Media Blast My 70 Shell, Need Guidance in the PNW |
gcrotvik |
Aug 12 2019, 10:59 AM
Member Group: Members Posts: 361 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
I have a 70 shell that I will be doing a color change on. It has been recommended that I have the outer surfaces (fenders, doors, rear quarter panels and hoods) be hand stripped to maintain the surface substrates.
I would like to have the rest of the car media blasted to remove the paint. There are many thoughts/threads on this topic. I am in the PNW (Portland). If you have had experience with media blasting your car/parts I would be interested in hearing your experience with vendors and media types used. Thanks, Greg |
IronHillRestorations |
Aug 12 2019, 11:38 AM
I. I. R. C. Group: Members Posts: 6,761 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
Whatever you do Greg, don't get it dipped. Hand chem stripping is effective, and when done right, probably the least invasive. I tape off the edges and seams so the paint stripper doesn't get where I don't want it to go.
That said, I'd probably look for a shop that does soda blasting, then have the metal acid etched and epoxy primered |
914werke |
Aug 12 2019, 11:41 AM
"I got blisters on me fingers" Group: Members Posts: 10,553 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Ive done a few cars now. Both Plastic/Sand & soda. The Soda wont touch rust or seam sealer. The plastic/sand will rid the chassis of the rust but you will STILL have to manually remove the sealer or run the risk of rust coming back from beneath those areas.
The sand has the benefit of exposing areas the will become to thin to retain. The plastic is for the large surface areas as it doesn't heat the panels that can cause warpage. Cost wise on a 914 where ALL the areas are affected it been a year or since last but was about $1500 for full car either process |
Aug 12 2019, 11:48 AM
914-6 GT in waiting Group: Members Posts: 19,518 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
We have a blast company about 90 minutes away. We get it done with plastic media. If plastic gets in the cracks, it won't absorb moisture and doesn't need to be neutralized like soda. It won't remove rust, I think they use garnet for the rusty parts and it won't take off tar or undercoating. Cost $900-1,200 depending on the car.
For high end builds, we send it down south to get dipped. they neutralize it and send it back. we do metalwork and then send it back down for e-coat. We once had it e-coated right after dipping but then we still had to do rust repair. There is no perfect method. |
914werke |
Aug 12 2019, 11:51 AM
Mark how much does a dip/neutralize then E-coat cost?
gcrotvik |
Aug 12 2019, 12:06 PM
In hindsight, I should have added in my initial post that the car has already been repaired to remove 98% of the rust. There may be a spot of surface rust here and there.
If I went the dip and then e-coat route, I would need to remove the paper air tubes from the inner rockers beforehand. If true then I would need to open the outer rockers when there is no real need to (although it would be nice to know there is NO rust anywhere). What about dipping and e-coating the hoods, door, rockers, and valences and having them e-coated and plastic media blast the shell? |
sixnotfour |
Aug 12 2019, 12:10 PM
914 Wizard Group: Members Posts: 10,525 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Aug 12 2019, 12:19 PM
Mikey914 |
Aug 12 2019, 12:43 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I have a local guy that is reasonable. You can see what he did for me here -
http://www.914world.com/bbs2/index.php?sho...y+with+stripper he is mobile, so can come to you, or take to the coast in Tillamook. That's where the black car will be going. He can do spot, or the whole thing. Used him on Taylor's car also - http://www.914world.com/bbs2/index.php?sho...;hl=taylors+wes When you're done you can use an acid etch primer to seal. He uses an iron phosphate so it will not flash rust, but if you leave it in a high moisture environment it will start to. |
Superhawk996 |
Aug 12 2019, 01:14 PM
914 Guru Group: Members Posts: 6,469 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
We get it done with plastic media. If plastic gets in the cracks, it won't absorb moisture and doesn't need to be neutralized like soda. There is no perfect method. (IMG:style_emoticons/default/agree.gif) Note on sand. Have all holes (no matter how small - like sheet metal screw holes) plugged robustly before any blasting starts. Put screws back in the screw holes, plug the longitudinal holes, etc. Otherwise you'll be getting sand out from random places for the next 10 years. Ask me how I know this. (IMG:style_emoticons/default/sad.gif) I did my 1st car myself and learned at the school of hard knocks. As pointed out with soda, sand will also hold moisture and promote rust. Currently working on a previous Florida car. Same deal. Sand in Longs, sand in front rails below the gas tank. Sand in the tunnel. All these areas are shot from that sand which was also potentially salty beach sand. (IMG:style_emoticons/default/sad.gif) |
Lo-Fi Version | Time is now: 27th September 2024 - 01:20 PM |
