shifter restoration? |
doug_b_928 |
Apr 13 2018, 09:01 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
It's unseasonably cold here so no work on the car outside yet (IMG:style_emoticons/default/sad.gif). Figured maybe I'll work inside on the shifter this weekend. I didn't see a thread on restoring the shifter. Is this something that just requires a good cleaning, or should it be disassembled, cleaned, painted, and new grease added? Pics of mine below.
Apr 13 2018, 10:02 AM
In for a penny, in for a pound. I would take it all apart, clean it, check for excessive wear, paint or powder coat, reassemble, and grease.
The spring is under a lot of tension so wear leather gloves and eye protection for removal and install. When installing the spring, use Phillips head screwdriver in place of the pin. Work the spring in place using vise grips to hold it and then push the screwdriver out by placing the pin back in place. The spring is too hard to muscle in with out vise grips and the screwdriver makes it easier to hold until replaced with the pin. |
Dr Evil |
Apr 13 2018, 10:42 AM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Order new bushings as well that go under the spring plate.
doug_b_928 |
Apr 13 2018, 10:48 AM
Thanks, guys. Is anyone aware of a good thread on restoring this part? Eric’s thread was really helpful for the pedal cluster. Something like that out there somewhere?
rhodyguy |
Apr 13 2018, 11:10 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Put a vicegrip on a spring, remove the 4 circlips, push the 2 pins out and remove the springs. This method prevents the springs from flying across the garage. this is what the detention plate should look like. straight across the re-inforcing plate on the underside. as they wear, the center of the plate gets wallowed out and there usually is a gouge on the shift lever. adding the loss of material on the lever and a spent plate it is certainly is of no help setting the linkage.
The backing plate has slight bevel. Attached thumbnail(s) |
doug_b_928 |
Apr 13 2018, 04:13 PM
Thanks again guys for your encouragement and assistance. I'm surprised at how easy it actually was to get it apart. Knowing what I know now, it's definitely 'an in for a pound' item. The detention plate looks good as does everything else to my eyes. But I do have some questions:
The shifter bracket has a small kink (pictured below). It didn't impede anything. Is it supposed to be like that? As this is a 73 there is not a ball cup. But there is a shifter spacer sleeve. It's metal. Mine looks good with some, what appears to me to be, very minor wear. I don't have a replacement. Is it fine to reuse this one or should it be replaced as a matter of course? Here are some pics: Attached image(s) |
doug_b_928 |
Apr 13 2018, 04:26 PM
After looking more closely at Rhodyguy's post, I could see where I should be looking so I re-inspected mine and there is wear on the plate and corresponding marks on the shifter. So, I guess another question is how bad is this?
RickS |
Apr 13 2018, 04:35 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
You can certainly reuse the shifter sleeve. Be sure to lube it before reinstalling. I used white lithium grease.
doug_b_928 |
Apr 13 2018, 06:59 PM
So I see that the 'Reverse Lockout Plate' is still available new. How do we assess the wear above to determine whether it needs replacing?
I'll use White Lithium for the sleeve (thanks Rick), but what is the correct grease for the shifter? There was grease everywhere but I assume I just put some on the 'ball' area of the shifter where it sits in the shifter plate, correct? |
rhodyguy |
Apr 14 2018, 06:17 AM
What kind of condition were the 2 plastic bushings (Haynes. P 89. #s 15&17) in?. Your springs were pretty gunked up too. I've seen the wear point on the lever much worse. Replacing the plate is your call. While you're in there....
doug_b_928 |
Apr 14 2018, 06:24 AM
I’ll take some pics of the others and post in a bit.
doug_b_928 |
Apr 14 2018, 06:56 AM
The small springs cleaned up nicely (didn't get a pic). Here are the bushings. I didn't separate the big spring from the bushing because it looks to be very well seated within it.
Mikey914 |
Apr 14 2018, 07:29 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Hummm.......... I made the springs for the late, maybe I should look at making a kit??? Both early and late.
rhodyguy |
Apr 14 2018, 07:33 AM
Yes.
doug_b_928 |
Apr 14 2018, 07:56 AM
So what kind of grease is recommended and should it just be placed on the shifter ball area where it rides in the shifter plate?
bdstone914 |
Apr 14 2018, 08:16 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
So what kind of grease is recommended and should it just be placed on the shifter ball area where it rides in the shifter plate? White Lithium, CV grease, does not really matter. That shift plate is fine to use. Insoect the round pin inside of the housing that can be seen in the image looking in from the top. The early shifters swear that pin badly into a D shape. Cant really tell on yours if it is worn. |
doug_b_928 |
Apr 14 2018, 09:28 AM
The round pin looks perfect, so good news for a change that I don't have to buy any parts (IMG:style_emoticons/default/smile.gif).
rhodyguy |
Apr 14 2018, 09:36 AM
the reinforcing piece sits just shy of the leading edge of the plate on the one I posted. yours has worn beyond the leading edge and into the reinforcing piece.
porschetub |
Apr 15 2018, 04:52 PM
The round pin looks perfect, so good news for a change that I don't have to buy any parts (IMG:style_emoticons/default/smile.gif). Noticed that bushing spring looks a bit distorted,is it level when sitting on a flat surface,if not might pay to replace it. Yes the lookout plate can be bought new but is $77 anyone seen it cheaper genuine part anywhere ? Is there any benefit in replace the two main springs....Bruce do you know ?. doug b 928 thanks for this thread ,never had mine apart but plan to (IMG:style_emoticons/default/beer.gif) |
Apr 15 2018, 05:26 PM
Reuse the springs unless they are broken.
Lo-Fi Version | Time is now: 25th April 2024 - 03:13 PM |
