Bumper and valence cut for rad intake. |
1970-1914 |
Dec 11 2018, 11:35 PM
Member Group: Members Posts: 97 Joined: 3-June 18 From: Vancouver Member No.: 22,186 Region Association: Canada |
I thought I Would try and mod the front bumper and valence myself to allow for the oil cooler type duct to feed my rad. This is about 1” wider of an opening than stock (21” vs. 20”) and 4” tall.
Got the the first pieces cut on my friends plasma table. Going to Bend a small diameter round rod to follow the intake lip to make a smooth transition in. Hoping for a result close to this. |
sithot |
Dec 12 2018, 04:51 AM
Member Group: Members Posts: 446 Joined: 25-October 06 From: Virginia Member No.: 7,090 Region Association: None |
PM sent
mb911 |
Dec 12 2018, 05:35 AM
914 Guru Group: Members Posts: 6,748 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Took me a while to get it figured out. Now I have done 12 bumpers and have a system with great results..
I have made laser cuts of 18 ga and then carefully cut the opening and add a 1/2" radius at the bottom . everyone seems to want that.. I do like your idea for the valance and would have done that myself but I don't have a steel valance. |
mb911 |
Dec 12 2018, 05:37 AM
This was my 1st bumper I did..
Dec 12 2018, 06:20 AM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Ben - I might have to send you a couple steel valances so you can “practice” and add it to your list of GT mods.
Cairo94507 |
Dec 12 2018, 07:19 AM
Michael Group: Members Posts: 9,649 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
That. (IMG:style_emoticons/default/beerchug.gif)
1970-1914 |
Dec 12 2018, 11:05 AM
Took me a while to get it figured out. Now I have done 12 bumpers and have a system with great results.. I have made laser cuts of 18 ga and then carefully cut the opening and add a 1/2" radius at the bottom . everyone seems to want that.. I do like your idea for the valance and would have done that myself but I don't have a steel valance. Yes - seeing your thread about the bumper mods was the motivation to try doing a matched set of these. I'll post my progress as it happens and hopefully can contribute a bit in the process. Pierre |
sixnotfour |
Dec 12 2018, 11:17 AM
914 Wizard Group: Members Posts: 10,392 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
here is an enlarged GT version eurotech body werks did...fiberglass
mb911 |
Dec 12 2018, 11:24 AM
Ben - I might have to send you a couple steel valances so you can “practice” and add it to your list of GT mods. @mepstein sounds good to me.. |
Dec 12 2018, 11:52 AM
Ben - I might have to send you a couple steel valances so you can “practice” and add it to your list of GT mods. @mepstein sounds good to me.. Maybe after holidays so we don’t load up your garage. I’ll see how many I have in case your father needs one. 1970-1914 - sorry to hyjack. I was wondering how to get the flat front on the GT balance. Your solution looks great. |
burton73 |
Dec 12 2018, 02:45 PM
burton73 Group: Members Posts: 3,457 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Ben - I might have to send you a couple steel valances so you can “practice” and add it to your list of GT mods. (IMG:style_emoticons/default/agree.gif) What would be cool is if you did steel ones with the fender flair area put in. Like the glass ones but metal. Best of both worlds. Bob B |
mb911 |
Dec 12 2018, 07:37 PM
Ben - I might have to send you a couple steel valances so you can “practice” and add it to your list of GT mods. (IMG:style_emoticons/default/agree.gif) What would be cool is if you did steel ones with the fender flair area put in. Like the glass ones but metal. Best of both worlds. Bob B I may do that.. Stay tuned.. |
1970-1914 |
Dec 16 2018, 07:58 PM
I bent some 3/8 rod to the same radius as the bumper bottom and valence top. The plan is to use these as a general shape support as well as to provide a radiused edge going into the duct.
I did a rod like this behind the bumper at the top of the cutout but I did not take a pic. The ends were cut off past the sheet metal after this pic. Unfortunately where the car is there is not much room in front of it to get a decent pic. Pretty happy with the overall result / look. Going to take both the bumper and valence back off now to finish the fab work. Probably won’t happen for a few days though with all the Xmas family stuff going on. |
1970-1914 |
Dec 20 2018, 01:44 AM
Valence is coming along - probably not exactly as factory but pretty hard to see under here to critique once the car is on the ground. (IMG:style_emoticons/default/biggrin.gif)
1970-1914 |
Jan 1 2019, 04:41 PM
Made some more progress on the valence - mostly welded up and fits well. I cut the piece of sheet metal off that went across the lower opening. With the round bar there it is not really necessary and will be easier to blend the body filler into.
The opening will be boxed in around the opening into the trunk so that all available air flow will make into and through the rad. |
mb911 |
Jan 1 2019, 06:37 PM
Looks nice..
I need to draw up mine so I can laser cut some parts as well.. |
1970-1914 |
Mar 11 2019, 12:54 PM
Had a little time to think about the next step with these and I decided to enlarge the bumper cut vertically about another 1.25" to help with the V8 cooling situation.
After I cut the sheet metal back I re-tacked in the 1/2" round rods that form the lips and give it back some rigidity. First skim of bondo and it looks like this will work out OK which is great considering I was going to toss this bumper originally. |
Mark Henry |
Mar 11 2019, 03:23 PM
Nice work, I still have to do my valance.
Lo-Fi Version | Time is now: 28th March 2024 - 10:51 AM |
