Rotor changes timing, 123 running fine, but? |
mgphoto |
Feb 18 2018, 12:17 AM
"If there is a mistake it will find me" Group: Members Posts: 1,335 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
So my engine has been really running fine except for a miss that seemed to come on at about 3200 rpms. I'm running the 123 D Jet version #B switch and no vacuum connection to the dizzy. I've pulled the timing back to 26* and I'm using regular gas with an MMT additive to control ping. This setup has been working very well as I've been testing different brands of the additive for effectiveness.
The miss I've attributed to cap, rotor and wires. I replaced the cap and rotor and before replacing the wires I took it for a spin. The miss seemed to be gone but the ping I had tuned out was back? I hadn't moved the dizzy, I tightened the clips holding the cap but no other change. So I pulled the cap and took out the rotor to see what might have changed. The new cap was identical to the one that came with the dizzy, but the rotor not so much. I suppose that could be a 2* difference in the rotor pickups? I put in a rev limiting 5850 rotor I had in my stash and now no miss and no ping! If there's an issue it will find me... |
Feb 18 2018, 06:40 AM
The rotor doesn't determine the timing. The reason that the end of the rotor is relatively wide (it looks to be about 20 degrees of arc) is because its only job is to get the spark from the center terminal on the cap to one of the outer terminals.
Something else is going on. --DD |
MarkV |
Feb 18 2018, 10:00 AM
The rotor doesn't determine the timing. The reason that the end of the rotor is relatively wide (it looks to be about 20 degrees of arc) is because its only job is to get the spark from the center terminal on the cap to one of the outer terminals. Something else is going on. --DD I guess I disagree....when you hook up a timing light the light flashes at the rotor passes the #1 terminal on the distributor cap. If you have a rotor with a wider tip it's going to change when the light flashes and change the timing. (IMG:style_emoticons/default/confused24.gif) |
mgphoto |
Feb 18 2018, 11:37 AM
The rotor doesn't determine the timing. The reason that the end of the rotor is relatively wide (it looks to be about 20 degrees of arc) is because its only job is to get the spark from the center terminal on the cap to one of the outer terminals. Something else is going on. --DD I guess I disagree....when you hook up a timing light the light flashes at the rotor passes the #1 terminal on the distributor cap. If you have a rotor with a wider tip it's going to change when the light flashes and change the timing. (IMG:style_emoticons/default/confused24.gif) Exactly. |
mgphoto |
Feb 18 2018, 11:42 AM
Additionally the contact point for the coil wire is not centered on the rotor.
I seem to remember these wide arc rotors used in beetle engines? |
Olympic 914 |
Feb 18 2018, 11:51 AM
Group: Members Posts: 1,662 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
The rotor doesn't determine the timing. The reason that the end of the rotor is relatively wide (it looks to be about 20 degrees of arc) is because its only job is to get the spark from the center terminal on the cap to one of the outer terminals. Something else is going on. --DD I guess I disagree....when you hook up a timing light the light flashes at the rotor passes the #1 terminal on the distributor cap. If you have a rotor with a wider tip it's going to change when the light flashes and change the timing. (IMG:style_emoticons/default/confused24.gif) WRONG... The light flashes when the points open, that's when the coil fires. the width of the contact on the rotor would only increase the possible range of advance or retard. the spark isn't triggered when the rotor passes the contact in the distributor. it fires when the points open, the position of the rotor only determines which plug fires because the current goes to the nearest one at the time. Dave is correct. |
MarkV |
Feb 18 2018, 12:49 PM
Okay I am game...
How exactly does the timing light know when the points open? My timing light and every other timing light I have ever seen is triggered by a lead going to a spark plug wire.... it flashes when there is energy in the wire. If the leading point of the rotor is wider then that changes the position inside the cap. The leading point inside the cap is going to send power down the plug wire sooner the light is going to flash sooner and the timing is going to be different..... probably advanced. The OP said it pinged with the new rotor so I would assume it pinged because the timing was too advanced with the new rotor. Edit: I see where you and Dave are coming from, the electricity in the wire happens because of the points opening. The difference here is that you have changed to position of where it fires inside the cap. Think of it this way....if you were able to rotate the cap independent of the distributor you would still change the timing which is essentially what is happening here. (IMG:style_emoticons/default/popcorn[1].gif) |
Rand |
Feb 18 2018, 01:05 PM
There's a difference between a "longer opportunity" for spark vs when the spark actually happens. The points opening (or electronic trigger) is the timing. That has to be precise.
clapeza |
Feb 18 2018, 01:34 PM
Member Group: Members Posts: 229 Joined: 7-February 11 From: South GA Member No.: 12,677 Region Association: South East States |
There's a difference between a "longer opportunity" for spark vs when the spark actually happens. The points opening (or electronic trigger) is the timing. That has to be precise. Exactly. It's the triggering inside the distributor that determines the firing. What happens inside the cap is trivial. There is no direct electrical contact closure inside the cap between the rotor tip and the spark plug wire connection on the rim, only the center pin of the cap and the center contact of the rotor. Try this: disconnect the spark plug wires from the cap and put your multitester leads in the center and one of the spark plug wire connectors on the distributor cap. Set for continuity. Now turn the engine manually and look for continuity. It won't happen. The reason you get spark to pass from the rotor tip to the cap leads is that the electrical charge jumps the gap between them. Remember, we're talking upwards of 50,000 volts here, plenty to jump a fraction of an inch. It jumps because the charge is looking for ground, which happens to be available via the spark plug wire to spark plug to head route. When you're setting the timing, you're doing very little inside the cap. It's what's happening inside the distributor - when you turn the body of the distributor, changing the relationship of the distributor drive gear to the firing point in the rotation. That firing point being under the control of when the points open or the electrical circuity says so, in the case of the 123Ign. |
Lo-Fi Version | Time is now: 24th April 2024 - 12:27 PM |
