Fuel pump issue, I think I bumped something under the dash |
Mowog4 |
Apr 19 2019, 12:09 PM
Member Group: Members Posts: 285 Joined: 2-November 15 From: Mesa AZ Member No.: 19,325 Region Association: None |
I have a problem with my fuel pump, if I turn the ignition on the fuel pump runs and doesn’t turn off. It used to run for a second to build pressure, them turm off. Any thoughts?
Thanks Ed |
Sea Dragon 914 |
Apr 19 2019, 01:52 PM
Member Group: Members Posts: 114 Joined: 26-February 03 Member No.: 358 Region Association: Northern California |
The pump runs when the ignition is turned off or only when hot? There is a relay on the relay panel in the engine compartment. Could that be sticking?
I don't recall of any relay or fuse on the fuse panel under the dash board. I have a problem with my fuel pump, if I turn the ignition on the fuel pump runs and doesn’t turn off. It used to run for a second to build pressure, them turm off. Any thoughts? Thanks Ed |
Lo-Fi Version | Time is now: 25th April 2024 - 05:02 PM |
