42mm individual throttle bodies (GSXR?), Perfect for making your own setup using Megasquirt |
Mueller |
Jul 10 2018, 10:15 PM
$125 shipped in the US.
Includes the 4 injectors, tps and extra fuel rail. |
jcd914 |
Jul 11 2018, 01:03 AM
PM sent.
Jim |
Retroracer |
Jul 11 2018, 12:11 PM
Senior Member Group: Members Posts: 609 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
They do look like GSXR 1000 throt bods. Out of interest: any chance you could slap a ruler across the top - what is the spacing of the centers? Always wondered about how easy these would be to adapt to early 911 engines,
- Tony |
roblav1 |
Jul 11 2018, 01:04 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
I used GSX-R 750 (40mm) throttle bodies in a 911 build a few years ago. 42mm would be GSX-R 1000.
Mueller |
Jul 11 2018, 03:33 PM
They do look like GSXR 1000 throt bods. Out of interest: any chance you could slap a ruler across the top - what is the spacing of the centers? Always wondered about how easy these would be to adapt to early 911 engines, - Tony 80mm center to center, however these come apart so that spacing can be made bigger or smaller. |
Mueller |
Jul 11 2018, 03:34 PM
hcdmueller |
Jul 11 2018, 07:10 PM
????????????? Group: Members Posts: 542 Joined: 4-February 06 From: UK Member No.: 5,527 Region Association: England |
Those are 2000 gsxr 750 throttle bodies. The remote secondary throttle valve controller is the giveaway. The 2001 gsxr 1000 and 750 use the same updated version with a direct control stepper motor. They both are 42mm. The 600 was 38mm. I have sets of both 750 and 600 sitting in a box.
These seem like the easiest to use because they are 4 individual setups. Whereas newer ones are mostly cast in pairs so the spacing is no longer adjustable. This is a pretty good price for these. |
Mueller |
Jul 11 2018, 07:11 PM
Those are 2000 gsxr 750 throttle bodies. The remote secondary throttle valve controller is the giveaway. The 2001 gsxr 1000 and 750 use the same updated version with a direct control stepper motor. They both are 42mm. The 600 was 38mm. I have sets of both 750 and 600 sitting in a box. These seem like the easiest to use because they are 4 individual setups. Whereas newer ones are mostly cast in pairs so the spacing is no longer adjustable. This is a pretty good price for these. I had to google that secondary throttle box, had no idea what the heck it was! |
roblav1 |
Jul 11 2018, 08:10 PM
Nice catch by Chris.
Retroracer |
Jul 11 2018, 08:26 PM
They do look like GSXR 1000 throt bods. Out of interest: any chance you could slap a ruler across the top - what is the spacing of the centers? Always wondered about how easy these would be to adapt to early 911 engines, - Tony 80mm center to center, however these come apart so that spacing can be made bigger or smaller. Thanks for that - looks as though they could be persuaded to work on an early 911 case - GLWTS - Tony |
Lo-Fi Version | Time is now: 25th April 2024 - 12:33 AM |
