WTB, Clamp |
WTB, Clamp |
yoursurfer |
Sep 8 2019, 08:29 AM
Newbie Group: Members Posts: 40 Joined: 20-May 06 From: Salado Texas Member No.: 6,036 Region Association: None |
I need the metal clamp ring that goes around the rubber shifter boot at rear of car, it oval shaped,t hey sell the replacement rubber but cant find clamp
RohJay |
Sep 8 2019, 08:36 AM
Member Group: Members Posts: 189 Joined: 24-April 07 From: Colombo, SRI LANKA Member No.: 7,689 |
I need the metal clamp ring that goes around the rubber shifter boot at rear of car, it oval shaped,t hey sell the replacement rubber but cant find clamp This clamp? https://900designs-container.zoeysite.com/s...mission-cover-1 |
yoursurfer |
Sep 8 2019, 08:39 AM
I need the metal clamp ring that goes around the rubber shifter boot at rear of car, it oval shaped,t hey sell the replacement rubber but cant find clamp This clamp? https://900designs-container.zoeysite.com/s...mission-cover-1 the one that broke on my car is a tail shifter type, silver in color adjustable |
Chi-town |
Sep 8 2019, 09:49 AM
Senior Member Group: Members Posts: 850 Joined: 31-August 18 From: Disneyland Member No.: 22,446 Region Association: Southern California |
That's probably a hose clamp someone installed.
the link above is the correct clamp |
yoursurfer |
Sep 8 2019, 10:13 AM
bdstone914 |
Sep 8 2019, 11:55 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@yoursurfer @Chi-townpo
That's probably a hose clamp someone installed. the link above is the correct clamp [/quote] Thanks for the info [/quote] . Tail shift do not use that clamp. |
yoursurfer |
Sep 8 2019, 12:10 PM
[quote name='bdstone914' date='Sep 8 2019, 09:55 AM' post='2745251']
@yoursurfer @Chi-townpo That's probably a hose clamp someone installed. the link above is the correct clamp [/quote] Thanks for the info [/quote] . Tail shift do not use that clamp. [/quote] Well has does that platic cover stay on them? |
euro911 |
Sep 8 2019, 01:44 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
I see you have two 914s that would normally have side-shifter transaxles, although I have seen tail-shifters in late cars (I owned one before converting it back to a side-shift) (IMG:style_emoticons/default/shades.gif)
It may be to your advantage if you post a pic of your shifting linkage so you get the correct part (IMG:style_emoticons/default/idea.gif) |
Mikey914 |
Sep 10 2019, 03:41 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This may help
Side shift https://900designs-container.zoeysite.com/9...from-model-1973 Tail shift https://900designs-container.zoeysite.com/9...from-model-1973 |
yoursurfer |
Sep 10 2019, 03:30 PM
This may help Side shift https://900designs-container.zoeysite.com/9...from-model-1973 Tail shift https://900designs-container.zoeysite.com/9...from-model-1973 Thanks to all who gave me guidance, I ordered on front link above |
euro911 |
Sep 10 2019, 04:22 PM
This is the tail shift diagram.
The rear cover (#51) is NLA IIRC https://900designs-container.zoeysite.com/9...mission-control |
Lo-Fi Version | Time is now: 25th April 2024 - 10:12 AM |
