Holley Carb on a 1.8, anyone got info on this setup |
Literati914 |
Mar 21 2018, 11:42 AM
Senior Member Group: Members Posts: 1,428 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
I have a 1.8L engine in a non-running '74 I got about a month ago, that has a single Holley carb mounted. It has an aluminum tag that reads "R9677" and "1943". Does anyone know anything about this setup? I've never heard of a Holley on a 914. Is it a reasonable carb for a stock 1.8? thx.
Chris H. |
Mar 21 2018, 12:07 PM
Senior Member Group: Members Posts: 4,027 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
That would be a progressive carb. Not part of any stock setup. Aftermarket cheap fix for someone who took the fuel injection off. It works, but really affects performance. I test drove a 914 with one and the power was WAY down.
Mblizzard |
Mar 21 2018, 12:11 PM
As I am sure you likely know. Many will say there is no "reasonable" single carb set up for the 914.
But the Holley R-9677 is a fairly middle of the road two barrel carb. Believe it is the same as the Holley 5200. Used on engines 2.8 L and larger so should be plenty for a 1.8. But with the single carb set up there will always be issues with good performance and such. If you got it non running you can almost be sure the carb needs a rebuild. Kits are $50-$60+ and a lot of time and experience. Hard not to go with reman one for a $150 to $200 if you are going to keep the carb set up. Going this route eliminates a lot of potential problems to run down when trying to get it started. |
porschetub |
Mar 21 2018, 01:51 PM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
IMO the Holley isn't up to the Weber and even that struggles with this setup,the T4 engine isn't suited to a single centre mount car due to the long manifold runners and lack of preheat to them.
If on a budget factor in the twin Weber ICT's or pick up a good used IDF dual throat set used in the classified section on here,they seem to come up fairly often. |
PlaysWithCars |
Mar 24 2018, 11:13 AM
Senior Member Group: Members Posts: 521 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Is that the same carb that was used on Type I VWs? Think it went by the marketing name of BugSpray. As I recall from my VW days, they were cold blooded as Porschetub noted due to lack of manifold heating and had a reputation for engine fires. I don't recall what the root cause of that was though. It might be worth doing some research to understand if its the same carb and why/if they were susceptible to engine fires.
jcd914 |
Mar 24 2018, 11:40 AM
I don't think the Bugspray carb was a progressive 2 barrel carb, I think it was a standard 2 barrel carb.
I had a 2 barrel carb on an old Baja bug and it never ran as well as the dual ICTs I had before the 2 bbl. I don't know if what I had was a Bugspray or not but it was supposed to be an upgrade from the ICTs, it wasn't. Jim |
rhodyguy |
Mar 24 2018, 01:25 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Usually a quick fix due to the mysteries of the Ljet fuel injection. With any luck the FI was tossed aside with internal engine parts remaining unchanged. The Ljet parts are readily available.
Lo-Fi Version | Time is now: 19th April 2024 - 01:08 PM |
