Shutting off the engine, Engine won't shut off |
erwindv |
Dec 6 2018, 03:48 AM
Newbie Group: Members Posts: 46 Joined: 17-June 16 From: Belgium Member No.: 20,119 Region Association: Europe |
Arriving home with the car, turning the ignition key to shut off the engine but it keeps on running!!
What could be wrong? Some electrical issue with the ignition switch? Meanwhile, before fixing it, what is the safest way to turn it off? Thx |
Tbrown4x4 |
Dec 6 2018, 04:03 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Can you pull the fuel pump relay, or is it carbed?
Tdskip |
Dec 6 2018, 08:14 AM
Advanced Member Group: Members Posts: 3,678 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None |
Keeps running for 15 second, 30, 60 seconds or will sit there and run until you get out of the cockpit and do something?
erwindv |
Dec 6 2018, 08:33 AM
bretth |
Dec 6 2018, 08:42 AM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
I seem to remember something about using the wrong tail light bulb causing this problem? Unless I am confusing this with another issue, couldn't find any info on a quick search though. Something about using a single filament bulb instead of a double filament keeps the ignition circuit alive when the key is off.
Krieger |
Dec 6 2018, 08:47 AM
Advanced Member Group: Members Posts: 4,693 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I bet it's the ignition switch. Pull the hot wire off the coil to shut it down.
rhodyguy |
Dec 6 2018, 08:52 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,054 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
As asked, FI or carbs?
erwindv |
Dec 6 2018, 08:58 AM
JFG |
Dec 6 2018, 09:05 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
emergency engine shut off, put in 5th and stall it then go pull wires off the coil.
Dec 7 2018, 04:54 PM
914 Idiot Group: Members Posts: 14,980 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I seem to remember something about using the wrong tail light bulb causing this problem? Unless I am confusing this with another issue, couldn't find any info on a quick search though. Something about using a single filament bulb instead of a double filament keeps the ignition circuit alive when the key is off. That was me. If you have the wrong bulb in one of the taillight sockets, and you leave the turn signal switch up or down (depending on where the wrong bulb is) the power from the "parking light" feature will feed back through the ignition switch to the ignition and fuel injection systems... Mixing up power and ground will make for very very weird symptoms! Has any electrical work been done on the car since the time it wasn't having this problem? If so, that's the first place to look. --DD |
dr914@autoatlanta.com |
Dec 7 2018, 04:57 PM
914 Guru Group: Members Posts: 7,806 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
pull the voltage regulator and see if it shuts off, if so the alternator is shorted, if not probably the ignition switch
JamesM |
Dec 8 2018, 12:03 AM
Senior Member Group: Members Posts: 1,888 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
what fuel system are you running?
What happens when you step on the brake after the key has been shutoff? |
euro911 |
Dec 8 2018, 04:13 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I seem to remember something about using the wrong tail light bulb causing this problem? Unless I am confusing this with another issue, couldn't find any info on a quick search though. Something about using a single filament bulb instead of a double filament keeps the ignition circuit alive when the key is off. That was me.If you have the wrong bulb in one of the taillight sockets, and you leave the turn signal switch up or down (depending on where the wrong bulb is) the power from the "parking light" feature will feed back through the ignition switch to the ignition and fuel injection systems... Mixing up power and ground will make for very very weird symptoms! Has any electrical work been done on the car since the time it wasn't having this problem? If so, that's the first place to look. --DD |
Lo-Fi Version | Time is now: 18th April 2024 - 04:33 AM |
