Rear Trunk Stuck Locked - Top Inside |
CoronaMike |
May 20 2019, 11:28 AM
Member Group: Members Posts: 152 Joined: 11-February 19 From: Maryville, TN Member No.: 22,868 Region Association: South East States |
Hi all,
So - not sure why it did this the other day, but I went to lock the trunk and the button got stuck pushed in and horizontal - locked. I was able to get the key out - but it was stuck. I've seen the 'go through the targa cap' procedure - **but my top is in the trunk.** I thought if I drilled the lock out that might help - so i did. The button popped back out - but - it's still locked. I'm a little worried here - ideas? (IMG:style_emoticons/default/confused24.gif) Thanks!! Mike |
76-914 |
May 20 2019, 11:53 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,455 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Hi all, So - not sure why it did this the other day, but I went to lock the trunk and the button got stuck pushed in and horizontal - locked. I was able to get the key out - but it was stuck. I've seen the 'go through the targa cap' procedure - **but my top is in the trunk.** I thought if I drilled the lock out that might help - so i did. The button popped back out - but - it's still locked. I'm a little worried here - ideas? (IMG:style_emoticons/default/confused24.gif) Thanks!! Mike Remove the hinges via the engine compartment. (IMG:style_emoticons/default/beerchug.gif) |
CoronaMike |
May 20 2019, 12:28 PM
Will the whole lid lift off if I do that?
May 20 2019, 12:42 PM
914-6 GT in waiting Group: Members Posts: 19,142 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
CoronaMike |
May 20 2019, 12:46 PM
ok - thanks guys! Looks like I have a lunch time project. (IMG:style_emoticons/default/smile.gif)
rhodyguy |
May 20 2019, 01:00 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,042 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Did you try spraying lubricant in the key slot? How worn is your key? I thought going thru the firewall holes was to remove the latching assem from the rear facia. Don't see how the lid will lift off when it's still secured at the back. The hinge arms are under a lot of pressure from the torsion springs. The top being in the trunk poses a problem. If the front top latches are in the holes, how are you going to push push the white cups in to the trunk?
CoronaMike |
May 20 2019, 02:35 PM
Well, I wasn't going to do the plastic cup method *because the top is in there. But I do share your concerns with the torsion springs. :/
76-914 |
May 20 2019, 02:59 PM
You can insert a 1x4 into the saddle part of the hinge. Then back out the bolts. (IMG:style_emoticons/default/beerchug.gif)
a scrap 1x4 then do this |
rhodyguy |
May 20 2019, 06:55 PM
I would drill out the lock cyl before I'd jump all of those hoops. Decent ones are avail. Rekey. Easier to replace than a rear deck.
The button is stuck in? Did you try gently pushing down on the radius of the lid center? |
Chi-town |
May 20 2019, 08:05 PM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
Go to harbor freight, buy a small pick set. Use the 90 degree pick in the key hole to pull the button back out.
Use the key to turn the lock and then push back in to open the trunk. |
sb914 |
May 20 2019, 08:21 PM
Surf Guru Group: Members Posts: 4,292 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
worn |
May 20 2019, 09:33 PM
can't remember Group: Members Posts: 3,129 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Hi all, So - not sure why it did this the other day, but I went to lock the trunk and the button got stuck pushed in and horizontal - locked. I was able to get the key out - but it was stuck. I've seen the 'go through the targa cap' procedure - **but my top is in the trunk.** I thought if I drilled the lock out that might help - so i did. The button popped back out - but - it's still locked. I'm a little worried here - ideas? (IMG:style_emoticons/default/confused24.gif) Thanks!! Mike If you can find another 914 it will help you understand what is going on and what you need to do. I was locked out of my blood pressure meds 1000 miles from home last year. Luckily my top was above the seats instead of being in the trunk. Usually the problem is a broken off die cast pin. Helps if you can see one with the trunk open. Good luck! |
CoronaMike |
May 21 2019, 09:27 AM
You can insert a 1x4 into the saddle part of the hinge. Then back out the bolts. (IMG:style_emoticons/default/beerchug.gif) a scrap 1x4 Awesome - thanks for taking the time with the pictures - i appreciate it! **Actually - hey, you're in temecula... be there in an hour. (IMG:style_emoticons/default/wink.gif) lol |
CoronaMike |
May 21 2019, 09:32 AM
Mike [/quote] If you can find another 914 it will help you understand what is going on and what you need to do. I was locked out of my blood pressure meds 1000 miles from home last year. Luckily my top was above the seats instead of being in the trunk. Usually the problem is a broken off die cast pin. Helps if you can see one with the trunk open. Good luck! [/quote] Hi Worn - Yeah, I read your post before I asked the group. You're lucky your top wasn't in. I think I'm going to have to try the lid removal. :/ |
CoronaMike |
May 21 2019, 04:04 PM
Ok - so I took of the top bolt on both sides (pic 1). It kinda made a popping sound and the lid kind of popped up in the back on both sides (pic 2) - but it's still solidly not moving. Do I need to take out the bottom bolts too? (pic 3).
Also - do I need to take out the torsion bars too? thanks! Pic 1: Pic 2: Pic 3: |
rhodyguy |
May 21 2019, 04:19 PM
Fun fact, those torsion rods are under incredible pressure with the lid closed. Lots of Pressure even with the lid raised. I think you're stuck until you release the latch. What ever it takes without doing further damage.
CoronaMike |
May 21 2019, 04:35 PM
Fun fact, those torsion rods are under incredible pressure with the lid closed. Lots of Pressure even with the lid raised. I think you're stuck until you release the latch. What ever it takes without doing further damage. I read somewhere that someone drilled a small hole under the lock in back and pushed some sort of rod in there to unlatch it. I might be getting desperate here. |
CoronaMike |
May 21 2019, 08:19 PM
**update**
Ok - I got it open. I kinda wish I woulda just done this first. If you drill a little hole coming up from where the top of the license plate is - and if you finagle around in there with a long screwdriver long enough - it will pop open. The harder part was then getting the bolts back in the hinges in the engine compartment. But I'm just glad it's done. Next stop - finding a new lock button. (IMG:style_emoticons/default/smile.gif) |
rhodyguy |
May 22 2019, 07:59 AM
Nice save. Spring for new rollers. Put the rods off of the rollers with a 10mm? DEEP, short ones tend to slip off, socket on the rods and an extension as a lever. Clean and lightly lube the roller posts. Should take 10-15 minutes.
FL000 |
Jun 9 2019, 04:44 PM
Member Group: Members Posts: 386 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
This thread just saved me some time and money! Got home from WCR and couldn't open rear trunk (IMG:style_emoticons/default/blink.gif) . Luggage blocked the bolts by lock cylinder to try and gain access from inside (V8 distributor cutout or targa cups). Inconspicuous hole above license as you did got the job done. Now I have an alternate access to boot if it happens again.
(IMG:style_emoticons/default/beerchug.gif) Josh |
Lo-Fi Version | Time is now: 29th March 2024 - 05:34 AM |
