Programmable distributor alternative to the 123Ignition units?, 2016 Maganspark from CB Performance |
Mueller |
May 15 2018, 02:47 PM
Just pulled the plug and bought this kit yesterday.
4 preset curves via dip switches. Don't like those and you can use your laptop to make custom curves and a 3D map. I didn't get in on the 123Ignition group buy and stumbled upon this setup. As a plus it comes with wires and a new coil and can be used with boost. $360. I'm using L-Jet for fuel and it'll fire the injectors when the coil collapses just like a stock distributor. https://www.cbperformance.com/product-p/2016.htm |
porschetub |
May 15 2018, 03:06 PM
Nice to see another option out there,will the unit clear the engine tin on a T4?,how do the vacuum pickups work? I see 4 of them?.
Should be a good unit,good luck with it. |
Beebo Kanelle |
May 15 2018, 03:25 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
Good Info, thanks
Amphicar770 |
May 15 2018, 04:50 PM
Senior Member Group: Members Posts: 1,188 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
This on their web site. ...
NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required. Bosch Blue Coils are NOT compatible. Resistor spark plugs are required |
Mueller |
May 15 2018, 05:23 PM
This on their web site. ... NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required. Bosch Blue Coils are NOT compatible. Resistor spark plugs are required About same mods as if installing a Mallory or MSD distributor, no big deal. |
McMark |
May 16 2018, 10:57 AM
The old Mallory was a drop in. But regardless, you're right, it's no big deal.
michael7810 |
May 16 2018, 12:27 PM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
This on their web site. ... NOTE: MAGNASPARK II & MAGNASPARK Digital will not fit T-3 or T-4, without modification the engine tin. Resistor spark plugs are required. Bosch Blue Coils are NOT compatible. Resistor spark plugs are required About same mods as if installing a Mallory or MSD distributor, no big deal. Can you post a pic of the tin mod? This looks interesting... |
rhodyguy |
May 16 2018, 01:27 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
All you is give the tin a med sized dimple where it interferes with the larger distributor body. Easiest to locate the spot when you try to slip the larger dist in. I think I used a hardwood dowel and a hammer.
jim_hoyland |
Sep 3 2018, 05:53 AM
Get that VIN ? Group: Members Posts: 9,260 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Tomorrow, I'm meeting with my local indy who has serviced my 914 the past 20 years. I'm hoping he can troubleshoot the Mallory Unilite. If he can't, I'm going to consider Plan B I'm not very mechanical on the ignition system; but a friend came over to trouble shoot the system. He though the coil produced a very wet spark; even a back-up coil appeared weak. After we replaced the Mallory optical module, it started right up; the next day, I started the car to idle in the garage and after 5 minutes it died. Won't restart like before. So, I'm also thinking there is something else going on; gonna know more next week |
Lo-Fi Version | Time is now: 25th April 2024 - 01:39 AM |
