Rebuiding Inside-out |
bkrantz |
Jun 24 2021, 07:55 PM
914 Guru Group: Members Posts: 8,065 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains |
After about 2 hours I have both handles working OK. The cylinders are a little notchy to turn, depending on the key I use, but should work.
Attached thumbnail(s) |
bkrantz |
Jun 25 2021, 07:12 PM
Getting ready to install the gas tank and plumbing. I have some ideas to try.
First, I want to use a metal fuel filter, but can only find 3/8" to 3/8". That means I need to have a separate 3/8" to 1/2" adapter to step up the supply line to feed the pump inlet. Second, I want to see if I can set the lines so I can access and change the filter from underneath. Third, I think I will connect the lines to the tank from underneath, with a minimum amount of extra length. Let's see what will work. Attached thumbnail(s) |
bkrantz |
Jun 25 2021, 07:13 PM
Here's the supply line, with a brass adapter to step up from 3/8 to 1/2" hose.
bkrantz |
Jun 25 2021, 07:15 PM
Supply line connected to the pump inlet, and the extra fed down trough the access hole (for now.
bkrantz |
Jun 25 2021, 07:16 PM
From underneath, the supply line and also the return line from the engine.
bkrantz |
Jun 25 2021, 07:17 PM
Fuel filter, attached from underneath. I can imagine being able to replace this in the future.
bkrantz |
Jun 25 2021, 07:18 PM
Fuel filter tucked inside, where it will live most of the time.
bkrantz |
Jun 25 2021, 07:20 PM
Checking access to the gas tank fittings. This might work.
bkrantz |
Jun 25 2021, 07:22 PM
But before installing the tank, I need to repaint the upper part. The radiator shop the boiled it out did not do much prep, and the paint they applied was flaking off in places. Here's the tank after a quick wire brush treatment.
bkrantz |
Jun 25 2021, 07:23 PM
Primer.
bkrantz |
Jun 25 2021, 07:27 PM
And new paint.
bkrantz |
Jun 25 2021, 07:30 PM
While waiting for paint to fully dry, I refilled the charcoal canister. A few months ago, I drilled 1" holes in each end to empty the original charcoal.
bkrantz |
Jun 25 2021, 07:31 PM
Here's the new charcoal. The pellets are a bit bigger than stock, but should work.
bkrantz |
Jun 25 2021, 07:32 PM
With both internal baffle plates in place, I filled the canister.
bkrantz |
Rubber plug in the fill end.
bkrantz |
Jun 25 2021, 07:33 PM
Here's the spring that keeps pressure on the end baffle to compact the charcoal.
bkrantz |
Jun 25 2021, 07:34 PM
Feeding into the hole.
bkrantz |
And then shoved over to the middle of the space.
bkrantz |
Jun 25 2021, 07:35 PM
Second rubber plug.
bkrantz |
Ready to use.
Lo-Fi Version | Time is now: 26th September 2024 - 11:14 PM |
