Intermittent right turn signal not working |
gfrewin |
Aug 9 2019, 01:14 PM
Newbie Group: Members Posts: 23 Joined: 2-May 18 From: Burlington, Ontario Member No.: 22,091 Region Association: Canada |
So driving my 72 today I noticed that the right turn signal is not working consistently. The left is functioning fine but when using the right I can hear the relay going but the interior indicators and exterior flashers aren't working.
Some time they kick in after a few... sometimes they don't. If I shut them off and back on it seems to work most of the time. I assume this could be relay forward but I'm curious if anyone else has experienced this and what the fix was for them. Thanks, G. |
porschetub |
Aug 9 2019, 02:21 PM
Advanced Member Group: Members Posts: 4,725 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Remove the switch assembly and clean the contacts,mine were all gummed and did the same thing but on both directions ,do your wiper switch @ the same time,good luck.
Spoke |
Aug 10 2019, 05:59 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Remove the switch assembly and clean the contacts,mine were all gummed and did the same thing but on both directions ,do your wiper switch @ the same time,good luck. (IMG:style_emoticons/default/agree.gif) The left and right turnsignals use the relay the same way. The only difference is the turnsignal switch and external bulbs. Try the 4-ways. If the right side blinks ok then it's your switch or the wiring to/from the switch. |
gfrewin |
Aug 11 2019, 12:35 PM
Thanks very much. Yeah I've determined it's definitely the switch.
Any recommendation on a good electronic grease to use? |
Lo-Fi Version | Time is now: 27th September 2024 - 12:17 PM |
