Rebuiding Inside-out |
bkrantz |
Jun 19 2021, 07:58 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Best fit are 6 mm.
Attached thumbnail(s) |
bkrantz |
Jun 19 2021, 07:59 PM
I bolted on the latches.
bkrantz |
Jun 19 2021, 08:00 PM
And then installed the targa top pad. This has a few cracks, but will do for now.
bkrantz |
Jun 19 2021, 08:01 PM
I then got out the targa side weatherstrips.
bkrantz |
Jun 19 2021, 08:02 PM
Pretty easy to install. This was my initial attempt, which was a bit too high. I tried a second time, and left it sticking up just a little bit.
bkrantz |
Jun 19 2021, 08:05 PM
More weatherstrip, here the bulkhead top seal (one of two).
bkrantz |
One in the frunk.
bkrantz |
Jun 19 2021, 08:06 PM
And one in the trunk.
bkrantz |
Jun 19 2021, 08:07 PM
Speaking of the frunk, I got out the perimeter seal.
bkrantz |
I installed this without any adhesive, so it can come out for cleaning the channel.
bkrantz |
Jun 19 2021, 08:08 PM
Here's the trunk seal.
bkrantz |
Jun 19 2021, 08:09 PM
Also an easy installation.
raynekat |
Jun 20 2021, 12:15 AM
Advanced Member Group: Members Posts: 2,160 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Getting there Brother.
Looking great. |
bkrantz |
Jun 20 2021, 06:42 PM
More weatherstrip fun today, getting the front targa top seals installed. This is now my (not so) favorite tool.
bkrantz |
Jun 20 2021, 06:46 PM
Before installing either strip, I had to deal with the edge of the top pad, which is a bit mangled in places.
bkrantz |
Jun 20 2021, 06:47 PM
Time again to dip into my lifetime supply of contact cement.
bkrantz |
Jun 20 2021, 06:49 PM
I was able to get most of the edge glued, and also the "pads" where the front latches attach.
bkrantz |
Jun 20 2021, 06:51 PM
I started on the left corner, and trimmed the metal tab to fit the shape of the indentation in the 914Rubber molding.
bkrantz |
Jun 20 2021, 06:54 PM
Here's the recess, not quite rectangular.
bkrantz |
Jun 20 2021, 06:56 PM
First attempt: almost. I started near the top of the straight section, and then worked into the upper curve. Note that the molding as-is prevents the outer edge of the trim piece to seat.
Lo-Fi Version | Time is now: 27th September 2024 - 03:19 AM |
