3 Pages V  1 2 3 >
> Type 4 rebuild questions
post Nov 19 2018, 08:14 PM
914-6 GT in waiting
What can I do to rebuild my 1.7 for more HP and torque but keep the original d-jet.
piston and cylinders
crank
camshaft
heads
I know I can't change the cam too much but is there one that will do better and still work with d-jet.
I know there is modern FI but I'm not interested. No carbs. I'm not looking for all out HP or dropping 10K on an engine kit. I just want a nice bump in power, if possible, while keeping a stock looking engine.
Mark Henry
post Nov 19 2018, 08:58 PM
that's what I do!
Webcam #73
96mm KB's for 66mm crank and move up to 1800S heads. I'd guess 90hp max.
Headers would be a consideration, only true bolt on HP, but at your HP it won't be a huge improvement. Maybe 5%.
No replacement for displacement, consider stepping up to 2,0, but no idea how well it would work with 1.7 djet. L-jet works for sure and 2,0 djet.
I love the 2056 2.0 head Ljet combo.
post Nov 19 2018, 09:39 PM
914-6 GT in waiting
QUOTE(Mark Henry @ Nov 19 2018, 09:58 PM) *
Webcam #73
I do have a set of nos mahle 94mm P&C's. Also have a 2.0 crank. I don't know if either of these will fit or work to improve power. I was hoping to see 100 but I realize the stock 1.7 d-jet has limitations.
Weight reduction (of the car) will also help to increase performance.
Chris914n6
post Nov 20 2018, 01:20 AM
Jackstands are my life.
The big difference with Djets is ecu and injectors.
But for all that trouble might as well put it into that Suby....
BeatNavy
post Nov 20 2018, 06:05 AM
Mark (E) I'm doing a similar build right now. 2056, webcam, Hoffman heads, and stock-djet. Not to contradict Mr. Henry (who has a world more experience than I will ever have), but I thought something like this was good for north of 110 hp. Maybe anything less than 200 to Mark (H) just looks like 100-ish (IMG:style_emoticons/default/smile.gif)
I guess we shall see.
Racer
post Nov 20 2018, 07:05 AM
I know a bump to a 1911 was always popular for 1.7s wanting more.. but the djet question is one I cant answer. I know 2.0/2056 with 100-110hp with djets were possible.. Are the 1.7 and 2.0 djets different?
saigon71
post Nov 20 2018, 07:08 AM
FAT 440 MP camshaft is great with D-jet.
I think a good budget build would be 96mm pistons with 1.7 crank, lightened flywheel and FAT 440 MP cam. Send the MPS to Jeff Bowlsby for 1911 calibration. Have stock heads rebuilt.
Literati914
post Nov 20 2018, 09:35 AM
Posted in the classifieds?, you amateur (IMG:style_emoticons/default/poke.gif)
I do kind of envy the built 1.7, they can be quick/high revving engines AND gas mileage! I like that.
914Sixer
post Nov 20 2018, 09:42 AM
Correct me if I am wrong, but the stock 1.7 made 88 hp in 70,71 according to brochure. They made it happen with domed pistons.
GregAmy
post Nov 20 2018, 10:07 AM
"Subscribing". My 2L street car is running nice with the stock D-Jet, but I heard that the system does not respond well to engine mods.
I also question how much more power you're going to get through that small single-port throttle body.
yellowporky
post Nov 20 2018, 10:26 AM
getting ready to build up my 73 1.7 next month.
This was perfect timing.
Thanks for the info
Alapone
post Nov 20 2018, 11:09 AM
Just curious, has anyone built a motor with a 66mm crank and 100 or 101mm or larger pistons, like a short stroke 2.1. Is it possible? what would the characteristics of that set up be>?
Racer
post Nov 20 2018, 11:22 AM
QUOTE(914Sixer @ Nov 20 2018, 10:42 AM) *
i think that is incorrect. I believe my Stock early 1.7 was rated at 80hp. By 72 or maybe 73 they were down to approx 75hp.
Really might depend if you are looking at DIN, SAE, Gross or Net too as all were popular Brochure horsepower tools (IMG:style_emoticons/default/wink.gif)
post Nov 20 2018, 01:01 PM
914-6 GT in waiting
QUOTE(Literati914 @ Nov 20 2018, 10:35 AM) *
Yea, my mistake.
@sirandy
914Sixer
post Nov 20 2018, 01:13 PM
My bad, I got on the wrong info line. 88 hp was for the 73 2.0. 76 hp is for the 1.7.
thelogo
post Nov 20 2018, 02:40 PM
Group: Retired Members
If your stick in with djet = stay bone stock
If you want to go above 60-70-80 hp
Then djet wont get you there
Jamie
post Nov 20 2018, 02:41 PM
QUOTE(914Sixer @ Nov 20 2018, 11:13 AM) *
Stock 73 was/is rated at 80 HP. (IMG:style_emoticons/default/driving.gif)
post Nov 20 2018, 02:50 PM
914-6 GT in waiting
I already have 94mm Mahle P&C's, 2.0 crank and a FI cam kit. I'm wondering if any of those things will make a difference if I rebuild the engine. If it's little to none, or not a combo that will work, I won't bother. If I could get another 15hp, well that's a 20% increase on that engine so It would be worth it to me.
I have a 250lb weight reduction planned (on paper) so a little boost with a much lighter car would make it fun.
JOEPROPER
post Nov 20 2018, 04:24 PM
The answer is "no" unless you ask...
I think you're right about looking at HP increases in percentage vs. looking at actual "big" numbers. When you are starting off with a relatively low HP number, I think it's unreasonable to look for high HP numbers with stock FI. I think 20% is a terrific goal and will be very noticeable.
TravisNeff
post Nov 20 2018, 05:03 PM
The CA spec 73 1.7 was 72 HP, lower than the 1.8 believe it or not.
I wonder if you could build a 2.0 liter engine and use the 1.7 djet?
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 16th April 2024 - 12:36 PM
