Wiper system install, Re-installing the wiper system - flange & rubber bushing ? |
anthwp |
May 22 2019, 09:44 AM
Newbie Group: Members Posts: 10 Joined: 6-June 17 From: Vail, CO Member No.: 21,157 Region Association: Rocky Mountains |
I am reinstalling the wiper system after needing to replace the broken flex bolt / shake proof bolt which had broken. With this I am replacing all of the rubber bushings for the wiper arms.
The question is in the parts list it has a flange washer item 6, followed with two rubber bushings (Female item 7) and (Male item 8 )followed by another flange item 6. Where does these part sit on the arm? Are all 4 parts above the body grill or does a flange with the female bushing sit under the body grill and the two remaining parts the male bushing and the top flange mount outside - on top on the body? Or does all 4 items mount on top on the body grill ? |
914werke |
May 22 2019, 09:52 AM
"I got blisters on me fingers" Group: Members Posts: 9,894 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
its a sandwich seal assembly. The chromed(?) "flange" washers capture the M/F rubber seals as they sandwich the cowl to seal the wiper shaft well.
Lo-Fi Version | Time is now: 29th March 2024 - 05:38 AM |
