How do you install these Damn seats |
flmont |
Oct 14 2018, 01:55 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
I cant remember how my seats came out,..and its either 1 side or the other when it comes to lining up the little flapper anchors I cant get them both to line up !!!
76-914 |
Oct 14 2018, 02:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,454 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
On my drivers seat I barely slip the inner rail on then move to the outer. It appears one side is longer but I can't confirm that w/o getting out of my chair. (IMG:style_emoticons/default/av-943.gif)
Oct 14 2018, 02:19 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Just set the seat rails on the end of the base rails, lift the handle and slide back.
flmont |
Oct 14 2018, 05:34 PM
flmont |
Oct 14 2018, 05:35 PM
I just cant line it up..
mgphoto |
Oct 14 2018, 07:04 PM
"If there is a mistake it will find me" Group: Members Posts: 1,330 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
flmont |
Oct 14 2018, 07:20 PM
they dont line up with the little flapper anchor plate,if one side does the other wont,.I know Iam missing something easy its been a year since I pulled them .
sb914 |
Oct 14 2018, 07:33 PM
Surf Guru Group: Members Posts: 4,292 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
I just set the seat on top of the rails tilt the seat back so you can see underneath than slid onto rails. I just did this last week. Took one minute.
Oct 14 2018, 07:39 PM
Yep, in and out should take seconds without adjustment. Maybe try from the opposite side in case you are holding the seat at an angle.
DaveO90s4 |
Oct 14 2018, 09:24 PM
Member Group: Members Posts: 149 Joined: 26-April 16 From: Australia Member No.: 19,935 Region Association: None |
File a small taper on the inner and outer of each chasis-minted rail. Not much. That will help give the seat rail a gentle entry into the chassis rails.
jim912928 |
Oct 14 2018, 09:50 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
I’d also lubricate them with some white lithium grease so the slide on easier.
falcor75 |
Oct 14 2018, 10:35 PM
Senior Member Group: Members Posts: 1,578 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Gentlemen he's talking about the seat rails.
Try loosening the screws for the jagged plate at the front that the height adjuster goes into. Do a dry fit without the adjuster engaged to see that the rear four bolt holes line up with the seat rail holes. |
Andyrew |
Oct 15 2018, 10:02 AM
I lift up on the height adjuster while attaching the seat rail base and installing a bolt on the other side. Elsewise I find it doesnt match up.
dr914@autoatlanta.com |
Oct 15 2018, 10:14 AM
914 Guru Group: Members Posts: 7,770 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
often when the seats are recovered, the upholstery guy does not get the sliders lined up correctly and then it is extremely hard if not impossible to line them up with the seat rack. If this is the case, slightly loosen the Allen bolts that hold the sliders onto the seat, start and slide the seal onto the rack, then remove and tighten up the Allens
Jamie |
Oct 15 2018, 10:44 AM
Senior Member Group: Members Posts: 1,023 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States |
I’d also lubricate them with some white lithium grease so the slide on easier. Oh no, don't use any grease because it will hold dirt in use. Rub on a bit of candle wax to lube the slides and rails. (IMG:style_emoticons/default/screwy.gif) |
Oct 15 2018, 10:45 AM
I’d also lubricate them with some white lithium grease so the slide on easier. Oh no, don't use any grease because it will hold dirt in use. Rub on a bit of candle wax to lube the slides and rails. (IMG:style_emoticons/default/screwy.gif) Very good idea. |
rhodyguy |
Oct 15 2018, 11:01 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Remove the base and fit the sliders. Turn the seat upside down. You can access/loosen the slider fasteners and adj them to fit the base as it slides in. Fitment is a pita with the base installed in the car as the loose sliders shift around with the in and out.
flmont |
Oct 15 2018, 05:54 PM
Thanks So Much for all the info,I figured it out I pulled out the entire frame,So I put the adjustment tongue on the highest point which pitched the seat at the angle needed to bolt up to the little flapper hinge,..Thanks !!!
Lo-Fi Version | Time is now: 28th March 2024 - 10:38 AM |
