New AA 2.0 Heads by HAM are Done, Mine are on the way |
914Sixer |
Apr 17 2018, 12:21 PM
914 Guru Group: Members Posts: 8,867 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Just got shipping notice that my heads are on the way. (IMG:style_emoticons/default/pray.gif) They will be here Friday. Should have some pictures for the weekend.
nditiz1 |
Apr 17 2018, 12:27 PM
Senior Member Group: Members Posts: 1,177 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region |
Just got shipping notice that my heads are on the way. (IMG:style_emoticons/default/pray.gif) They will be here Friday. Should have some pictures for the weekend. Mine too, super excited! (IMG:style_emoticons/default/beerchug.gif) |
rgolia |
Apr 17 2018, 02:14 PM
GeoJoe Group: Members Posts: 704 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States |
I think mine are next up. Let me know how they look when you get them. Starting to get excited but still lots of work to do before the 914 hits the pavement.
Mueller |
Apr 18 2018, 07:25 PM
Congrats....I came pretty close to ordering a set , however the $ added up quickly since I have a 1.8 which I figured the cylinders would be too small so I'd have to invest (buy) 2.0 P/Cs and then buy a 2.0 crank w/rods.
nditiz1 |
Apr 19 2018, 07:44 PM
Here they are in all their glory, well worth the wait. Now, to get the motor back together and back in. Thanks Len!
(IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524188696.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524188696.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524188697.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524188697.4.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-18763-1524188697.5.jpg) |
gothspeed |
Apr 19 2018, 08:03 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Awesome!!! What size intake/exhaust valves are those?
914Sixer |
Apr 19 2018, 08:32 PM
Nick got his 1st. I just noticed there is not any studs in the head. Going to have to find new ones for the exhaust, intake and rockers. Going to have to check out Bel-Metric.
nditiz1 |
Apr 19 2018, 08:43 PM
Stock 2.0 valve size 42x36
Mark - Len included a stud kit and a block off for venting or a vent tube if you want to go that route. |
Apr 20 2018, 12:14 AM
I have a 1.8 which I figured the cylinders would be too small ... The 1.8 cylinders and the 2.0 cylinders have the same OD. The ID is only 1mm different, too. You could have used them, though I don't know how different the combustion chamber sizes are, which could have a huge effect on the compression ratio. And you'd have to deal with the intake and engine tin and such. --DD |
jcd914 |
Apr 20 2018, 12:52 AM
Per the factory spec book:
1.7 heads have 51.1cc to 52.6cc combustion chambers. 1.8 heads have 52cc to 53.5cc combustion chambers. 2.0 heads have 58.7cc to 60.2cc combustion chambers. So with a stock 1.8 bottom end and stock 2.0 heads, the compression would drop significantly. Jim |
914Sixer |
Apr 20 2018, 05:48 AM
Great the studs are there just not installed.
Apr 20 2018, 05:52 AM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
barefoot |
Apr 20 2018, 07:10 AM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Are the chambers ceramic coated ??
Looks great ! |
malcolm2 |
Apr 20 2018, 07:23 AM
Advanced Member Group: Members Posts: 2,738 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Congrats....I came pretty close to ordering a set , however the $ added up quickly since I have a 1.8 which I figured the cylinders would be too small so I'd have to invest (buy) 2.0 P/Cs and then buy a 2.0 crank w/rods. I started with a 1.8 and just upped the P/C to 96mm IIRC, kept the 66mm crank and 1.8 rods.... 1911cc with 2.0 heads. Or in my case the valves are 2.0 size. I like mine. Saved me alittle $. |
HAM Inc |
Apr 20 2018, 08:11 AM
Senior Member Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None |
I'm very pleased that everyone in the GB went with the ceramic coating. There is still much that's unknown about these Chinese castings, and with what we know about the more sturdy AMC castings and the benefits of ceramic in protecting them I feel it was imperative with the AAP's.
One thing to keep in mind about the ceramic coating, it's extremely chemical and heat resistant, but it is not at all abrasion resistant. It scratches and scuffs very easily, so be careful with sharp objects, and if you want it stay pretty don't touch it with oily fingers. It stains easily, though the stains do no harm. (IMG:style_emoticons/default/driving.gif) |
914work |
Apr 20 2018, 08:28 AM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
Congrats....I came pretty close to ordering a set , however the $ added up quickly since I have a 1.8 which I figured the cylinders would be too small so I'd have to invest (buy) 2.0 P/Cs and then buy a 2.0 crank w/rods. I started with a 1.8 and just upped the P/C to 96mm IIRC, kept the 66mm crank and 1.8 rods.... 1911cc with 2.0 heads. Or in my case the valves are 2.0 size. I like mine. Saved me alittle $. You'll like that combo match it with 2.0L exhaust !! (IMG:style_emoticons/default/aktion035.gif) |
914Sixer |
Apr 20 2018, 02:52 PM
Got mine this afternoon. Really nice. Thanks Len. (IMG:style_emoticons/default/beerchug.gif)
HAM Inc |
Apr 21 2018, 08:39 AM
You're welcome Mark. Hope everyone is happy with their heads. I expect the last of them back from the coater in the next week or so.
ClayPerrine |
Apr 21 2018, 11:13 AM
Life's been good to me so far..... Group: Admin Posts: 15,403 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Per the factory spec book: 1.7 heads have 51.1cc to 52.6cc combustion chambers. 1.8 heads have 52cc to 53.5cc combustion chambers. 2.0 heads have 58.7cc to 60.2cc combustion chambers. So with a stock 1.8 bottom end and stock 2.0 heads, the compression would drop significantly. Jim Stock 2.0L crank and rods with 1.8L heads makes for a bump in the compression ratio. Put 2.0 valves in the 1.8 heads, and you make up for the non-optimal plug location issues with the increase in compression. Plus the 1.8L heads don't drop valve seats like the 2.0L heads. If you do it, make sure you run premium gas all the time. (IMG:style_emoticons/default/driving-girl.gif) |
Jetsetsurfshop |
Aug 2 2018, 03:44 PM
Senior Member Group: Members Posts: 814 Joined: 7-April 11 From: Marco Island Florida Member No.: 12,907 Region Association: South East States |
I did a set too . (IMG:style_emoticons/default/first.gif)
Thanks Len!! Attached thumbnail(s) |
Lo-Fi Version | Time is now: 23rd April 2024 - 11:12 AM |
