Rebuiding Inside-out |
bkrantz |
Jun 23 2021, 07:14 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
Next, I installed the seal. I was able to start it with hard finger pressure, but it took some soft hammer taps.
Attached thumbnail(s) |
bkrantz |
Jun 23 2021, 07:15 PM
Then I got out all the parts for installing the flywheel.
bkrantz |
Jun 23 2021, 07:16 PM
Here's the big O-ring.
bkrantz |
Jun 23 2021, 07:17 PM
Installed. And some assembly lube on the face and outside.
bkrantz |
Jun 23 2021, 07:19 PM
Pilot bearing, with some moly grease.
bkrantz |
The bearing is a tight fit in the flywheel.
bkrantz |
Jun 23 2021, 07:20 PM
So time for the press.
bkrantz |
Jun 23 2021, 07:22 PM
I left the bearing sticking out a bit more than the recess in the end of the crank. I figured that it would press in as required when I bolted the flywheel on.
bkrantz |
Jun 23 2021, 07:24 PM
Then the felt washer, dampened with engine oil, as per the factory repair manual.
bkrantz |
Jun 23 2021, 07:25 PM
The felt washer in place. Note the marks on the flywheel from the old bolts when I made them snug enough for setting the axial play.
bkrantz |
Jun 23 2021, 07:26 PM
Then new bolts and the retaining washer.
bkrantz |
Jun 23 2021, 07:27 PM
After torquing the new bolts, all done with the flywheel.
bkrantz |
A few more things crossed off the list.
bkrantz |
Jun 24 2021, 07:43 PM
I decided to see if I could make my uncooperative repro door handles work. Lots of measuring and thinking.
bkrantz |
Jun 24 2021, 07:44 PM
On the left handle, the out hole was a bit small.
bkrantz |
Jun 24 2021, 07:45 PM
I used a "big" drum sander on my Dremel to open up the hole a bit.
bkrantz |
Jun 24 2021, 07:47 PM
Then I used a hand file to knock off the sharp edge at the inside end of the main cylinder, and take just a little off the inner 1/8 inch of the cylinder.
bkrantz |
Jun 24 2021, 07:49 PM
The cylinder fit OK, but the recess on the inner end of the handle was too deep by about .01 inch, so the cam was binding.
bkrantz |
A bit more hand filing.
bkrantz |
Jun 24 2021, 07:50 PM
On the right handle, the entire opening for the cylinder was too tight. I used the small drum sander to open it up a bit.
Lo-Fi Version | Time is now: 26th September 2024 - 11:15 PM |
