Rebuiding Inside-out |
bkrantz |
Jun 16 2021, 07:24 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Easy to feed this in from the rear, and then mount the fork and lock nut.
Attached thumbnail(s) |
bkrantz |
Jun 16 2021, 07:25 PM
A bit fiddly, but I then got the retaining pin attached.
bkrantz |
Jun 16 2021, 07:26 PM
Next, the throttle cable, also a Porsche part.
bkrantz |
Also fed in from the rear.
bkrantz |
Jun 16 2021, 07:27 PM
And then I made sure it was not wrapped around the clutch cable.
bkrantz |
Jun 16 2021, 07:29 PM
And then I attached the ball joint, and mounted that onto the pedal crank.
bkrantz |
Jun 16 2021, 07:30 PM
Then I installed the covers for the tunnel. I dug these out of the powder-coated box.
bkrantz |
Jun 16 2021, 07:32 PM
Rear cover installed.
bkrantz |
Threaded captive nut threads cleaned.
bkrantz |
Jun 16 2021, 07:33 PM
And front cover installed.
bkrantz |
Jun 16 2021, 07:34 PM
I have not shown a shot of my white board in a while, but these lists are pretty much done.
bkrantz |
Jun 17 2021, 06:56 PM
I got out the drains and plugs for the frunk floor.
bkrantz |
Jun 17 2021, 06:57 PM
Along with a few standard rubber grommets, all the holes are filled.
bkrantz |
Jun 17 2021, 06:59 PM
And a larger grommet in my lumpy front panel.
bkrantz |
Jun 17 2021, 07:00 PM
I got this kit for 2 pin waterproof connectors. It has all the components and weather sealing.
bkrantz |
Jun 17 2021, 07:02 PM
For these plugs to work on the left fog light, I had to add a single wire to the double lead (positive).
bkrantz |
Jun 17 2021, 07:03 PM
Shrink wrap insulation. And don't forget to put the wire seal stoppers on.
bkrantz |
Jun 17 2021, 07:05 PM
All the left side leads with male and female pins. I soldered these on for extra reliability.
bkrantz |
Jun 17 2021, 07:06 PM
Inserting the pins into the female connector requires removing the red locking tab.
bkrantz |
Jun 17 2021, 07:07 PM
Female connector done. These things are a bit fiddly, but might be worth the effort if they keep water out.
Lo-Fi Version | Time is now: 27th September 2024 - 05:27 AM |
