LE 15322, It will be six years in November |
rstover |
Sep 11 2018, 04:39 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
I was not going to start thread until the car was home, but it is getting close and I want to share some pictures of the car and the progress.
IMG_2173.mov ( 3.24mb ) Number of downloads: 1031 |
Sep 11 2018, 04:42 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Congrats. (IMG:style_emoticons/default/beerchug.gif)
rgalla9146 |
Sep 11 2018, 04:50 PM
WOW ! (IMG:style_emoticons/default/wub.gif)
914_7T3 |
Sep 11 2018, 05:18 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,846 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well?
(IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
poorsche914 |
T4 Supercharged Group: Members Posts: 3,087 Joined: 28-May 09 From: Smoky Mountains Member No.: 10,419 Region Association: South East States |
rstover |
Sep 11 2018, 06:41 PM
My favorite section of a 914 is the rear deck. The simple line and immense flat area sets it apart from all others. I received this from the painter today and it made my day. He thought it was good. I thought it was crazy good. Some guy named Jeff told me to get it painted in single stage. I hope he approves. |
914Sixer |
Sep 11 2018, 09:18 PM
914 Guru Group: Members Posts: 8,868 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I know the restoration on this car. I can't wait to see the paint in person.
rhodyguy |
Sep 11 2018, 09:21 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
It took me a second to figure out the picture. Quite the reflection.
billh1963 |
Sep 12 2018, 07:41 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
That reflection in the movie is awesome!
EdwardBlume |
Sep 12 2018, 08:10 AM
rstover |
Sep 12 2018, 04:57 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) At this time I have painted the front trunk only where needed. The area to the front of the gas tank is very nice. The headlight buckets will need a little attention. There is no deep rust in them. The area up under the cowl was good and all it needs is a good cleaning. Where the gas tank sits there was a spot of rust that had pitted a bit. You can see in the picture where it was. I sanded this out and just painted this small area. There was surface rust in the area below the gas tank which you can also see. I used various wire wheels on a drill and sanded it to get all the rust removed. The area was then sprayed with Permatex rust treatment. After a day or so I wipe off the excess and use a etching primer and then paint. There were three types of material used as gas tank pads when I removed the tank. To the front on the tank were the two carpet pads. There was no problem under those pads. On the flat part of the tank to the rear of the tank was a strip which I think was a furniture protection felt strip. It was long and narrow and it caused no problem. The other piece I think was a piece of leather. This is where the rust was. |
rstover |
Sep 12 2018, 04:59 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) |
914_7T3 |
Sep 13 2018, 03:51 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) At this time I have painted the front trunk only where needed. The area to the front of the gas tank is very nice. The headlight buckets will need a little attention. There is no deep rust in them. The area up under the cowl was good and all it needs is a good cleaning. Where the gas tank sits there was a spot of rust that had pitted a bit. You can see in the picture where it was. I sanded this out and just painted this small area. There was surface rust in the area below the gas tank which you can also see. I used various wire wheels on a drill and sanded it to get all the rust removed. The area was then sprayed with Permatex rust treatment. After a day or so I wipe off the excess and use a etching primer and then paint. There were three types of material used as gas tank pads when I removed the tank. To the front on the tank were the two carpet pads. There was no problem under those pads. On the flat part of the tank to the rear of the tank was a strip which I think was a furniture protection felt strip. It was long and narrow and it caused no problem. The other piece I think was a piece of leather. This is where the rust was. I know exactly what you mean! |
euro911 |
Sep 13 2018, 04:04 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Wow ... looks great, Roger. Now I can see why you desired the nicest trim pieces available to finish it off. Glad to hear the upper windshield trim made the trip OK, and that it met with your expectations. Looking forward to the progression to completion.
rstover |
Sep 13 2018, 05:55 PM
Wow, Its like a mirror! Will you be painting inside the trunks and engine bay as well? (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) At this time I have painted the front trunk only where needed. The area to the front of the gas tank is very nice. The headlight buckets will need a little attention. There is no deep rust in them. The area up under the cowl was good and all it needs is a good cleaning. Where the gas tank sits there was a spot of rust that had pitted a bit. You can see in the picture where it was. I sanded this out and just painted this small area. There was surface rust in the area below the gas tank which you can also see. I used various wire wheels on a drill and sanded it to get all the rust removed. The area was then sprayed with Permatex rust treatment. After a day or so I wipe off the excess and use a etching primer and then paint. There were three types of material used as gas tank pads when I removed the tank. To the front on the tank were the two carpet pads. There was no problem under those pads. On the flat part of the tank to the rear of the tank was a strip which I think was a furniture protection felt strip. It was long and narrow and it caused no problem. The other piece I think was a piece of leather. This is where the rust was. I know exactly what you mean! The pad on the flat part looks familiar. What kind of material do you think it is? |
rstover |
Sep 13 2018, 06:00 PM
aggiezig |
Sep 13 2018, 08:04 PM
Porsche Wannabe Group: Members Posts: 319 Joined: 13-January 16 From: Los Angeles, CA Member No.: 19,557 Region Association: Southern California |
your reflections are stunning!!!
914_7T3 |
Sep 13 2018, 11:01 PM
rstover |
Nov 5 2018, 06:55 PM
The air box is in. I was very apprehensive about getting it back in place and really did not have a plan. I don't read all the post, but I had not seen one that said it was easy. I had a few starts and stops and a few redos. I seperated box from fan then installed the box. With the box in I didn't have room to attach the control wire. (IMG:style_emoticons/default/headbang.gif) Start over. Removed air box to allow room to attach control wire. Even with the box removed this was the most difficult task. I had marked the spot where the wire was attached so I knew where it needed to be. With the washers and a tight fit this gave me a fit. I ended up putting in the bolt with the small hole in and then the near washer and used a little super glue to hold them in place. After the nut secured the wire in place I attached the outer rubber cable. With the wire control in place the fan will set flat and there is room to insert air box. It slid up easily and tightened the box in place. I hooked up electric wire before attaching fan. Getting the fan bolted to box was a challenge. I had to get some longer 5 mm bolts to align it then hold it in place while I got the short bolts in. I don't know if valve is supposed to be completely close, but it wont be on this car. At this position the fan was blowing full and flat was wide open. I don't know if this is perfect , but I don't want to start over. |
rstover |
Nov 17 2018, 04:44 PM
Finished the dash today. It was another one of the items to do that was completely new to me. Thanks to all 914 world members that have shared information and my wife the project was finished and I was happy with the result.
Lo-Fi Version | Time is now: 23rd April 2024 - 11:15 PM |
