75/76 heat exchangers |
mb911 |
Jul 18 2018, 06:57 PM
914 Guru Group: Members Posts: 6,811 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
A friend contacted me today about a set of heat exchangers off of a 75 or 76 914.. I went and looked at them and they are pretty nice. Any idea on value if any? I know bad performance but for the orginal folks.
Jul 18 2018, 07:20 PM
I haven't seen any that are worth reusing. Now that original brings good money, I'm guessing a couple hundred if all the parts are there. Might take a while to find a buyer.
bigkensteele |
Jul 18 2018, 11:08 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
The only two cars I have owned have been a '76 2.0 and a '75 1.8. The heat exchangers on both have been pretty shot, so I tossed them. But that was before where we are right now. I would say put them on ebay and see what you get. At this point, I am not throwing away any Porsche parts. |
mb911 |
Jul 19 2018, 05:22 AM
Thanks guys. They look pretty nice so I may do the ebay route.
bretth |
Jul 19 2018, 06:16 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
My 75 came with what looks like the factory exchanger tubes on them. Someone cut off the outer sheet metal. The tubes that are left are stainless (non magnetic) to my surprise. Don't know if they were all that way but may still have some decent life left in them if so.
Nacho |
Jul 19 2018, 07:48 PM
Member Group: Members Posts: 219 Joined: 31-December 16 From: So. California Member No.: 20,716 Region Association: None |
Are you all talking about these? I have a set in much better condition and i was thinking of using them as a starting point for a homemade dual exhaust. I would only be using them with an extension where the reactor went leading into mufflers exiting the rear.
I've seen NOS units on ebay for $500 |
mb911 |
Jul 20 2018, 05:44 AM
Are you all talking about these? I have a set in much better condition and i was thinking of using them as a starting point for a homemade dual exhaust. I would only be using them with an extension where the reactor went leading into mufflers exiting the rear. I've seen NOS units on ebay for $500 No I am talking about the " logs" that attach to them |
barefoot |
Jul 20 2018, 07:11 AM
Senior Member Group: Members Posts: 1,269 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
Are you all talking about these? I have a set in much better condition and i was thinking of using them as a starting point for a homemade dual exhaust. I would only be using them with an extension where the reactor went leading into mufflers exiting the rear. I've seen NOS units on ebay for $500 My 76 came with custom exhausts which I'd like to get rid of, hate to throw them away but too far from Hershey to display. |
rhodyguy |
Jul 20 2018, 07:39 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
$0 value.
JamesM |
Jul 23 2018, 01:06 AM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I had a perfect complete 75 exhaust that even had the heat shielding still intact on the head stub pipes.
I gave them away just to get them out of my garage! |
Jul 23 2018, 01:51 PM
In the past, the 75-76 exhaust hasn't been worth much. It's distinctly sub-optimal, worse than any of the earlier exhausts, and only desired by people who had to pass smog with original-type parts.
Now that 914s have started to get collectible, you might see some more demand for the original-type parts, but I'm a fan of backdating these any time it is practical. BTW, the F-pipes make a lousy basis for a custom exhaust. Unless you're just looking for noise. The unequal lengths plus combining two cylinders that fire right after each other, plus the tight-180-bend thing, make for rather worse performance than the early exhaust. Note that the main difference between the 74 2.0 that made 95 HP and the 75 2.0 that made 88 is this very exhaust.... --DD |
JeffBowlsby |
Jul 23 2018, 03:09 PM
914 Wiring Harnesses Group: Members Posts: 8,478 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
They are also a heavy mass of steel connected to the heads to heat unburned fuel for emissions, which retained high heat at the heads, leading to heads with a shorter service life from the high heat.
bdstone914 |
Jul 24 2018, 07:26 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
rhodyguy |
Jul 24 2018, 08:11 AM
Deduct time and gas to and from the scrap recycler @.07 per pound. Hardy cutting a fat hog. Trying to SELL a set of stripped 75-76 with scabbed on mufflers? You have to cut them apart to avoid a massive oversized shipping bill. Then the scrap is real money.
Lo-Fi Version | Time is now: 25th April 2024 - 05:48 PM |
