Rebuiding Inside-out |
bkrantz |
May 23 2021, 07:50 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Then connected the lead for the lever switch.
Attached thumbnail(s) |
bkrantz |
May 23 2021, 07:51 PM
And then installed the lever.
bkrantz |
May 23 2021, 07:54 PM
Here's the indicator light for the heater lever, actuated by the integrated switch.
bkrantz |
May 23 2021, 07:55 PM
This will also need a modified LED bulb.
bkrantz |
May 23 2021, 07:56 PM
Finally, I got out the license plate lights to clean up.
bkrantz |
May 24 2021, 07:06 PM
One of the lights has a couple of cracks. Time for the plastic welding liquid.
bkrantz |
Glued and clamped.
bkrantz |
May 24 2021, 07:07 PM
New LED bulbs.
bkrantz |
May 24 2021, 07:09 PM
Assembled and attached.
bkrantz |
May 24 2021, 07:10 PM
Then I dug out the bag with the parking brake, and fetched the switch.
bkrantz |
May 24 2021, 07:11 PM
Attached to the lead.
bkrantz |
May 24 2021, 07:12 PM
And installed.
All part of my plan to test the electric system before putting the interior together. Attached thumbnail(s) |
bkrantz |
May 24 2021, 07:15 PM
I then got out the cylinder heads. I knew I had some issues with exhaust studs but did not expect big problems. I should have known better.
bkrantz |
May 24 2021, 07:16 PM
One head is missing a stud, with an oversized hole that looks like 9 mm. The threads also look a bit rough.
bkrantz |
May 24 2021, 07:21 PM
The other head also has a missing stud, but the original hole and threads cleaned up with my 8mm tap.
bkrantz |
May 24 2021, 07:22 PM
However, it also has another odd stud. It seemed loose, so I removed it--and watched it wobble on the way out. You might be able to see the bend.
bkrantz |
May 24 2021, 07:24 PM
I screwed a bolt into the hole. The bolt (background) has a very different angle compared to the stud (foreground).
bkrantz |
May 24 2021, 07:28 PM
Looks like the hole with the bad angle has an insert. Whoever did the repair did not get the angle correct.
Sigh. Attached thumbnail(s) |
Puebloswatcop |
May 25 2021, 01:42 PM
Senior Member Group: Members Posts: 1,395 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
bkrantz |
May 25 2021, 06:50 PM
Lo-Fi Version | Time is now: 27th September 2024 - 03:24 PM |
