No Lights ! |
No Lights ! |
63acornwall |
Sep 10 2019, 10:56 AM
Member Group: Members Posts: 53 Joined: 24-January 19 From: London , UK Member No.: 22,823 Region Association: None |
When I operate the light switch on dash nothing happens - no panel lights , no side lights , no headlamps popping up . All worked ok before and will go have a look with a multimeter tomorrow . Suspect switch as there are 6 or so independent fuses protecting individual items and doubt they have all failed at same time .
Hazard lights work off their switch , turn indicators work off their stalk , reversing lights ( backup lights ) work when reversing . What shall I try ? |
lierofox |
Sep 10 2019, 12:03 PM
Member Group: Members Posts: 256 Joined: 23-June 15 From: Paso Robles, CA Member No.: 18,880 Region Association: Southern California |
When I operate the light switch on dash nothing happens - no panel lights , no side lights , no headlamps popping up . All worked ok before and will go have a look with a multimeter tomorrow . Suspect switch as there are 6 or so independent fuses protecting individual items and doubt they have all failed at same time . Hazard lights work off their switch , turn indicators work off their stalk , reversing lights ( backup lights ) work when reversing . What shall I try ? From what you've described I'd start by checking for +12v battery voltage at Terminal #30 on the headlight switch, which should be fed from the back-side (un-fused side) of fuse #10. Make sure neither of those are loose or popped out. Might also check Terminal 15 which should have +12v when the key is on. |
63acornwall |
Sep 10 2019, 11:57 PM
Thanks for that lierofox , will save a lot of time !
Lo-Fi Version | Time is now: 19th April 2024 - 07:56 AM |
