Misc 914 parts |
Misc 914 parts |
Pdr1787 |
Apr 2 2019, 12:15 AM
Sneaky Pete Group: Members Posts: 55 Joined: 8-September 09 From: Lakewood, California Member No.: 10,779 Region Association: Southern California |
Here are a bunch of misc. parts for sale. for asking price or better offer
Spark plug wires 8mm ...... 60 *Sold* Original belt restraints ( non retractable )...... 50 *Sold* Rocker-arm hardware (Shaft/springs/nuts/bolts/washers)...... 50 *Sold* Outside door handle ..... 50 *Sold* Speaker cover and speaker ( Driver and Passenger side) ...... 100 Heat exchanger elbow .... 50 Heater control valve flap box ....... 50 Clutch release bearing and fork ...... 150 70-72 complete linkage 80 *Sold* Sideshift linkage rod firewall to transmission...... 150 *Sold* Heater blower fan assembly..... 70 70-72 engine motor mount cross bar...... 50 Foot well foam insert ....... 35 Arm rest pocket and lid cover....... 50 Valve cover pair ........ 60 Shifter assembly ...... 100 *Sold* Shift rod coupler 73-76..... 60 w/bolt/screw.....80 *Sold* Motor support bracket 70-72........ 50 Motor mounts...... pair 40 Clutch cable deflection roller and reverse bracket.......40 *Sold* 2.0l cylinders 4 ............ 180 *Sold* Thermostat...... 80 1.7l ecu Works ....... 80 1.7 rods .... 40 Bosch 1.7distributor with vacuum advance..... 100 Hydraulic lifters 1.7 ......80 Vacuum pressure regulator ...... 80 Porsche valve springs full set 90110590150 ...... 140 Bosch starter .......... 140 Bosch 12volt coil ......50 Bosch 009 chrome .........90 Attached thumbnail(s) |
Chi-town |
Apr 2 2019, 12:56 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Open to offers? I could always use a spare 73-76 shift rod rear section.
Pdr1787 |
Apr 2 2019, 12:25 PM
I am open to offers as well. shoot me a reasonable price. Everything must go!!
(IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/screwy.gif) |
Pdr1787 |
Apr 4 2019, 12:47 PM
Bump
racingredsc |
Apr 12 2019, 10:54 AM
Newbie Group: Members Posts: 18 Joined: 12-April 13 From: Columbia,SC Member No.: 15,762 Region Association: South East States |
What do the heads fit? I need some for '74 2.0.
forrestkhaag |
Apr 13 2019, 09:06 AM
Are the speakers spoken for? And, what condition are they in? cracks /missing pieces, etc? I would offer 60 bucks if they are decent./ please pm me if that works out /
cheers (IMG:style_emoticons/default/beerchug.gif) |
Pdr1787 |
Apr 13 2019, 10:06 PM
Pdr1787 |
Apr 13 2019, 10:09 PM
Are the speakers spoken for? And, what condition are they in? cracks /missing pieces, etc? I would offer 60 bucks if they are decent./ please pm me if that works out / cheers (IMG:style_emoticons/default/beerchug.gif) The actual speakers are in good condition, fairly new. The speaker grills just need to be cleaned and i can post a picture tomorrow after i clean the up. There is a small crack in one of the corners for one grill. will post picture tomorrow |
rasam |
Apr 14 2019, 12:26 AM
Newbie Group: Members Posts: 23 Joined: 10-March 15 From: Santa Fe Springs ca Member No.: 18,508 Region Association: Southern California |
PM sent for the thermostat.
Pdr1787 |
Apr 15 2019, 05:57 AM
What do the heads fit? I need some for '74 2.0. Heads are 2.0L heads. There is damage to one exhaust stud just so you know. Attached thumbnail(s) |
Pdr1787 |
Apr 15 2019, 05:58 AM
Pdr1787 |
Apr 15 2019, 06:00 AM
Are the speakers spoken for? And, what condition are they in? cracks /missing pieces, etc? I would offer 60 bucks if they are decent./ please pm me if that works out / cheers (IMG:style_emoticons/default/beerchug.gif) The actual speakers are in good condition, fairly new. The speaker grills just need to be cleaned and i can post a picture tomorrow after i clean the up. There is a small crack in one of the corners for one grill. will post picture tomorrow Attached thumbnail(s) |
Pdr1787 |
Apr 15 2019, 06:01 AM
Pdr1787 |
Apr 15 2019, 06:02 AM
Here a closer picture of the door handle
racingredsc |
Apr 16 2019, 12:29 PM
I'll take the heads if the only problem is the one stud.
carl k |
Apr 16 2019, 12:47 PM
Member Group: Members Posts: 76 Joined: 19-August 08 From: San Jose, CA Member No.: 9,440 Region Association: None |
Are those modified 1.7/1.8 heads? I see the four studs for the intake manifold.
Pdr1787 |
Apr 16 2019, 02:35 PM
Pdr1787 |
Apr 24 2019, 04:06 PM
Bump (IMG:style_emoticons/default/icon_bump.gif)
bdstone914 |
Apr 27 2019, 08:52 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Are those modified 1.7/1.8 heads? I see the four studs for the intake manifold. They were bored out That does not make them 2.0 heads. Will not fit 2.0 runners. Might he good heads. What are the valve sizes? 1.7, 1.8 and 2.0 all use different size valves. |
Chi-town |
Apr 27 2019, 11:09 PM
They're 2.0 bus heads
Lo-Fi Version | Time is now: 25th April 2024 - 01:52 AM |
