Auxiliary oil cooler, An alternate location |
IronHillRestorations |
Sep 21 2018, 07:25 AM
I. I. R. C. Group: Members Posts: 6,707 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
25 years ago when I put a 3.0 SC engine in my 914, I understood the need for additional oil cooling, but I didn’t want to cut up my frunk, or run 26 feet of oil lines. My car was a street hot rod, and really didn’t plan on doing track events, so I didn’t need the maximum possible oil cooling.
My solution back then was to put a 25 row Mocal cooler with a fan sandwiched on it in front of the right rear wheel, on the opposite side of the car from the oil tank. This worked out well, and neither I or the current owner has seen oil temps out of range. I have another street hod rod in the works and since the right rear quarter panel was removed for rust repair, I decided to revisit this alternate oil cooler location. After measuring, mocking up, and some head scratching I figured a 34 row 234 matrix Mocal cooler would fit. Here’s what I’ve come up with. To test fit a Spal puller fan, I taped it to the cooler. Two holes drilled for the front bracket and one weld nut for the rear bracket. 3 M8 cap screws are more than enough to secure the cooler |
Sep 21 2018, 07:28 AM
This is a good fit for this location
Attached thumbnail(s) |
db9146 |
Sep 21 2018, 07:40 AM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
Looks like a nice solution, Perry!
Sep 21 2018, 07:49 AM
I tested the fit with the fender to make sure there wasn’t any interference, and that the cooler could be installed and removed when the quarter panel was reinstalled
Sep 21 2018, 07:55 AM
I’m the engine compartment. I’ll make a template for the front mounting holes for any future installs and to share with anyone else who would like this option.
I’ll make a stone shield after it’s all plumbed in, and I’ll post more pics when it’s completed Attached thumbnail(s) |
TravisNeff |
Sep 21 2018, 08:38 AM
That looks like a great solution Perry, thanks for sharing that.
DRPHIL914 |
Sep 21 2018, 08:51 AM
Dr. Phil Group: Members Posts: 5,751 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Perry,
I have the same size cooler and the same fan on mine, but we put it up under the right side rear trunk, just above the HE on that side- I didn't really think at the time it would fit bac kin that wheel well area, but that is a nice solution,- might think about relocating it at a later date, right now it does seem to work very good where it is. |
Sep 21 2018, 08:55 AM
Perry, I have the same size cooler and the same fan on mine, but we put it up under the right side rear trunk, just above the HE on that side- I didn't really think at the time it would fit bac kin that wheel well area, but that is a nice solution,- might think about relocating it at a later date, right now it does seem to work very good where it is. I’ve done that before too, and it makes for an easier install. For your 2.0 you’ll be fine. This car is getting a 230hp engine and I wanted to get the cooler away from the exhaust heat |
burton73 |
Sep 21 2018, 09:32 AM
burton73 Group: Members Posts: 3,457 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Thank you, this looks like a great spot for this.
Bob B |
whitetwinturbo |
Sep 21 2018, 11:21 AM
Honey, does this wing make my ass look fat? Group: Members Posts: 1,391 Joined: 22-October 11 From: Newport Beach/Kalefornya/USA Member No.: 13,704 Region Association: Southern California |
jim912928 |
Sep 21 2018, 11:55 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Nice....I need something for my 3.2 conversion. Mine creeps up somewhere between 220-240 on hot days in the summer...so I don't drive it very long. Didn't want to do all the plumbing and cutting going up front. Keep the info coming.
Sep 21 2018, 12:12 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Nice....I need something for my 3.2 conversion. Mine creeps up somewhere between 220-240 on hot days in the summer...so I don't drive it very long. Didn't want to do all the plumbing and cutting going up front. Keep the info coming. It’s actually very easy to put up front and except for some 1” holes for the lines, no cutting involved. |
Sep 21 2018, 01:04 PM
You still loose 1/3 or more of the front trunk
jim912928 |
Sep 21 2018, 03:55 PM
I have a 75 that still has the big bumpers, so I didn't really want to cut the holes for the lines, backdate bumpers, cut valance and bumper (or leave big bumpers and cut valence/modify more), cut trunk, move spare location (probably put in an inflatable..etc. This looks easier and cleaner for something I could do pretty easy.
Steve |
Sep 21 2018, 05:27 PM
914 Guru Group: Members Posts: 5,547 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area.
Sep 21 2018, 07:13 PM
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area. I'm considering making custom rockers and ducting up to that area, but we may hold off and see how it does. That cooler is about 1/3 larger in size and capacity than the kit BAT makes to replace a 911 front fender cooler. The engine will be totally rebuilt by a master engine builder, and a new tight engine will always run cooler than an older engine with more blow by. |
pete000 |
Sep 21 2018, 09:49 PM
Nice install ! (IMG:style_emoticons/default/welder.gif)
rgalla9146 |
Sep 21 2018, 10:14 PM
Advanced Member Group: Members Posts: 4,538 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area. I'm considering making custom rockers and ducting up to that area, but we may hold off and see how it does. That cooler is about 1/3 larger in size and capacity than the kit BAT makes to replace a 911 front fender cooler. The engine will be totally rebuilt by a master engine builder, and a new tight engine will always run cooler than an older engine with more blow by. Hey Perry Nice installation. Great use of overlooked space. I'm planning on putting an AC condenser there. I'll provide airlflow by adding a fan and louvers or some form of opening in the fender. |
Spoke |
Sep 22 2018, 06:33 AM
Jerry Group: Members Posts: 6,964 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Curious what kind of air flow you will get in the fender? I have seen people put a duct in the rocker to force air into that area. It can't be any worse than the 911 front fender location. There's only a 1 inch x 6 inch opening under the bumper and the headlight bucket is so close to the top of the cooler that a fan will not fit in front of the top of the cooler. The one thing it does have going for it is that the entering cool air is separated from the exiting hot air with the shroud and foam gasket. Not sure in the 914 rear wheel well how the hot air exiting the cooler is kept from being sucked back in as cool air. Attached thumbnail(s) |
914forme |
Sep 22 2018, 07:05 AM
Several have done this, okay several being at least 5 I can count, but it is a great solution if it meets your needs.
From what I see the thing that makes the 911 work, was separation of spaces, and a high low pressure zone. If you can achieve the same thing than that would be great. CB performance used to market what the called a 550 oil cooler kit. It took two VW oil coolers and mounted them up front. On the 550 kits they mounted them right behind the brake cooling inlets. A nice front fender oil cooler might be doable. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 28th March 2024 - 08:34 AM |
