Lift |
Lift |
Cracker |
Feb 18 2018, 09:39 AM
Advanced Member Group: Members Posts: 2,148 Joined: 2-February 10 From: Atlanta (area) Member No.: 11,316 Region Association: South East States |
Thoughts, experiences, frequency of use, etc. If you have pictures of your set-up in general; decisions you wish you had made; decisions you were thankful you DID make - all would be helpful! I have plenty of ceiling height; do I need to spend big bucks for infrequent use (mostly as a storage device)? The lift will need to be functional for teener engine drops...suffice to say, it has to be a two-post.
Tony |
jmitro |
Feb 18 2018, 09:56 AM
Senior Member Group: Members Posts: 713 Joined: 23-July 15 From: Oklahoma Member No.: 18,986 Region Association: None |
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath.
I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 Attached thumbnail(s) |
sithot |
Feb 18 2018, 10:23 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath. I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 May require approach boards/ramps. The Rotary I have screws down pretty tight but if a car is too low it does require assistance from the aforementioned. |
dcheek |
Feb 18 2018, 10:25 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
This subject has been covered many times in this forum. Most of the time people want a portable jacking system. They are more expensive and some only raise a couple of feet.
You are smart wanting a 2 post, especially for P cars and air cooled VW's. I have an Atlas brand lift from Greg Smith Equipment. It's the least expensive they have and also the the lowest clearance. My ceilings are 10 1/2 feet. I can lift the 914 and be able to walk under it (I'm 6'2"). Can't stand under a Beetle though. I paid $1445.00, no shipping, no sales tax because I picked it up at the Delaware warehouse. We actually picked up two lifts using a car trailer. It took 2 3/4 hours to install with the help of a couple of friends. The second one took about 2 hours. I hired an electrician to wire in 220 volts. The model is a BP 8000, 8000 lb. lift. I've had it for several years and have changed 2 clutches, 2 complete brake jobs and tie rods. I've made my money back already, plus it gives to extra car storage. Dave |
Unobtanium-inc |
Feb 18 2018, 10:26 AM
Advanced Member Group: Members Posts: 2,199 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None |
You can read about my lift saga here:
http://www.914world.com/bbs2/index.php?sho...370&hl=lift I will say this, decide what you want the lifts for, storage or car work. If it's storage get ones like mine, if it's car work, get the two post ones with moveable arms. Both do their job well, but don't work well for the other. Attached thumbnail(s) |
Feb 18 2018, 10:50 AM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath. I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 We often have to jack up a low car to slide the arm in and then use some spacers under the pad so it doesn't hit the rockers. |
Phoenix-MN |
Feb 18 2018, 11:00 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
Al Meredith |
Feb 18 2018, 11:02 AM
Senior Member Group: Members Posts: 958 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
Tony, I have a 4 poster . I didn't get it from Greg Smith but they have a store in Norcross. I like the 4 poster because it does not have to be secured to the deck and I think transmits less weight to each foot. I was not sure of the thickness of my floor. I use it mostly for storage but have done almost every kind of work on it. AL
Feb 18 2018, 11:05 AM
Thoughts, experiences, frequency of use, etc. If you have pictures of your set-up in general; decisions you wish you had made; decisions you were thankful you DID make - all would be helpful! I have plenty of ceiling height; do I need to spend big bucks for infrequent use (mostly as a storage device)? The lift will need to be functional for teener engine drops...suffice to say, it has to be a two-post. Tony Put it in a convenient spot with enough room around it to work on each side - if possible. pad the edges so when the door swings open, it wont matter. |
cary |
Feb 18 2018, 11:15 AM
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath. I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 We often have to jack up a low car to slide the arm in and then use some spacers under the pad so it doesn't hit the rockers. What Mark said. On both items. I have a box of 3*3 MDX pieces to use a spacers. I have a 10K Bend Pak Asymmetrical as a primary. We're planning on a 7k and 2 4 posts in the next upgrade. |
Cracker |
Feb 18 2018, 11:31 AM
Guys: I also would like to lift my 8500 lb truck as well. Sorry for the omission. So I would like to lift a Sportsracer to a one-ton Ram...
Jamie |
Feb 18 2018, 11:44 AM
Senior Member Group: Members Posts: 1,025 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I bought the Atlas 4 post from Greg Smith because the garage slab had a slight slope which made a 2 post unusable. Have to use a 10" high ramp to access the top level, but it has worked well for about 5 yrs. and the only problem is shuffling cars to get the right car up for maintenance! Lifts do make great storage multipliers for my 914 and Cayman.
Cracker |
Feb 18 2018, 12:17 PM
I realize this conclusion has many flaws but I am leaning toward a Rotary; cautiously looking at the Revolution (Chinese version) line; but would really like to have a MoHawk. If Rotary's are good enough for Goldcrest with +10 Cup cars on hand...they should cut the mustard for a teener. Now to find a reasonable deal...
Tony |
Feb 18 2018, 12:26 PM
My house had a 2 post installed when I bought it. Max height is around 5 1/2' so at 6' tall I can't quite stand up straight underneath. I really like having a lift but the biggest problem is that it is not low profile. I can't get the jacking arms low enough to fit under my 996 We often have to jack up a low car to slide the arm in and then use some spacers under the pad so it doesn't hit the rockers. What Mark said. On both items. I have a box of 3*3 MDX pieces to use a spacers. I have a 10K Bend Pak Asymmetrical as a primary. We're planning on a 7k and 2 4 posts in the next upgrade. by spacers, i meant the metal donuts that come with the lift that lift the pad higher than the arm. |
Triaddave |
Feb 18 2018, 12:30 PM
Member Group: Members Posts: 244 Joined: 31-December 03 From: olympia,wa Member No.: 1,478 |
MikeM |
Feb 18 2018, 12:41 PM
Senior Member Group: Members Posts: 558 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
This subject has been covered many times in this forum. Most of the time people want a portable jacking system. They are more expensive and some only raise a couple of feet. You are smart wanting a 2 post, especially for P cars and air cooled VW's. I have an Atlas brand lift from Greg Smith Equipment. It's the least expensive they have and also the the lowest clearance. My ceilings are 10 1/2 feet. I can lift the 914 and be able to walk under it (I'm 6'2"). Can't stand under a Beetle though. I paid $1445.00, no shipping, no sales tax because I picked it up at the Delaware warehouse. We actually picked up two lifts using a car trailer. It took 2 3/4 hours to install with the help of a couple of friends. The second one took about 2 hours. I hired an electrician to wire in 220 volts. The model is a BP 8000, 8000 lb. lift. I've had it for several years and have changed 2 clutches, 2 complete brake jobs and tie rods. I've made my money back already, plus it gives to extra car storage. Dave What are the concrete requirements for that lift? Thanks |
Triaddave |
Feb 18 2018, 12:42 PM
Also, take a look at"lift cable broke" on the next page. creepy
Bartlett 914 |
Feb 18 2018, 12:48 PM
Advanced Member Group: Members Posts: 2,214 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
You can do more using a 2 post. 4 post is better for storing a car. How would you do a brake job using a 4 post and all wheels are under load? I made the mistake of getting a lift with cables and a hose on the floor (it has a cover / ramp). This gets in the way a lot more than I like. Think moving a transmission jack from front to rear.
jmitro |
Feb 18 2018, 03:00 PM
Also, take a look at"lift cable broke" on the next page. creepy mine (and I'm sure most all well-made lifts) have a built-in fail safe ratchet-stop system. +1 to rolling chair under the car. I can actually squeeze my 914 and X5 (or 996) in the same garage with one car on the lift and one slightly underneath. It's not ideal for storage, but I don't plan to "store" any of my cars |
burton73 |
Feb 18 2018, 03:23 PM
burton73 Group: Members Posts: 3,486 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
You can do more using a 2 post. 4 post is better for storing a car. How would you do a brake job using a 4 post and all wheels are under load? I made the mistake of getting a lift with cables and a hose on the floor (it has a cover / ramp). This gets in the way a lot more than I like. Think moving a transmission jack from front to rear. You can buy a jack setup for 4 post lifts so you can remove the tires. One nice thing with a 4-post lift is the tray to catch oil if it drips. Not like our car ever drip. You see the custom cardboard drip stopper on the 2 post lifts someone did. I guess it works. Bob B |
Lo-Fi Version | Time is now: 20th April 2024 - 06:27 AM |
