Hood adjustment, Front Hood |
RolinkHaus |
Dec 30 2018, 02:58 PM
Member Group: Members Posts: 253 Joined: 21-July 18 From: Noblesville, IN Member No.: 22,330 Region Association: None |
RolinkHaus |
Dec 30 2018, 02:59 PM
buck toenges |
Dec 30 2018, 08:05 PM
Senior Member Group: Members Posts: 553 Joined: 25-November 03 From: Fort wayne In Member No.: 1,388 Region Association: None |
What does the front trunk seal look like? Is it new? If new then it could look this way. Can you take off the seal to see how it fits?
Buck |
rgalla9146 |
Dec 30 2018, 08:17 PM
Get the rear edge and the sides as parallel and uniform with the cowl and fenders
as possible. Be certain the hood is high enough that it does not catch on the front edge of the cowl. The mounts on the body for the hinges are adjustable but difficult to access. The curvature of the sides of the hood can be increased or decreased ....but not too much. Your issue may be as simple as adjusting the rubber bumpers at the front corners on the body. They can be raised or lowered by screwing them in or out. After you've optimized these items the headlight covers, eyebrows and the front bumper will need attention. Results can come in a few minutes.....or a few days. As Buck says above.....new gasket ? just hope it settles down but don't expect too much. When these things are 'right' the whole car looks better. |
tygaboy |
Dec 30 2018, 08:25 PM
914 Guru Group: Members Posts: 5,269 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California |
Always hard to tell from pics only, but...
Carefully check the underside / support structure for signs of damage. I have a hood that's doing what yours is doing. At first glace, it looks perfect. However, in looking at the support areas, I found a smallish dent. It's causing a slight bow in the hood that makes it sit a bit proud of the fender line. Until that's addressed, no adjustments will make it fit correctly. Hopefully, that's not what's up w/yours and adjustment will get you there. |
second wind |
Dec 30 2018, 10:39 PM
Senior Member Group: Members Posts: 850 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
I say it is the seal. My new seal ruined the fit of my hood six years ago....slowly improving......fits perfect without seal. I am going to use heat gun to flatten seal ...off of car of course....these heat guns get really hot!! Having the hood and lights and eyebrows fit like new is what makes a fair car or a great car in my opinion.
gg |
RolinkHaus |
Dec 31 2018, 07:57 AM
Thanks for the info
dr914@autoatlanta.com |
Dec 31 2018, 08:21 AM
914 Guru Group: Members Posts: 7,816 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
this is dead on, align to the cowl first and make sure it is perfectly uniform. If when uniform to the cowl and will not align to each side, the car has been hit, if perfect on the cowl and one fender, the other fender side has been hit. Besides the buffers the hinge mounting brackets and the hinge bolts being adjustable, the latches have a bit of adjustment in them. Finally, like someone else stated, if the hood structure has been damaged underneath OR the hood has been bowed, it can be made to lie flatter by putting a 2x4 under the front side lip and then be pushed down in the middle side one side at a time to make the hood flatter
Get the rear edge and the sides as parallel and uniform with the cowl and fenders as possible. Be certain the hood is high enough that it does not catch on the front edge of the cowl. The mounts on the body for the hinges are adjustable but difficult to access. The curvature of the sides of the hood can be increased or decreased ....but not too much. Your issue may be as simple as adjusting the rubber bumpers at the front corners on the body. They can be raised or lowered by screwing them in or out. After you've optimized these items the headlight covers, eyebrows and the front bumper will need attention. Results can come in a few minutes.....or a few days. As Buck says above.....new gasket ? just hope it settles down but don't expect too much. When these things are 'right' the whole car looks better. |
tmessenger |
Dec 31 2018, 08:53 AM
Member Group: Members Posts: 70 Joined: 6-December 18 From: Iowa Member No.: 22,707 Region Association: Upper MidWest |
I've been working on this same issue, lowering the front latch (I even filed the slots a bit) helped. You can then adjust the bumper down a bit if needed.
Tim |
sholman5 |
Dec 31 2018, 08:59 AM
Kraut burner Group: Members Posts: 189 Joined: 11-September 16 From: Ormond beach, Fl. Member No.: 20,391 Region Association: South East States |
I changed the hood seal on mine, fit is perfect. If you have changed the seal on the wall that separates the fuel tank from the front trunk compartment, it only goes on one way. If you have on backwards the hood when closed will bow and the alignment will be off. That happened to me. Reversed it and had no resistance when I closed it.
FlacaProductions |
Dec 4 2019, 12:36 PM
Senior Member Group: Members Posts: 1,555 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Bringing this one back....I'm pretty happy with the way my hood lines up except for as I get closer the cowl. I think I have this narrowed to a potential adjustment at the hinges.
Question is, how is this adjustment achieved? I can't quite get a grip on the procedure. Are there two bolts down there? Simply loose and lower or will there be pressure/force on them due to the hinge springs? I certainly don't want to make it worse as it's really just picking nits at this point.... |
rgalla9146 |
Dec 5 2019, 07:54 AM
What a beautiful car.
The rear hinge mount adjustment is difficult and will require patience and caution. It could lead to damage of your paint across the rear edge of the hood and the front edge of the cowl. The mounts are hard to even see no less adjust in a incremental way. Mark the current position before doing anything. |
Lo-Fi Version | Time is now: 25th April 2024 - 11:20 AM |
