Rebuiding Inside-out |
bkrantz |
Jun 10 2021, 07:44 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
First, I got the order of parts correct.
Attached thumbnail(s) |
bkrantz |
Jun 10 2021, 07:45 PM
I then made sure the internal spring in the reel was fully wound, and then inserted the belt end.
bkrantz |
Jun 10 2021, 07:46 PM
This pin retains the belt end in the spool center.
bkrantz |
Jun 10 2021, 07:47 PM
Here's the spool all set with the new belt.
bkrantz |
Jun 10 2021, 07:49 PM
I also got new labels for the release buttons.
bkrantz |
Jun 10 2021, 07:51 PM
Better. Note that I removed the plastic sheath and wires for the belt interlock warning system.
bkrantz |
Jun 10 2021, 07:53 PM
Now to sort out the mounting hardware. I think I have the correct parts for the buckles.
bkrantz |
Jun 10 2021, 07:54 PM
And for the shoulder yokes.
bkrantz |
Jun 10 2021, 07:56 PM
But the correct pieces for the belt anchor are a mystery. Here are parts that came off the car, plus some others that I sourced.
bkrantz |
Jun 10 2021, 08:02 PM
And to add to the confusion, I dug through my old parts for the box of belt hardware, including eye-bolts from my racing days. In the bag I found 3 more 914 mounting bolts.
bkrantz |
Jun 11 2021, 06:51 PM
Progress on my custom ash tray interior light holder. For this first attempt, I epoxied the two pieces together.
bkrantz |
Jun 11 2021, 06:52 PM
I then went back to my custom LED fog light conversion, and how to complete the wiring.
bkrantz |
Jun 11 2021, 06:53 PM
I fed the stock leads into the housing, as was original.
930cabman |
Jun 11 2021, 06:54 PM
Advanced Member Group: Members Posts: 3,545 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Bob, do you sleep?
bkrantz |
Jun 11 2021, 06:55 PM
But there is not enough room in the cavity at the base of the housing for both the original leads and the new wiring.
bkrantz |
Jun 11 2021, 06:57 PM
So I reverted to feeding the new leads out of the housing, with some additional cable housing.
bkrantz |
Jun 11 2021, 06:59 PM
I need to find the right waterproof connector.
bkrantz |
Jun 12 2021, 07:35 PM
bkrantz |
Jun 12 2021, 07:39 PM
I think I finished my new ash tray light, but it took a couple of tries.
Both pieces expoxied together. Not as cool as welding, but maybe next time. Attached thumbnail(s) |
bkrantz |
Jun 12 2021, 07:40 PM
After adding a groove for the retaining tab, the light fits--sort of.
Lo-Fi Version | Time is now: 27th September 2024 - 09:28 AM |
