WTB a few small parts, Found some bits but need more |
porschetub |
Aug 2 2019, 01:33 AM
Advanced Member Group: Members Posts: 4,696 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor.
Need; 1 x metal 3 bolt spacer behind crank fan 1 x thermostat mounting bracket ,found one online 2 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate. 1 x 3 pin altenator plug 1 x working thermostat, found one thanks Mike B 1 x dipstick Still looking thanks. Shipping to Portland Oregon 97203. TIA. |
Tbone425 |
Aug 2 2019, 07:14 PM
Newbie Group: Members Posts: 43 Joined: 15-August 15 From: AZ/WA Member No.: 19,065 Region Association: Southwest Region |
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I might have some of this stuff in my free bin at the John Walker Porsche swap meet tomorrow in Seattle. |
Tbone425 |
Aug 2 2019, 07:19 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I have an ....020 afm no ide if it will work, but you can have it if you think it will. |
porschetub |
Aug 2 2019, 07:51 PM
PM on the way,thanks so much (IMG:style_emoticons/default/biggrin.gif) .
porschetub |
Aug 13 2019, 02:10 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind fan 2 x thermostat mounting brackets 3 x small spring steel tabs that hold the fan housing flap pivot rod 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. 1 x working thermostat (yes I know),a T1 original would do. Shipping to Portland Oregon 97203. TIA. Bump |
Dominic |
Aug 13 2019, 06:49 PM
Dominic Group: Members Posts: 990 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
I should have the following parts, but I will need a few days to find all of them:
1 x metal 3 bolt spacer behind fan 2 x thermostat mounting brackets (I know I have at least one) 1 x crankcase metal cover and bolt for oil strainer 1 x working thermostat (I have a T1 thermostat) Thanks, Dominic |
Mblizzard |
Aug 13 2019, 07:29 PM
I have a dizzy clamp and thermostat.
porschetub |
Aug 14 2019, 12:42 AM
Thanks Mike and Dominic ,keen as thanks
porschetub |
Aug 14 2019, 05:11 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 2 x thermostat mounting brackets 2 x dizzy clamps 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. Shipping to Portland Oregon 97203. TIA. I have an ....020 afm no ide if it will work, but you can have it if you think it will. Still keen to sell the AFM if you still have it?,cheers. |
porschetub |
Aug 14 2019, 10:59 PM
I should have the following parts, but I will need a few days to find all of them: 1 x metal 3 bolt spacer behind fan 2 x thermostat mounting brackets (I know I have at least one) 1 x crankcase metal cover and bolt for oil strainer 1 x working thermostat (I have a T1 thermostat) Thanks, Dominic Cheers when you get time will take all,thanks. |
porschetub |
Aug 16 2019, 03:46 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind crank fan 2 x thermostat mounting brackets 3 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. 1 x working thermostat (yes I know),a T1 original would do as better than nothing. 1 x dipstick Shipping to Portland Oregon 97203. TIA. Bump |
porschetub |
Aug 28 2019, 08:31 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind crank fan 2 x thermostat mounting brackets 3 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. 1 x working thermostat (yes I know),a T1 original would do as better than nothing. 1 x dipstick Shipping to Portland Oregon 97203. TIA. Bump. |
porschetub |
Aug 28 2019, 09:37 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind crank fan 2 x thermostat mounting brackets 3 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. 1 x working thermostat (yes I know),a T1 original would do as better than nothing. 1 x dipstick Shipping to Portland Oregon 97203. TIA. Bump. Have found thermostat thanks to Mike B. Still need the rest,thanks. |
porschetub |
Sep 14 2019, 01:58 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind crank fan 2 x thermostat mounting brackets 3 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working afm for 1.8 L-jet part Bosch number 0 280 200 012. 1 x working thermostat (yes I know),a T1 original would do as better than nothing. 1 x dipstick Shipping to Portland Oregon 97203. TIA. BUMP |
porschetub |
Sep 20 2019, 02:22 AM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Need; 1 x metal 3 bolt spacer behind crank fan 1 x thermostat mounting bracket ,found one online 2 x small spring steel tabs that hold the fan housing flap pivot rod. 1 x crankcase metal cover and bolt for oil strainer 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate. 1 x 3 pin altenator plug 1 x working thermostat, found one thanks Mike B 1 x dipstick Still looking thanks. Shipping to Portland Oregon 97203. TIA. BUMP. |
porschetub |
Sep 23 2019, 01:35 PM
Hi all,need the following small parts to complete current engine build and parts for the L-jet 1.7 motor. Still need; 1 x working or serviceable afm for 1.8 L-jet part Bosch number 0 280 200 012,must have free moving air gate . Thanks. Shipping to Portland Oregon 97203. TIA. |
Lo-Fi Version | Time is now: 19th April 2024 - 02:37 AM |
