Porsche carpet Installation/gluing sequence., My buddy is installing carpeting and needs help |
dcheek |
May 27 2018, 11:12 AM
Senior Member Group: Members Posts: 691 Joined: 30-May 06 From: Westfield, New Jersey Member No.: 6,103 |
I searched this forum and Google and I can't find the sequence for installing a carpet kit in a 914. Pelican has one for a 911 but not for a 914.
Anybody have a link, or can send a PDF of the installation instructions? Dave |
Tom_T |
May 27 2018, 11:56 AM
Dave,
Try looking on any of the Lakewell.com, Autos International, World Upholstery, AA or 914Rubber websites for instructions - or email them to send you instructions. George at AA probably has something or can write it up in an email for you. PS - or maybe Jeff Bowlsby has it on his 914 website under the rare &/or tech documents, or it may be in the 914 factory manual in the Body section - if you have that in hard copy or on CD. (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/flag.gif) Tom /////// |
May 27 2018, 12:09 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
It was just discussed a couple weeks ago but I don't remember the thread. Basically, the carpet on the longs and possibly (can't remember) the carpet around the pedals gets glued in. A rubber mallet and a heat gun can make the indent for the e-brake. The rest is just laid in the car. Speaker grills help hold in the carpet at the front wheels.
You do have to uncouple the steering shaft to put in the piece around the pedals. |
McMark |
May 27 2018, 02:10 PM
914 Freak! Group: Retired Admin Posts: 20,177 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Only glue the pieces to the longs. Everything will be removed and installed again for various common projects/maintenance that pop up. If you glue everything down you're gonna be ripping it up again later.
PanelBilly |
May 27 2018, 04:30 PM
914 Guru Group: Members Posts: 5,788 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Lay out the carpet and see where the gaps are. I glued in some black vinyl in those spots, but I wasn’t trying to build a concourse car either
dcheek |
May 29 2018, 11:05 AM
Thanks everyone for getting back to me.
I will pass the information on to my buddy. Dave |
ConeDodger |
May 29 2018, 11:18 AM
Apex killer! Group: Members Posts: 23,543 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
dr914@autoatlanta.com |
May 29 2018, 11:58 AM
914 Guru Group: Members Posts: 7,772 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
to do a great job with the ten piece carpet set, you will have to remove the seats, the em brake handle as it goes through the carpet, the back pad as the rocker carpet goes under it, the speaker grilles, the pedal board, and the steering column as the bulkhead carpet has the hole for the steering shaft to g through. Start by installing the rocker carpets with a light bit of 3m spray trim adhesive, then install the left and right bulkhead pieces with some light spray trim adhesive cutting the slits for the speaker screw receivers to poke through. Next glue the pedal board piece as high as you can behind the board banking it against the flat part of the cowl. The rest is easy, center tunnel carpet then install the speakers the steering column, the emergency brake. pedal board (board helps cinch up the small pedal board carpet and the backpad (great time with the back pad removed to check for a loose rear window) then install the seats, and finally the four floor pieces (nine if you have a 70-71)
May 29 2018, 11:59 AM
of course not tidied up yet!!!!!! No glue on anything but the two bulkhead pieces and the two rocker pieces.
Mikey914 |
May 29 2018, 01:35 PM
The rubber man Group: Members Posts: 12,625 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
The sequence is pretty straight forward. The cenThe piece at the drivers left foot. Then the passenger foot well piece. Followed by the piece above the pedals. Then the longs followed by the 2 front and rear of both drivers and passenger's floor pieces.
avocadotom |
Jul 5 2020, 01:19 PM
Newbie Group: Members Posts: 5 Joined: 17-September 19 From: Pittsburgh, PA Member No.: 23,469 Region Association: None |
The sequence is pretty straight forward. The cenThe piece at the drivers left foot. Then the passenger foot well piece. Followed by the piece above the pedals. Then the longs followed by the 2 front and rear of both drivers and passenger's floor pieces. I think this post got a little mangled. Not to be obtuse, but sounds like: 1. Center piece 2. Drivers left foot piece - is this the small rectangular piece? 3. Then the passenger foot well piece. 4. Followed by the piece above the pedals. 5. the longs 6. the 2 front and rear of both drivers and passenger's floor pieces. Thanks! |
Nojoah |
Jul 5 2020, 04:34 PM
Member Group: Members Posts: 119 Joined: 6-May 20 From: Ontario Member No.: 24,234 Region Association: Canada |
The order isn't really important as long as the longs and front left footwell piece are glued and installed first. If you lay the pieces out everything should make sense as to their fitment.
Mikey914 |
Jul 5 2020, 08:42 PM
Think of it this way. The last 2 pieces to go down are the passenger and drivers mats.
Lo-Fi Version | Time is now: 29th March 2024 - 06:41 AM |
