914 GT off set / back spacing with no spacers ? |
914GTSTI |
Nov 8 2018, 05:02 PM
Member Group: Members Posts: 269 Joined: 16-September 07 From: Glendale AZ Member No.: 8,123 Region Association: None |
Keep looking but have not found the answer. This will be using the 4-130 pattern.
So what is the back spacing or off set for the front using a 8x15" wheel .And the rear using a 10" or 12" x 15 " for the rear.( if they will fit) Trying to not use a spacer. Thanks, Randy |
Nov 8 2018, 05:11 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
You might get a 9” wheel on the back but no bigger unless you widen the flares.
pete000 |
Nov 8 2018, 06:32 PM
These are wider than 9" and look killer ! RSR
Attached thumbnail(s) |
914GTSTI |
Nov 8 2018, 06:47 PM
Is 7x15" front and 9x15"+- the way to go ? And their is still the back spacing / off set question ? Using the Factory flairs.
TravisNeff |
Nov 8 2018, 08:38 PM
I believe you can get 15x8 up front (ET 10.3), the 8's would fit in the back. As for the 9's there are 2 offsets for them ET 3 and ET 15. I don't know if either of those will fit without widening the rears flares or not.
914GTSTI |
Nov 8 2018, 09:08 PM
How about if the wheels are custom ? Does this make any difference ?
What about 8x15 all around with a spacer to fill the well ? And for tires how about 225/45R15's ? |
pete000 |
Nov 8 2018, 11:02 PM
I have run 15 x 8 front and back with no problems, I used a 13mm 930 spacer on the front.
Currently running 16 X 7 up front with 15mm spacer and 16 x 8 out back no spacers. Plenty of clearance. |
PlaysWithCars |
Nov 8 2018, 11:25 PM
Senior Member Group: Members Posts: 521 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
I had 16x8 and 16x9 on mine and it looked killer! Too bad I didn’t own them and can’t afford to buy them. Would love them for my street tires. Currently running 15x8 all the way around and they do a good job filling up the wheel wells.
sixnotfour |
Nov 9 2018, 03:07 AM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
8 & 9 x15 205 & 225s buy wheels first if your going that wide...to run 245/50s I had to rework the lft rear
sixnotfour |
Nov 9 2018, 03:12 AM
the 15 mm offset of the 9x16 fit no problem.. the 3 mm offset of the 15s is a problem, as seen in my grn 814 pic,,,that being said,,I know a guy that cannot put any 9 inch under his rear flairs..
Nov 9 2018, 06:07 AM
Also depends on your budget.
15x8 -$500-800/pr 16x8- $800-1,200/pr 15x9- $1,500-2,200/pr 16x9 - $1,600-2,400/pr Unless you are looking at fake Fuchs. |
Racer |
Nov 9 2018, 06:58 AM
Senior Member Group: Members Posts: 787 Joined: 25-August 03 From: Northern Virginia Member No.: 1,073 Region Association: MidAtlantic Region |
914GTSTI |
Nov 9 2018, 09:36 AM
Lo-Fi Version | Time is now: 28th March 2024 - 03:42 AM |
