Would the welders look at this please |
BPic |
Mar 19 2019, 06:59 PM
Member Group: Members Posts: 341 Joined: 5-February 18 From: Miami, Florida Member No.: 21,864 Region Association: South East States |
I've been welding in this car for a year and never had anything like this happen.
I ran out of gas and the welder was doing fine. Got a new bottle delivered today and hooked it up. When I started welding it sounded different, lots of soot, the metal doesn't puddle the way it did before and the welds look like crap! (IMG:style_emoticons/default/headbang.gif) The other thing that happens is that the wire fuses itself to the gun tip. Settings are the same on the machine and everything was fine. The only thing that changed was a new bottle of gas. I'm sure it's possible for them to put the wrong mix or the wrong gas but before I call them is there something else I should be looking at? (IMG:style_emoticons/default/confused24.gif) Thanks in advance, Brad |
roblav1 |
Mar 19 2019, 07:13 PM
Senior Member Group: Members Posts: 528 Joined: 18-September 12 From: KY Member No.: 14,943 Region Association: MidAtlantic Region |
Contaminated gas? Running straight argon, right? Who's the supplier? Brownish-yellow haze looks like bad gas. Same thing happened to me. My welder puddled cleanly then changed bottles and all went to crap. I picked up a new bottle today (Airgas) so I'll see if it's better tomorrow.
Mar 19 2019, 07:19 PM
914-6 GT in waiting Group: Members Posts: 19,234 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Superhawk996 |
Mar 19 2019, 08:08 PM
914 Guru Group: Members Posts: 5,745 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Bad gas
It can happen to the best of us. (IMG:style_emoticons/default/av-943.gif) No seriously (IMG:style_emoticons/default/biggrin.gif) Leak check your connections and hose first |
tazz9924 |
Mar 19 2019, 08:11 PM
Senior Member Group: Members Posts: 703 Joined: 31-May 15 From: Mooresville NC Member No.: 18,779 Region Association: None |
It looks like you are missing a good amount of gas. Possibilities: Did you take off the wire feed hose? somtimes when you put the feed hose back on it doesn’t go all the way in and it leaks gas, listen for leaks near the machine and gas coming out of the gun/ torch when you hit the button. What type of gas do you have? co2 air mix for mig, argon for tig. Is the gas on (stupid sounding question but you never know)? Is the flow rate high enough? depending on machine and wind. On mig it’s about 20-35 gph (or was it liters per hour..... just read what it says on ur machine). Just give everything a good once over and im sure you’ll find the problem, good luck!
Andyrew |
Mar 19 2019, 08:32 PM
mb911 |
Mar 19 2019, 08:44 PM
914 Guru Group: Members Posts: 6,802 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Looks like 100% argon to me.. It will be a sluggish weld.
mgp4591 |
Mar 19 2019, 09:06 PM
914 Guru Group: Members Posts: 5,366 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
roblav1 |
Mar 19 2019, 10:28 PM
I wasn't sure if he's using MIG or TIG. I've always used straight Argon with TIG on steel.
Andyrew |
Mar 19 2019, 10:32 PM
mb911 |
Mar 20 2019, 04:32 AM
BPic |
Mar 20 2019, 04:33 AM
Thanks everyone. I’m running a mig with 75/25. Checked everything, no leaks and replaced the nozzle and tip. I’ll call th gas company.
Thanks again. (IMG:style_emoticons/default/beerchug.gif) |
mb911 |
Mar 20 2019, 05:48 AM
Could be a combo of the gas/windy conditions and base metal changes..
Superhawk996 |
Mar 21 2019, 12:43 PM
Curious, did you get new bottle of gas and did the issue resolve itself?
Playing with welding Titanium. Uses absurd amounts of gas and needs to be purged on the backside. Rest assured, I won't be doing any aircraft welding. Top is absolute crap weld; too much heat not enough gas Middle is getting better but is still crap. (IMG:style_emoticons/default/slap.gif) Bottom; closer yet but I think I need bigger #16 cup and a bit less heat. Should be pure shiny silver. That golden straw color is borderline. Need more practice. (IMG:style_emoticons/default/welder.gif) |
Jeff Hail |
Mar 21 2019, 09:31 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I've been welding in this car for a year and never had anything like this happen. I ran out of gas and the welder was doing fine. Got a new bottle delivered today and hooked it up. When I started welding it sounded different, lots of soot, the metal doesn't puddle the way it did before and the welds look like crap! (IMG:style_emoticons/default/headbang.gif) The other thing that happens is that the wire fuses itself to the gun tip. Settings are the same on the machine and everything was fine. The only thing that changed was a new bottle of gas. I'm sure it's possible for them to put the wrong mix or the wrong gas but before I call them is there something else I should be looking at? (IMG:style_emoticons/default/confused24.gif) Thanks in advance, Brad Try this first. First issue is that steel is coated. Need to grind it clean like that small swipe halfway through the upper weld except everywhere you are going to sample. Pull the nozzle off and clean the slag out as it may be shorting your contact tip causing the wire to stick to the tip. Check the gas diffuser while the nozzle is off while you are in their and make sure its not plugged with slag balls and gas is flowing. Change the tip. Purge both sides of the regulator. Open the tank valve and then while you are squeezing the gun trigger open up the flow regulator to about 45, then wind it back down to normal flow rate . What regulator are you using? C02? C02 with adaptor or an Argon regulator? That rusty almond frost around your welds looks like restricted shielding gas or really low to almost no flow. Gas blends vary by far with industrial suppliers so perfect 75/25 mixes aren't realistic, 75 – 95 percent Argon and 5 – 25 percent CO2 is considered the normal these days when filled from a manifold. Its not much of an issue welding, both work fine even if the blend % is off. Most people would not notice it. Does the tank they gave you have a painted shoulder that's different than the primary color of the tank? If so what color is the shoulder? Last. If you think the fill is contaminated take the tank back and tell them you have a slugged tank, they should exchange it -it happens. |
roblav1 |
Mar 22 2019, 07:52 AM
My issue was bad gas. A new tank and all is well. Never had that happen before.
Mar 22 2019, 08:22 AM
bbrock |
Mar 22 2019, 08:28 AM
My issue was bad gas. A new tank and all is well. Never had that happen before. It happens to all of us. My dog is the worst. Yeah, yeah, I blame my dog too (IMG:style_emoticons/default/biggrin.gif) |
Superhawk996 |
Mar 22 2019, 09:33 AM
Still curious if OP's problem went away.
@Jeff Hail Jeff, any advice on TIG'ing Galvanneal? I've tried grinding it back (both sides) but some of the zinc is actually annealed into the steel and can't be removed by grinding and still leads to electrode contamination and puddle pops. Not an issue for MIG. At this point it's painfully slow with TIG but I'm surviving. However, the thought of going back to a MIG rig has crossed my mind several times now. Best success I've had is by feeding as much filler as quickly as I can. I suspect it helps dilute the zinc in the puddle by getting fresh filler (ER70-S2) in there. Apologize for thread high jack. I'll post fresh thread if I've offended anyone but this appears to have the attention of the welders among us. |
Mark Henry |
Mar 22 2019, 10:36 AM
@Jeff Hail Jeff, any advice on TIG'ing Galvanneal? I've tried grinding it back (both sides) but some of the zinc is actually annealed into the steel and can't be removed by grinding and still leads to electrode contamination and puddle pops. Talk to @Peteyd at Restoration Design besides the panels they do some high end resto's and have a full time metal guy tig welding their panels that are Galvanneal. RD might even have a vid on YT showing how they prep their panels. |
Lo-Fi Version | Time is now: 23rd April 2024 - 01:26 PM |
