1.4 rockers for 914 4, where can i get some ??? |
kepko |
Sep 13 2018, 05:39 PM
Newbie Group: Members Posts: 2 Joined: 13-September 18 From: massachusetts Member No.: 22,484 Region Association: None |
started as 914 4 , 2.0,,,ended up 2640,,,
everything was fine until valve retainer let go and ate a valve,,, had pauter 1.4 roller rockers,,,one was chewed up nobody seems to have anything but stock rockers engine will run on stock rockers but really wants more llift and duration where can i find high lift rockers ?? thanx |
Mark Henry |
Sep 13 2018, 05:55 PM
To me the T4 paulter rocker is junk, it doesn't have correct oiling IIRC. I know Jake was playing with them trying to make them work, don't know if he ever did.
Honestly the stock (modified) rocker works best, everything works correctly, never an issue, I have similar 2.6L T4, 78X102mm, engine in my'67 bug. I use the stock modified rocker with real porsche adjusters and I use T1 dual springs, 163/86b web cam, ceramic lifters, CrMo retainers, hardened keepers and Manton pushrods. |
Beebo Kanelle |
Sep 13 2018, 07:38 PM
Member Group: Members Posts: 248 Joined: 22-November 12 From: Houston, Texas Member No.: 15,177 Region Association: Southwest Region |
it would be nice if somebody, somewhere made a decent rocker with a greater ratio.
and, Not to hijack, but are ceramic lifters available anywhere? |
Jake Raby |
Sep 13 2018, 09:50 PM
l’m making a 1.6 chromoly rocker for my 3.1S.
l have a few random Pauter rockers from sets that have had a rocker break. The self oiling Pauters were junk. l broke 3 of them on Beth’s engine in 4 weeks. They can’t stand a roller cam at all! This post has been edited by Jake Raby: Sep 13 2018, 09:51 PM |
Mark Henry |
Sep 14 2018, 10:26 AM
wrong thread
kepko |
Sep 15 2018, 04:59 PM
what a surprise!!!!!!!!! jake , great to hear youre still here!!!!!!!
i still have a jake 2270 and 1911 and 2056 all ready to install dtms on !! 2270 has ceramics and i think i bought the last set a long long time ago. so , the question now is :: where can you purchase a complete rocker assembly , ready to install and set geometry ?? everybody sells all the parts but who sells the complete assembly??? thanx |
VaccaRabite |
Sep 15 2018, 08:31 PM
En Garde! Group: Admin Posts: 13,423 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Nowhere.
You need to set geometry yourself for optimum performance. As you get to better parts and more power, getting the right tolerance built in is more important. Zach |
veltror |
Sep 20 2018, 04:31 PM
Senior Member Group: Members Posts: 928 Joined: 27-April 08 From: Potters Bar Herts UK Member No.: 8,978 Region Association: None |
veltror |
Sep 30 2018, 07:31 AM
Lo-Fi Version | Time is now: 25th April 2024 - 01:42 AM |
