FS: Early (70-71) Steering Column |
PCA7GGR |
May 12 2018, 12:59 PM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Early ('70-'71? - the steering wheel that came with it has a "6 70") date code) steering column w/ steering shaft and universal joint. Has ignition key that does not turn, the large cut wire bundle contains 8 wires. $75 shipped lower states - thanks
(IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-1219-1526151591.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/forums.pelicanparts.com-1219-1526151594.2.JPG) |
tweet |
May 12 2018, 01:56 PM
Member Group: Members Posts: 200 Joined: 25-February 13 From: South Florida Member No.: 15,579 Region Association: South East States |
I'll take the lock if you are parting it.
PCA7GGR |
May 12 2018, 02:16 PM
Tweet,
I’ll keep that in mind if I get no nibbles on the assembly. Thanks |
mgp4591 |
May 12 2018, 04:10 PM
914 Guru Group: Members Posts: 5,360 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
The key turned with a little effort before I sent it - maybe a little jogging will help and I did provide the best key with it. Good luck!
tweet |
May 13 2018, 02:32 PM
It doesn't matter to me if the key does not work as long as the cam on the tail of the lock is intact.
PCA7GGR |
May 15 2018, 08:25 PM
Tweet,
Please reply to my PM and let me know if you still want the lock cylinder - thanks |
tweet |
May 15 2018, 08:35 PM
Yes, I will send you some info on how to remove it tomorrow.
PCA7GGR |
May 15 2018, 08:45 PM
Thanks
PCA7GGR |
May 16 2018, 04:24 PM
sold - thanks
Lo-Fi Version | Time is now: 29th March 2024 - 08:26 AM |
