RockAuto.com and Standard Motor Products, Ignition Conversion Kits |
914sgofast2 |
Feb 12 2018, 12:11 PM
Senior Member Group: Members Posts: 613 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
I just bought an Ignition Conversion Kit for my 1970 Porsche 914 from RockAuto.com because the old Pertronix unit had failed. Not wanting to buy another Pertronix unit, I found a kit supposedly made by Standard Motor Products [ignition conversion kit #LX-811] on RockAuto.com for $173.75. When I got it, I discovered that it was just a Pertronix kit that had been re-boxed by Standard Motor Products and was being sold at an elevated price. The exact same Pertronix kit can be bought from FCPEuro for $110.89 (with a lifetime warranty), from AutoHausAS.com for $11.24, and from PelicanParts.com for $117.75. Be carefull when buying from RockAuto and Standrd Motor Products. This was very disappointing. I have bought many parts from ROckAuto in the past for my Porsche 914 and other vehicles, and have always thought it was being sold for a reasonable price. But this time I feel like I was ripped-off big time by RockAuto for $50 to $60.
914Sixer |
Feb 12 2018, 01:48 PM
914 Guru Group: Members Posts: 8,869 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
RockAuto screwed me on some injectors that where supposed to to 914 2.0 injectors. They turned out to be Standard Products too. They would NOT take them back because the CATALOGUE said they were correct.
gothspeed |
Feb 12 2018, 02:09 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
DRPHIL914 |
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
get the hot spark module - or by one of my distributors I have in F/S section both have brand new never run HotSPark modules. My current module is still going strong after almost 8 years.
Bartlett 914 |
Feb 12 2018, 02:31 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
get the hot spark module - or by one of my distributors I have in F/S section both have brand new never run HotSPark modules. My current module is still going strong after almost 8 years. Sorry for the hijack The Pertronix unit had a problem of burning up if the ignition was left on without the car running. Does your units still have this issue? |
Chris914n6 |
Feb 12 2018, 04:49 PM
Jackstands are my life. Group: Members Posts: 3,304 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
I've returned stuff to RA, just had to pay shipping of 5-7$, and a bunch mouse clicks.
RA buys a lot of their parts outside normal distribution, thus the really cheap prices sometimes. There could be mistakes involved. For me, they replaced a window regulator that had been dropped and broke the plastic elbow, with expedited shipping. They covered the warranty on a fuel pump gone bad. I actually a day away from placing another order for some stuff for the neighbors car. $30 shipped beats Autozones $130 for a basic motor mount. |
malcolm2 |
Feb 12 2018, 04:59 PM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
get the hot spark module - or by one of my distributors I have in F/S section both have brand new never run HotSPark modules. My current module is still going strong after almost 8 years. Sorry for the hijack The Pertronix unit had a problem of burning up if the ignition was left on without the car running. Does your units still have this issue? Hot Spark has been know to fail that way also.... don't know about the burning up part, but the module will stop working. Check some of my posts about Hot Spark, search "hiccup". My HS also failed. It ran for over 20K miles, IIRC. I found out the HS does not want more than 13.7 volts running thru. I have now connected a ballast resistor. It has pulled my input voltage to the HS down to close to 13.7. I keep a spare module in the car for WHEN it does finally die. |
malcolm2 |
Feb 12 2018, 05:04 PM
RockAuto screwed me on some injectors that where supposed to to 914 2.0 injectors. They turned out to be Standard Products too. They would NOT take them back because the CATALOGUE said they were correct. Does Rock Auto have a "review" section? I had an issue with The Bird. But they have a review on each item, so I reamed them about selling a part that they know does not work. Caveat Emptor.... It is my own fault. Some dude had the same problem more than a year ago and he also gave a bad review, wish I had read it. (IMG:style_emoticons/default/bootyshake.gif) Live and learn. So don't buy a turn signal relay from The Bird. Get one from SPOKE. His works and is even cheaper. (IMG:style_emoticons/default/aktion035.gif) |
Front yard mechanic |
Feb 12 2018, 08:29 PM
Senior Member Group: Members Posts: 1,154 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Don't buy anything from rock auto (IMG:style_emoticons/default/sheeplove.gif)
bdstone914 |
Feb 12 2018, 09:48 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
The last company I worked for had SMP as the parent company. They do not make much themselves. Toured the dungeon in Long island where they make distributor caps. They make them different colors out of the same molds and call some of the premium caps and sell at a higher price. Not a fan.
914werke |
Feb 12 2018, 10:52 PM
"I got blisters on me fingers" Group: Members Posts: 9,998 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
UGH! Search on Pertronix +Failure ....
read until your eyes bleed. Yes that failure CAN occur if the key is left on AND the PU & trigger wheel happen to be in alignment. OR you simply wire it backwards ..... Otherwise one of the most simple, RELIABLE and effective updates you can do to an otherwise stock car. Installed on EVERY 914 ive owned (MANY!) Had only one ever fail, ............................. I WIRED IT BACKWARDS! |
Feb 13 2018, 08:32 AM
I just bought an Ignition Conversion Kit for my 1970 Porsche 914 from RockAuto.com because the old Pertronix unit had failed. Not wanting to buy another Pertronix unit, I found a kit supposedly made by Standard Motor Products [ignition conversion kit #LX-811] on RockAuto.com for $173.75. When I got it, I discovered that it was just a Pertronix kit that had been re-boxed by Standard Motor Products and was being sold at an elevated price. The exact same Pertronix kit can be bought from FCPEuro for $110.89 (with a lifetime warranty), from AutoHausAS.com for $11.24, and from PelicanParts.com for $117.75. Be carefull when buying from RockAuto and Standrd Motor Products. This was very disappointing. I have bought many parts from ROckAuto in the past for my Porsche 914 and other vehicles, and have always thought it was being sold for a reasonable price. But this time I feel like I was ripped-off big time by RockAuto for $50 to $60. What Petronix unit were you looking for the 1-2 or 3 their web site catalog is not real clear which type is best for us 1874v? About 65.00 bucks |
Spoke |
Feb 14 2018, 07:13 AM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
UGH! Search on Pertronix +Failure .... read until your eyes bleed. Yes that failure CAN occur if the key is left on AND the PU & trigger wheel happen to be in alignment. OR you simply wire it backwards ..... Otherwise one of the most simple, RELIABLE and effective updates you can do to an otherwise stock car. Installed on EVERY 914 ive owned (MANY!) Had only one ever fail, ............................. I WIRED IT BACKWARDS! (IMG:style_emoticons/default/agree.gif) Never had a Pertronix fail in 10 years. Just don't leave the key on with engine not running. Similar issue can happen with standard points if the points are closed, key on and engine not running. |
worn |
Feb 14 2018, 12:34 PM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
UGH! Search on Pertronix +Failure .... read until your eyes bleed. Yes that failure CAN occur if the key is left on AND the PU & trigger wheel happen to be in alignment. OR you simply wire it backwards ..... Otherwise one of the most simple, RELIABLE and effective updates you can do to an otherwise stock car. Installed on EVERY 914 ive owned (MANY!) Had only one ever fail, ............................. I WIRED IT BACKWARDS! You would think they would simply add a diode or something... |
rhodyguy |
Feb 14 2018, 12:53 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Does Rockauto stock parts? I was under the impression it is a 3rd party vendor. I bought a wheel thru them that did not match the picture on the site. Opened the box and it was not close. Calling RA I was asked why I bothered them. Turns out the wheel came out of a dismantler in Michigan. Big hassle began and calls not being returned. Contacted the CC co and they credited my account. Then people wanted to talk to me. I was not kind and told the outfit in MI if they wanted their wheel back they had to cover shipping. They balked. 'Fine. In 5 biz days I will set it off of my property and not be responsible for it. You'll be out the wheel and the money'. 2 days later FedEx knocked on my door.
914sgofast2 |
Feb 14 2018, 05:17 PM
My complaint was with RockAuto and Standard Motor Products selling a deceitful ignition kit as being actually made by STP, when in reality it was only a Pertronix kit re-boxed by STP with the price increased by $50 to $60 over what I could have bought a Pertronix kit for from a bunch of other vendors (like Pelican, FCPEuro and Autohaus AZ). I did not want to buy another Pertroinx kit, especialy at an exhorbitant price! I know that RockAuto is simply a drop shipper of autoparts being stocked by other parts jobbers/distributors, who have contracted to sell things on the RockAuto website. And no, I did not leave the ignition switched on which resulted in a burned out Pertronix ignition unit.
Mikey914 |
Feb 14 2018, 06:39 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The moral of the story is stick with reputable vendors who know our cars. God only know what youll get, but at least it wasn't a brand U part.
TheCabinetmaker |
Feb 14 2018, 09:40 PM
Why would anyone buy a part for a 914 from rock auto?
Feb 14 2018, 09:51 PM
914-6 GT in waiting Group: Members Posts: 19,237 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Why would anyone buy a part for a 914 from rock auto? (IMG:style_emoticons/default/agree.gif) If all you are doing is buying on price, you aren't going to get a good buying experience all the time. There is no passion behind the sale, just dollars. |
Mike D. |
Feb 15 2018, 12:27 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
After my Pertronix failed, I got a Compufire. At the time it was about half the cost and it has worked perfectly for years. In fact, this one Compufire is on it's 3rd engine.
$82 on JEGS... (EDIT: HA! Just looked and Compufire is now owned by Pertronix... ) |
Lo-Fi Version | Time is now: 24th April 2024 - 06:05 PM |
