Battery Tray Mystery |
doug_b_928 |
Jun 21 2018, 08:08 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I have a new battery tray from RD (purchased a year or two ago). Today I compared it to old battery tray and to the ECU holder and found a significant difference. Here is a pic of the two side by side.
And here is a pic of the ECU holder next to the old battery tray. And a pic of the ECU holder next to the new battery tray. The raised area with the hole is missing from the new tray. My car is a 73. Given the condition of the old tray, and the fact that I've owned the car for 33 years, the old tray is probably the original (though I notice that it doesn't have a hole on the front left corner of the tray for the bolt in that location. Is the practice to drill two holes and weld nuts on the ECU holder? |
worn |
Jun 21 2018, 08:13 PM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Looks like you have the option to just drill a single hole in the RD part.
Jun 21 2018, 08:18 PM
Resident German Group: Admin Posts: 41,606 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
I don't see mounting holes for the front of the bracket on either tray?
(IMG:style_emoticons/default/confused24.gif) |
cary |
Jun 21 2018, 11:40 PM
Is the practice to drill two holes and weld nuts on the ECU holder? That's what I've been doing. Then using a SS socket head bolt. I don't think RD manufactures these, there isn't a Made In Canada logo on the web page. Pete can correct me if I'm wrong but I think its made by Dansk. |
TravisNeff |
Jun 21 2018, 11:47 PM
Yes by Dansk, I have one I got from RD. It's black e-coated though.
doug_b_928 |
Jun 22 2018, 05:02 AM
Thanks guys. So seems like this is typical. I’ll add drilling holes and welding M6 nuts to the list.
peteyd |
Jun 22 2018, 06:09 AM
Senior Member Group: Members Posts: 705 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada |
I don't think RD manufactures these, there isn't a Made In Canada logo on the web page. Pete can correct me if I'm wrong but I think its made by Dansk. Indeed it is made by Dansk. I do believe there is two versions of the tray also. This part has not been a huge priority to manufacture ourselves. There are more important panels that are not available yet that we will focus on. Pete |
doug_b_928 |
Jun 22 2018, 06:16 AM
yes, like the lower left outer wheelhouse... (IMG:style_emoticons/default/poke.gif)
914Sixer |
Jun 22 2018, 06:59 AM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Seems like we run across this more and more everyday. The devil is in the details.
dr914@autoatlanta.com |
Jun 22 2018, 12:22 PM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Jun 22 2018, 12:23 PM
we actually make over 100 metal parts for the 914 now
doug_b_928 |
Jun 22 2018, 12:58 PM
Much better.
peteyd |
Jun 22 2018, 12:59 PM
doug_b_928 |
Jun 22 2018, 01:11 PM
I’d settle for new quarters at a reasonable price (and the left outer wheelhouse ;p)
David Billo |
Jun 22 2018, 02:13 PM
Member Group: Members Posts: 64 Joined: 23-November 17 From: Plainfield, Ontario Member No.: 21,625 Region Association: Canada |
peteyd |
Jun 22 2018, 02:41 PM
Indeed it is made by Dansk. ... This part has not been a huge priority to manufacture ourselves. There are more important panels that are not available yet that we will focus on. I thought that all the sheet metal parts I see on your website were made by you. Not everything. We do resell some other company's products Pete |
doug_b_928 |
Jun 24 2018, 07:49 PM
So I ended up using a bit of both approaches... I drilled a hole in the tray for the corner nut and I drilled a hole in the ECU holder and welded on a nut. I think it should work.
Mark Henry |
Jun 24 2018, 08:20 PM
Indeed it is made by Dansk. ... This part has not been a huge priority to manufacture ourselves. There are more important panels that are not available yet that we will focus on. I thought that all the sheet metal parts I see on your website were made by you. Not everything. We do resell some other company's products Pete When I first started going to the RD open houses I saw quite a few painted panels in stock, the RD made panels are not painted. Each and every year there's less painted panels and way more unpainted panels. RD has easily doubled the number of 914 panels in this time. RD's shop is a fair size operation and the shear number of parts for 356, 911 and 914 is outstanding. Plus the number of press dies is quite the sight, these are not small, some must be 5+ tons alone. And as always there's a dozen new dies waiting in queue to be polished and put into service. |
Larmo63 |
Jun 24 2018, 08:34 PM
You ordered the right hand drive tray.
Those are made for the British market. |
doug_b_928 |
Jun 24 2018, 08:38 PM
I didn't know there was a difference, but that distinction was not made on the RD website so I guess that's what they had in stock...
Lo-Fi Version | Time is now: 25th April 2024 - 08:15 AM |
