GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
Mikey914 |
Oct 15 2019, 11:43 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the outer scraper on the late cars were superseded with the 911 profile.
Yes it's a more robust profile, but it also grips the glass more. This is even more true when it's new. So some have lubricated them, others have baked them both with some success, but the real problem is it was never really designed for the application. So you all know me I can't just leave something alone. we made a significant improvement to the product. See the seal that is like OEM below. Attached thumbnail(s) |
Mikey914 |
Oct 16 2019, 12:05 AM
Here's the solution.
We've added a strip of fuzzey to the scraper edge. Allowing the window to slide easily on the new "buffer" These will be $7 each side retail in the future, but we are starting a GB for $9.99 a set. SO who can use a set? Attached thumbnail(s) |
ndfrigi |
Oct 16 2019, 12:15 AM
Advanced Member Group: Members Posts: 2,926 Joined: 21-August 11 From: Orange County Member No.: 13,474 Region Association: Southern California |
Mark, 1 set for me pls.
Noel |
Tbrown4x4 |
Oct 16 2019, 02:37 AM
Senior Member Group: Members Posts: 699 Joined: 13-May 14 From: Port Orchard, WA Member No.: 17,338 Region Association: None |
Yes. I've needed these for a while. 1 set please.
mlindner |
Oct 16 2019, 04:21 AM
Senior Member Group: Members Posts: 1,509 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
Yes, I'll take a set. Mark
barefoot |
Oct 16 2019, 05:38 AM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
I'm in for a set
Barefoot |
DRPHIL914 |
Oct 16 2019, 06:08 AM
Dr. Phil Group: Members Posts: 5,758 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
yep, I am in for a set
dlee6204 |
Oct 16 2019, 06:38 AM
In for a set
ValcoOscar |
Oct 16 2019, 06:52 AM
Garage Life Group: Members Posts: 2,373 Joined: 19-November 13 From: SoCal Member No.: 16,669 Region Association: Southern California |
(IMG:style_emoticons/default/piratenanner.gif) For now, 4 sets please (IMG:style_emoticons/default/hide.gif)
Oscar |
andreic |
Oct 16 2019, 07:43 AM
Member Group: Members Posts: 172 Joined: 21-December 15 From: Madison, WI Member No.: 19,479 Region Association: Upper MidWest |
Do they also work on early cars? Or if not, are there scrapers for the early cars at 914rubber?
Jett |
Oct 16 2019, 08:32 AM
Senior Member Group: Members Posts: 1,630 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
I’ll take a set... the old style although good they do make it hard to roll the window down (IMG:style_emoticons/default/sad.gif)
aharder |
Oct 16 2019, 08:35 AM
Advanced Member Group: Members Posts: 4,365 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
I'm in for a set (IMG:style_emoticons/default/biggrin.gif)
DucRS |
Oct 16 2019, 08:40 AM
Member Group: Members Posts: 105 Joined: 29-May 19 From: Riverbank CA Member No.: 23,173 Region Association: Central California |
Ill Take a set.
76-914 |
Oct 16 2019, 08:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,485 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
2 sets for another 914Rubber Junkie. (IMG:style_emoticons/default/beerchug.gif)
jcd914 |
Oct 16 2019, 08:52 AM
I'm in for a set.
Just replaced most of the seals on my 914 and was disappointed in these seals. The window wants to bind and I figure the regulator will fail soon. Jim |
moldygreg |
Oct 16 2019, 09:11 AM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
Im' in!
I too had the problem mentioned ^ with the current offering. |
rhodyguy |
Oct 16 2019, 09:13 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,055 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Don't forget about the 'U' guide in the vertical channels. F&R. Unless you've replaced them, figure they're 40 years old. Replace those shoddy end caps while doing the squeegees. All part of the system.
Mikey914 |
Oct 16 2019, 09:36 AM
Don't forget about the 'U' guide in the vertical channels. F&R. Unless you've replaced them, figure they're 40 years old. Replace those shoddy end caps while doing the squeegees. All part of the system. You are correct. I will put together special pricing for those that replace their scraper seals (and will put the other on sale too. May take me a day or two to get the listings up, but will make a nice set. Heck I'll even throw in a version to get the inner fuzzey too. You know, while you are there.......... |
rhodyguy |
Oct 16 2019, 09:46 AM
I think the channel guides would be a big seller. I did mine years ago. Made a huge dif. Why take the door cards off repeatedly? Once and done. Make your own vapor barriers out of 6mil plastic and stick them on with double sided tape.
seanpaulmc |
Oct 16 2019, 10:03 AM
Member Group: Members Posts: 297 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States |
In for a set.
Lo-Fi Version | Time is now: 19th April 2024 - 10:24 PM |
