Australia Member No.: 11,741 Region Association: None |
Front: Level 3 ER coilovers, raised spindles
ER adjustable camber plates Turbo tie rods De-cambered lemforder balljoints Stock sway bar Poly Bronze bushes ER A arm mounts 21mm wheel spacers Rear: 200lb springs Bilstein sport shocks Poly bronze bushes Zero dive under hard braking but solid upper mounts are clunky over lane markers. |
Justinp71 |
Feb 12 2018, 11:15 AM
Front: 19mm Torsion Bars 911 stock 21mm Sway Bar aftermarket Koni Red Adjustable Shocks Elephant Racing Bronze/Brass suspension bushings with zeros 205/50-17 7 inch rims with BF Goodrich tires Rear: 16mm Stock Sway Bar Koni Red Adjustable Shocks with adjustable perches 150# springs Elephant Racing Suspension Bushings and pivot bolts with zeros 245/45-17 9 inch rims with BF Goodrich tires Engine: 1987 911 Carrera 3.2 with front oil cooler and origin heat exch- angers and heat system. Trans: Rebuilt 901 with shifting assembly for headers Cool setup. I've heard good things about those elephant Bronze/Brass bushings. Can you elaborate more on how your car handles? Oversteer/understeer, firm, predictable, etc... |
bernbomb914 |
Feb 12 2018, 03:54 PM
one of the oldest Farts on this board Group: Benefactors Posts: 1,873 Joined: 29-December 02 From: Temecula, CA Member No.: 36 |
I have factory sway bars ft. and rear with adj. links 911 suspension ft. koni adj sport shocks all around 185 lb. rear spgs. 6" rear wheels. and have been told that it was the best handling 914 at willow spgs.
BK911 |
Feb 13 2018, 08:00 AM
Senior Member Group: Members Posts: 672 Joined: 19-February 04 From: Rocky Top, TN Member No.: 1,674 Region Association: None |
'72 1.7l
Bilstein front and rear shocks New front stock tbars, new stock rear springs Elephant rubber bushings all the way around New ball joints Turbo tie rods New wheel bearings No sway bars. 195.60.15 tires. Car handles perfect for what I use it for; driving to work. Although my drive is 75 mile round trip through east TN back roads. |
Andyrew |
Feb 13 2018, 10:00 AM
Front
245 40 17 300TW tires (21psi) 22mm T bars Koni reds set to 2/3rds 911 raised spindals Roller bearings instead of bushings Turbo tie rods Rear 285 35 18 200TW tires (18psi) 225lb springs Koni yellows set to 2/3rds Roller bearings instead of bushings Grip level is high (~1.15G max at the track, Avg ~ 1.05), Turn in is sluggish, Not confidence inspiring at speed. I have a front sway bar Im going to try, and I'll try some yellow konis up front and some tuning. Also probably try some stickier tires up front and some higher tire pressures. |
Justinp71 |
Feb 16 2018, 11:31 AM
Front 245 40 17 300TW tires (21psi) 22mm T bars Koni reds set to 2/3rds 911 raised spindals Roller bearings instead of bushings Turbo tie rods Rear 285 35 18 200TW tires (18psi) 225lb springs Koni yellows set to 2/3rds Roller bearings instead of bushings Grip level is high (~1.15G max at the track, Avg ~ 1.05), Turn in is sluggish, Not confidence inspiring at speed. I have a front sway bar Im going to try, and I'll try some yellow konis up front and some tuning. Also probably try some stickier tires up front and some higher tire pressures. Raised Spindles... Nice! Do you have a bump steer kit or did you have the arms moved on the struts? Which Struts do you have (Boge or Koni)? I bet a front sway bar will help alot, I was able to pull 1.2g's when we went to thunderhill and I only have 18mm front torsions. |
Andyrew |
Feb 16 2018, 12:19 PM
Front 245 40 17 300TW tires (21psi) 22mm T bars Koni reds set to 2/3rds 911 raised spindals Roller bearings instead of bushings Turbo tie rods Rear 285 35 18 200TW tires (18psi) 225lb springs Koni yellows set to 2/3rds Roller bearings instead of bushings Grip level is high (~1.15G max at the track, Avg ~ 1.05), Turn in is sluggish, Not confidence inspiring at speed. I have a front sway bar Im going to try, and I'll try some yellow konis up front and some tuning. Also probably try some stickier tires up front and some higher tire pressures. Raised Spindles... Nice! Do you have a bump steer kit or did you have the arms moved on the struts? Which Struts do you have (Boge or Koni)? I bet a front sway bar will help alot, I was able to pull 1.2g's when we went to thunderhill and I only have 18mm front torsions. Arms moved up on the struts and Koni's as mentioned above. Im pretty sure the lack of sway bars is a big portion of my problems on track. What PSI did you run your tires at at thill? |
Justinp71 |
Feb 16 2018, 12:27 PM
Front 245 40 17 300TW tires (21psi) 22mm T bars Koni reds set to 2/3rds 911 raised spindals Roller bearings instead of bushings Turbo tie rods Rear 285 35 18 200TW tires (18psi) 225lb springs Koni yellows set to 2/3rds Roller bearings instead of bushings Grip level is high (~1.15G max at the track, Avg ~ 1.05), Turn in is sluggish, Not confidence inspiring at speed. I have a front sway bar Im going to try, and I'll try some yellow konis up front and some tuning. Also probably try some stickier tires up front and some higher tire pressures. Raised Spindles... Nice! Do you have a bump steer kit or did you have the arms moved on the struts? Which Struts do you have (Boge or Koni)? I bet a front sway bar will help alot, I was able to pull 1.2g's when we went to thunderhill and I only have 18mm front torsions. Arms moved up on the struts and Koni's as mentioned above. Im pretty sure the lack of sway bars is a big portion of my problems on track. What PSI did you run your tires at at thill? 29-30PSI, I was letting some air out as it warmed up. Ya I saw you have Koni Inserts, but I meant the strut body, it doesn't really matter. The Boge housings you can install Bilsteins or Koni's, but the Konis you can only install Koni inserts, but I hear they are a little stronger. I was bouncing back and forth on what I wanted, but I'm installing 3.5" boge struts now. |
Lo-Fi Version | Time is now: 20th April 2024 - 04:49 AM |
