Front Sway bar, Front sway bar |
simonjb |
Jun 18 2018, 03:03 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Probably a stupid question, but do all of the front sway bar products require welding to the chassis? My car did not come with sway bars.
Thanks |
ChrisFoley |
Jun 18 2018, 03:11 PM
I am Tangerine Racing Group: Members Posts: 7,907 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
To do it right - yes.
iankarr |
Jun 18 2018, 03:18 PM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,471 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
You're close enough that I can come by with my welder and help you if you want to DIY. Otherwise, Chris is less than 100 miles away and he's the man.
Here's the install video I made which shows the mayeur kit and welds. HUGE difference in handling... https://www.youtube.com/watch?v=l2-iOhb-4Gw |
simonjb |
Jun 24 2018, 02:15 PM
Thanks guys. I have the Maurer kit. What sway bars are folks using these days?
mlindner |
Jun 24 2018, 02:28 PM
Senior Member Group: Members Posts: 1,509 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Well, at the level Racer Chris is at yes.....I installed one thirty years ago, auto crossed and track for over ten and the bolt in installation has been perfect. Best, Mark
iankarr |
Jun 24 2018, 06:37 PM
I installed the stock bar. Easy install and great for street use. I'm sure the track / auto x guys will have some reccos for higher performance units.
ClayPerrine |
Jun 24 2018, 07:15 PM
Life's been good to me so far..... Group: Admin Posts: 15,394 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
There was a bolt in front bar installed on Elwood (factory six). It is not usable right now because the holes in the fender well on the left side have torn out. I am going to have to put in the reinforcement plates and weld in the bolt plates to fix it.
32 years ago, I installed sway bars on Betty's car. I welded in the brackets. I have only replaced the rubber bushings since then. And that with 400,000 miles and a LOT of AX and TT runs. Do it right and weld it in properly. |
Mark Henry |
What is your intended use of the car?
Sway bar type and size depends on what the car is being used for, one of those things you need to be totally honest and realistic with your plan. You don't want a heavy bar on a street only car. It's somewhat like cams choices, a full race cam will make for a horrible street car engine. Too heavy of a sway bar would be too stiff for normal driving and vice versa. |
simonjb |
Jun 24 2018, 09:34 PM
Thanks. It is for street use only.
914_teener |
Jun 24 2018, 09:40 PM
914 Guru Group: Members Posts: 5,193 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
914work |
Jun 24 2018, 11:09 PM
Member Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None |
The stock bar is
Adjustable linkage will allow you to remove pre-load and further "tune" to your driving use. |
ChrisFoley |
Jun 25 2018, 05:04 AM
Jun 25 2018, 08:55 AM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The stock front anti-sway bar is 15mm! (IMG:style_emoticons/default/agree.gif) The stock rear bar is 16mm, not that it matters. Just a front bar is sufficient. --DD |
Mueller |
Jun 25 2018, 09:17 AM
Yep 15mm for stock front.
Someone just posted a swaybar setup in the classifieds for $100.... listed as 914 Parts. Killer deal for stock or aftermarket. |
simonjb |
Jun 27 2018, 03:45 PM
Thanks All
I am looking for a 15mm set up, but can't seem to locate one. Looks like most are 19mm |
Jun 27 2018, 03:54 PM
914-6 GT in waiting Group: Members Posts: 19,223 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
xperu |
Jun 27 2018, 04:32 PM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
Thanks All I am looking for a 15mm set up, but can't seem to locate one. Looks like most are 19mm I have a stock 15mm set up. It needs refinishing and new bushings. $250 + ship. If Simon does not want it I'll take it. Thanks. Mike Kelly |
simonjb |
Jun 27 2018, 05:33 PM
Jun 27 2018, 05:38 PM
Thanks All I am looking for a 15mm set up, but can't seem to locate one. Looks like most are 19mm I have a stock 15mm set up. It needs refinishing and new bushings. $250 + ship. If Simon does not want it I'll take it. Thanks. Mike Kelly I’m taking care of Simon but I’ll look tomorrow to see if I have enough parts to make a second set. If I do, you have first dibs. |
RickS |
Jun 27 2018, 09:35 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
Probably a stupid question, but do all of the front sway bar products require welding to the chassis? My car did not come with sway bars. Thanks Elephant does not require welding but does require drilling holes in your front fenders. That said I have said Efalant sway bar and am being driven nuckin futs by the way it squeaks. Replaced the plastic bushing and still squeaks. Added lithium grease infused with Teflon, still squeaks. Am ready to ditch it since Chuck won’t answer my question about creating a rubber bushing as a replacement. Any suggestions on a replacement? Stock sway? Who sells these? |
Lo-Fi Version | Time is now: 19th April 2024 - 04:06 PM |
