My 7mm Caliper bolt solution |
n2j2ryan |
Feb 12 2018, 10:14 PM
Member Group: Members Posts: 85 Joined: 9-January 17 From: Victoria BC Member No.: 20,740 Region Association: Canada |
After many suggestions and a visit to a machine shop, I decided with this solution. I tapped out one end from the 7mm hole to a an 8mm thread. The other end I just bored out to 8mm. It now takes an 8mm socket head bolt, without a nut, just like the later callipers. Total cost of all bolts $12, instead of the $16 per bolt plus delivery from the UK.
914Sixer |
Feb 12 2018, 10:37 PM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Looks like a working solution to me.
Valy |
Feb 13 2018, 08:43 AM
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
GeorgeRud |
Feb 13 2018, 10:40 AM
Makes you wonder why Ate chose such a strange bolt initially when producing these. Eric?
Feb 13 2018, 11:19 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
oldie914 |
Feb 13 2018, 12:11 PM
Member Group: Members Posts: 102 Joined: 2-May 10 From: Germany Member No.: 11,680 Region Association: None |
I think Ate used the odd bolt size to keep somebody from rebuilding the calipers with the wrong (low strength) bolts. 7mm is a very strange bolt size and was probably only available from Ate. I am sure they would not sell them to everybody back then.
The calipers on my 1997 Mercedes are attached with bolts with 18mm heads. I think it has the same purpose. |
gothspeed |
Feb 13 2018, 02:37 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
This makes a lot of sense as the 7mm bolt holes are on the sloppy side. If you ream the holes to barely accommodate 8mm bolts, the assembly will be plenty strong. (IMG:style_emoticons/default/smile.gif)
cwpeden |
Feb 14 2018, 11:38 AM
Hi, I'm in Victoria too. Sorry I didn't see this sooner.
If you need any 914 help call or send me a text. I have one of the local parts hoards....including brake caliper bolts. (IMG:style_emoticons/default/sad.gif) two5zero 8eight6 9one44 |
Feb 15 2018, 01:20 PM
914 Idiot Group: Members Posts: 14,974 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
austriafisch0 |
Feb 18 2018, 08:46 AM
Newbie Group: Members Posts: 1 Joined: 24-January 12 From: Austria Member No.: 14,047 Region Association: Europe |
Hi,
can give me somebody the specification, I will arrange a run of 1000pcs (IMG:style_emoticons/default/first.gif) java script:emoticon(':first:','smid_29') |
Lo-Fi Version | Time is now: 29th March 2024 - 01:48 AM |
