Would you believe...? |
second wind |
May 21 2019, 08:42 PM
Senior Member Group: Members Posts: 850 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Would you believe that I use JB WELD QUIK WELD to glue washers and nuts to my fingers so I can finish putting my new dash together?? With hands like catcher's mitts and impossible to use tools in those micro spaces....seems to be working. The lower dash nut holders all pop out and don't go back in very well.....so now new bolts, washers and nuts doing the job. Super glue didn't work so JB Quik really is the answer....dash is looking great....more adjustments to do with the side screws.....has anyone ever done this? All the best,
gg |
bretth |
May 21 2019, 10:05 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
This isn't something I have done on my car yet but what about gluing a small strong magnet to a glove finger tip instead?
oakdalecurtis |
May 21 2019, 10:18 PM
Oakdalecurtis Group: Members Posts: 1,323 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California |
Nuts are plastic, magnet won’t help. Get a small metric bolt that the nuts will thread on to. Grind the bolt head down until it’s very thin. Glue the bolt head to the tip of your index finger, then thread each nut on a few turns, then reach under the dash and line up the nut with the stud. A few turns on the nut with your thumb will transfer the nut off the bolt and onto the stud. Easy peasy...
(IMG:style_emoticons/default/beerchug.gif) |
sb914 |
May 22 2019, 06:13 AM
Surf Guru Group: Members Posts: 4,296 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Mark Henry |
May 22 2019, 07:28 AM
Putting the newer P-car back together is just as bad, once a customer says IMS and AOS in the same sentence I just drop the engine/trans.
I can put a nut and washer on with two fingers. (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 24th April 2024 - 07:20 PM |
