'72 914 Power train swap, Removing V8, installing a .... |
Chris914n6 |
Apr 28 2019, 12:58 AM
Jackstands are my life. Group: Members Posts: 3,393 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
ECU: look into Speeduino. Like Megasquirt with same software but newer tech and half the price.
Gauges: Speedhut. Not cheap but worth it and look appropriate. |
jb6000 |
May 3 2019, 08:06 AM
Member Group: Members Posts: 52 Joined: 15-September 18 From: Ca Member No.: 22,486 Region Association: None |
Thank you for the tips guys. Smart advice.
ajracer |
May 3 2019, 08:02 PM
Member Group: Members Posts: 204 Joined: 18-April 04 From: Toronto, Canada Member No.: 1,945 |
Greetings JB6000:
The Audi transaxle looks very similar to my Audi 6 spd 01X which has 108 mm flanges. I had adapters machined to take the 108 mm >> 100 mm Porsche 944 / 911 CV's. Because the ttranaaxle is offset (centre line) I started with 5/8" adapters recessed bolts to Flanges, used 944T CV's and 911 axles, I believe the axles were 18.5" and 20" (going by memory). After several months realized that the right axle was too short, but after some re-measuring decided to keep what works and then machined thicker adapter on right side; seems to be the best solution. (custom axles would be costly and difficult to source). Sorry I don't have more in common with your project since I am running a Z06 LS6 motor out of a 2004 Vette; and closer to 400HP. Enjoy the project and wish you good success. Allan |
jb6000 |
May 4 2019, 10:33 AM
jb6000 |
May 4 2019, 10:36 AM
jb6000 |
May 4 2019, 10:43 AM
ajracer |
May 4 2019, 07:46 PM
Hi JP6000
Appreciate the follow-up comments and questions; unfortunately I am traveling and don’t have access to the files back home with access to more specific details as the build records so need to go back to reference things. Regarding your layout diagram above, the details are correct except the following items: D – mine uses 944 turbo C/V’s and reason being they are stronger and excellent axle angles. E – Axle measurements will be different as previously mentioned, as well depends up location of your transaxle and ride height of the car. I’ll update later next week on axle length and adapter thickness. F - it is my understanding the C/V’s are measured by their Outside diameters Audi is 108 mm Porsche C/V’s 914, 911, 944 many at 100 mm, 930 & newer Porsche are 108 mm. G - mine was converted to 5 lug 911 flanges / hubs. Hope this will assist you in the process of your project. Allan |
jb6000 |
May 4 2019, 09:53 PM
Allan,
Thanks for sharing your set up. Thanks Mike and Andy and Chris. I would not even have a clue without your help. I guess the axle length will be the last thing I determine, and measure, after everything is mounted. This thread will be here when you get home Allan, Safe travels! Jerry |
jb6000 |
Oct 24 2019, 07:20 PM
jb6000 |
Oct 24 2019, 07:23 PM
Also I bought Renegade rear transaxle mount for the Boxster S trans, and I bought a Shifter and Cables.
With the Renegade rear mounts my front to rear transaxle placement has been defined. Need to fab motor mounts next ... |
jb6000 |
Oct 24 2019, 08:49 PM
Side view.
I made it fatter so I could drill and tap the 4 Bolt holes deeper. Plans available on this forum. Attached thumbnail(s) |
jb6000 |
Oct 27 2019, 08:50 AM
jb6000 |
Oct 27 2019, 09:34 AM
I think I need a 12v 1 amp diode so the alt does not feed the coil +
FL000 |
Oct 27 2019, 11:09 AM
Member Group: Members Posts: 421 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
jb6000 |
Feb 15 2020, 12:39 PM
I need to fab some motor mounts parts next.
Daryl32 |
Feb 15 2020, 12:54 PM
Member Group: Members Posts: 133 Joined: 14-January 20 From: Southern California Member No.: 23,827 Region Association: Southern California |
jb6000 |
Jun 12 2020, 08:54 PM
Has anyone Putting a Boxster S transaxle in a 914 ....
Used the Boxster axles, hubs, rotors, calipers? Just wonder if it's been done. I found some threads on it. Looking in to it. |
jb6000 |
Jul 24 2020, 11:45 PM
If you look on youtube for 914outlaw you will find more great infomation on this build.
Andrew has laid out how to set up a very efficient radiator system and water to air intercooler for this swap, on a budget. |
jb6000 |
Apr 1 2021, 09:20 PM
Mike Bellis mentioned these cv joints:
https://www.rcvperformance.com/ultimate-930...-28-spline.html Nice parts! Thank you Mike! |
Lo-Fi Version | Time is now: 27th September 2024 - 11:30 AM |
