WTB 1974 2.0L Fuel Injector |
Rsjg911 |
Jul 18 2019, 10:51 AM
Member Group: Members Posts: 89 Joined: 13-June 16 From: Weston, Florida Member No.: 20,105 Region Association: South East States |
Hi Guys:
I am looking for 1 fuel injector for a 1974 914 2.0 L. The Porsche number is 039 906 031 and the Bosch number is 0 280 150 019. Thanks! Ron |
914Sixer |
Jul 18 2019, 11:05 AM
914 Guru Group: Members Posts: 8,845 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Replacement part is Standard Motor Parts FJ 67.
euro911 |
Jul 18 2019, 01:26 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Rsjg911 |
Jul 18 2019, 02:53 PM
Replacement part is Standard Motor Parts FJ 67. Hi Sixer: Thanks much for your reply! I previously purchased a Standard Motor Parts FJ67 injector. The injector I received was from Intermotor (SMP FJ67.) I installed it but the electrical connection would not slide into the housing. Also, I noticed that the injector end was about 1/4" shorter and there were 3 sprayers at the tip, not 1 that I have on my original injector. I looked on eBay, Amazon, etc but all of the Standard Motor Parts injectors seem to be identical to the one I received from Intermotors. I did see an injector manufactured by G.P. Sorensen (Part # 800 1061N) on AutoZone's website that looked the same but the part is no longer available and I have not been able to locate another distributor. I also heard from a rebuilder that Lucas makes a good replacement but don't have a part number. The rebuilder also said that Air Tex makes an acceptable injector but not as good as Lucas in his opinion. I am at a loss at this point. Help!!! |
Rsjg911 |
Jul 18 2019, 02:56 PM
Hi Euro and thanks for your reply. Please see my response to Sixer. I looked on Rock Auto and the part appears to be the Intermotor injector by Standard Motor Parts with the FJ67 SKU. It doesn't work with my electrical connection. Gaaaaaa! Any other ideas? Thanks, Ron |
euro911 |
Jul 18 2019, 05:57 PM
Ron, since I'm not sure what your particular situation is, lemme ask some questions.
1. Are you missing an injector? ... or ... 2. Do you have one that's leaking? ... or ... 3. Do you need another one because one of them stopped working? The reason I ask, if it's the later, have you thought about sending it (or all of them) out to a refurbishing company? |
Dominic |
Jul 18 2019, 10:16 PM
Dominic Group: Members Posts: 990 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
PM Sent
JeffBowlsby |
Jul 19 2019, 04:48 PM
914 Wiring Harnesses Group: Members Posts: 8,439 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
The website photos show the Standard Motor Parts FJ 67 as a D-Jet injector, which is the correct style and connector for a 74 2.0L.
So what injection do you have on that motor...L-Jet? Posting photos of your harness connector and the injector you received would be helpful. |
Rsjg911 |
Jul 24 2019, 09:06 AM
Ron, since I'm not sure what your particular situation is, lemme ask some questions. 1. Are you missing an injector? ... or ... 2. Do you have one that's leaking? ... or ... 3. Do you need another one because one of them stopped working? The reason I ask, if it's the later, have you thought about sending it (or all of them) out to a refurbishing company? Hi and thanks for your reply. My current injector is leaking. It works but gas is getting into the engine compartment. I changed the inner a d outer seals and fuel line but still have a leak so assume it is the onjector. Any help is much appreciated. Ron |
Rsjg911 |
Jul 24 2019, 09:15 AM
The website photos show the Standard Motor Parts FJ 67 as a D-Jet injector, which is the correct style and connector for a 74 2.0L. So what injection do you have on that motor...L-Jet? Posting photos of your harness connector and the injector you received would be helpful. Hi Jeff: Thanks for your help. Here are two photos. Hope they help. I switched out the inner and outer seals and fuel line but still have a leak. Not sure where it is coming from though. I appreciate your help. Best Ron |
Rsjg911 |
Jul 24 2019, 09:16 AM
Rsjg911 |
Jul 26 2019, 08:14 AM
The website photos show the Standard Motor Parts FJ 67 as a D-Jet injector, which is the correct style and connector for a 74 2.0L. So what injection do you have on that motor...L-Jet? Posting photos of your harness connector and the injector you received would be helpful. Hi Jeff: Thanks for your help. Here are two photos. Hope they help. I switched out the inner and outer seals and fuel line but still have a leak. Not sure where it is coming from though. I appreciate your help. Best Ron Bump |
jdadams |
Sep 20 2019, 06:03 PM
I'm new here ... Group: Members Posts: 0 Joined: 20-September 19 From: fountain valley Member No.: 23,481 Region Association: None |
bdstone914 |
Sep 21 2019, 05:58 AM
bdstone914 Group: Members Posts: 4,496 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Hi Guys: I am looking for 1 fuel injector for a 1974 914 2.0 L. The Porsche number is 039 906 031 and the Bosch number is 0 280 150 019. Thanks! Ron I have 2 NOS ones for $125 each P/N 0280150038 Those are a different part number and probabky for 1975-76 2.0l engines. I think the flow rate is different. |
Lo-Fi Version | Time is now: 29th March 2024 - 03:21 AM |
