Rebuiding Inside-out |
bkrantz |
Feb 13 2021, 08:19 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Timing for the buffing. I started with black on one cotton wheel.
Attached thumbnail(s) |
bkrantz |
Only about 10 minutes got this.
bkrantz |
Feb 13 2021, 08:20 PM
And then white compound.
bkrantz |
Feb 13 2021, 08:21 PM
Another 10 minutes. I like it.
I need to go back and dress the edges a bit more, and then think about sealing. Attached thumbnail(s) |
bkrantz |
Feb 13 2021, 08:23 PM
But I made another problem for myself. The polished window track from the original right door looks so good, it makes the track from the replacement left door look bad.
bkrantz |
Feb 13 2021, 08:25 PM
Although it was never sanded, it has some big scratches near the upper end.
Now where did I put the original left door? Attached thumbnail(s) |
jaredmcginness |
Feb 13 2021, 09:58 PM
... Group: Members Posts: 504 Joined: 12-June 19 From: Baltimore Member No.: 23,209 Region Association: MidAtlantic Region |
Taking care of business! As always!
Cheers |
bkrantz |
Feb 14 2021, 07:59 PM
bkrantz |
Feb 14 2021, 08:02 PM
So, after at least of foot of snow and blowing wing all night, I went to fetch the spare (original) left door. I was in a hurry to get the door, so did not take a photo then. Here is the spot.
bkrantz |
Feb 14 2021, 08:05 PM
Yup, just like I remembered, with PO black paint. And while the door looks OK, it has some serious bondo plus rust along the bottom seam.
bkrantz |
Feb 14 2021, 08:08 PM
About 30 minutes later, I had the door completely stripped and the front window channel out.
bkrantz |
Feb 14 2021, 08:09 PM
Truth time. What's under the black paint? Will it be better than the channel from the replacement door?
bkrantz |
Feb 14 2021, 08:11 PM
After some acetone...
bkrantz |
Feb 14 2021, 08:13 PM
Sanding marks, but no gouges like the channel from the replacement door. Yay! We work with this.
bkrantz |
Feb 14 2021, 08:14 PM
Like yesterday, oven cleaner to remove the anodizing.
bkrantz |
Feb 14 2021, 08:15 PM
That leaves a splotchy finish, which sands off easily.
bkrantz |
First, 320 grit.
bkrantz |
Feb 14 2021, 08:16 PM
Then 600 grit.
bkrantz |
Feb 14 2021, 08:17 PM
Then polishing with first black and then white compound. Shiny!
bkrantz |
Feb 14 2021, 08:18 PM
Much better option.
Lo-Fi Version | Time is now: 27th September 2024 - 08:55 AM |
