> 914World Classifieds Rules
> Parts wanted, buncha small early items
VintageExcellence
post Jul 16 2018, 10:24 AM
Missing a few small hardware items for my early 914-6. All these parts would be for a very early 1/70 build car and I am only looking for excellent quality parts not junk please.
1. x1 headlight pivot 3 screw, the early ones are steel and a magnet will stick to them (not pot metal), they have a pointed shaft
Found these **2. x10 headlight pivot allen bolts, these are the very short M6 allen that mount the pivot arms to the chassis. Not sure why I am missing all of these but I can't seem to find them in my hardware - can anyone post a pic of the size of these things? I have the mounting plates and washers.
3. Black plastic battery cover, the one held down by the O-ring, anyone know what size battery is correct for a 914-6?
Found these** 4. Fuel tank rubber blocks, the ones on the outside left and right
Found this** 5. x1 trailing arm bolt, these are M10x55mm with a 10.9 grade
6. LEFT early defrost vent, goes on top of the air flap in the trunk, I have one with a broken plastic mounting stud, I want one with no cracks or broken off parts
Found this**7. Strut top forward mount - pictured below, I just need x1 of the front mounts
Found this** 8. Spare tire hold down washer, I have the stud but no washer
VintageExcellence
post Jul 16 2018, 10:26 AM
QUOTE(VintageExcellence @ Jul 16 2018, 09:24 AM) *
picture of the early part
VintageExcellence
post Jul 16 2018, 12:55 PM
Here is a picture of the trailing area bolt I need, one broke coming out.
I like original hardware
VintageExcellence
post Jul 16 2018, 12:58 PM
left defrost vent, see the broken plastic tab, I need one with no broken tabs
Larmo63
post Jul 16 2018, 06:50 PM
I have a battery thingie.
KevinW
post Jul 16 2018, 07:47 PM
I have the fuel tank rubber blocks, spare tire hold down washer and the strut top forward mount.
KevinW
post Jul 16 2018, 08:05 PM
Headlight pivot Allen bolts
KevinW
post Jul 16 2018, 08:17 PM
Found a couple of trailing arm bolts
Mikey914
post Jul 17 2018, 07:56 PM
The rubber man
disregard I mis-read
carl k
post Jul 19 2018, 06:36 PM
I have a steel headlight pivot, three allen bolts for the headlight pivot, and a spare tire hold down plate.
see magnet sticking to part:
PM me if you're still looking for these items.
thanks!
Carl
VintageExcellence
post Aug 20 2018, 09:29 AM
Still looking for the L defrost vent with no broken tabs and a original black plastic battery cover.
Carl, sent you an email on the headlight pivot.
- Lo-Fi Version Time is now: 15th April 2024 - 10:57 PM
